summaryrefslogtreecommitdiff
path: root/bsps/arm/include/cmsis_gcc.h (follow)
AgeCommit message (Collapse)Author
2019-03-08bsps/arm: Adjust CMSIS Doxygen groupsSebastian Huber
Update #3706.
2019-02-28Remove explicit file names from @fileSebastian Huber
This makes the @file documentation independent of the actual file name. Update #3707.
2018-01-25Remove make preinstallChris Johns
