Add a simplified path evaluation function IMFS_eval_path_devfs() for a
device only IMFS configuration.
The code size can be further reduced by the application if it disables
the support for legacy IO drivers via:
#define CONFIGURE_IMFS_DISABLE_MKNOD
#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
Obsolete CONFIGURE_MAXIMUM_DEVICES. Remove BSP_MAXIMUM_DEVICES.
Update #3894.
Update #3898.
Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 instead of RTEMS_SYSINIT_ORDER_LAST
to allow applications and support functions to place system
initialization handlers behind the standard handlers.
Update #3838.
Update #3838.
Update #3785.
Always provide this function. Return 0 by default. Fix formatting.
Simplify function.
Update #3785.
ld.lld defaults .work to PROGBITS otherwise
LLVM/LLD does not support STARTUP and ALIGN_WITH_INPUT directives that
GNU LD support. INPUT and ALIGN(8) are supported by LLVM/LLD and can
replace the unsupported STARTUP/ALIGN_WITH_INPUT directives.
The commit conditionally adds the supported directive that linkers
can understand depending on the toolchain used to compile RTEMS
i.e., clang or gcc. Clang is assumed to use LLD by default.
This commit moves the existing linkcmds.base to linkcmds.base.in
in order to make it configurable by autotools.
Added support for Sifive Freedom FE310 soc on Arty A7 FPGA board.
Update #3785.
Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com>
Rename _SMP_Get_processor_count() in _SMP_Get_processor_maximum() to be
in line with the API level rtems_scheduler_get_processor_maximum().
Update #3732.
Update #3732.
Update #3706.
Update #3706.
replace.
searching and sorting.
Update #3706.
* Also switch default config to imafd as the C extension
is not supported for code coverage
Update #3678.
Rename
* _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin,
* _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and
* _Configuration_Interrupt_stack_size in _ISR_Stack_size.
Move definitions to <rtems/score/isr.h>. The new names are considerable
shorter and in the right namespace.
Update #3459.
Spike simulator and QEMU's spike_v1.10 don't have a PLIC
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Initialize fcsr to zero for a defined rounding mode.
Update #3433.
Do not assume that mtime is zero at boot time.
Update #3433.
The previous version worked only on a patched Qemu. Writes to mip are
illegal according to the The RISC-V Instruction Set Manual, Volume II:
Privileged Architecture, Privileged Architecture Version 1.10.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
This is a hack. The clock interrupt should be handled by each hart.
Update #3433.
Update #3433.
Update #3433.
The CLINT and PLIC need some per-processor state.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Remove _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector()
functions. Applications can install an exception handler via the fatal
error handler to handle synchronous exceptions.
Handle interrupt exceptions via _RISCV_Interrupt_dispatch() which must
be provided by the BSP.
Update #3433.
Update #3433.
This is a prepartion to add NS16550 driver support to the console
driver.
Update #3433.
An address must be loaded to a register according to the code model.
Add LADDR define for use in assembler code.
Update #3433.
Update #3433.
