* VERSION: Updated to network-demos-4.9.1.
* VERSION: Updated to network-demos-4.9.0.
* networkconfig-mpc8313erdb.h: New file.
* networkconfig-qemu.h, networkconfig.h: Add missing initializers.
* networkconfig-icecube.h, networkconfig-qemu.h, networkconfig.h:
Updated to include new fields and expand tabs.
* Makefile: Added telnetd test.
* networkconfig-icecube.h: Fix MAC address and typo.
* Makefile: Add mcast.
* networkconfig.h: Loopback only network configuration tweaked to have
a hostname.
* networkconfig.h: Loopback only network configuration. Use one of the
real ones as an example.
* networkconfig-qemu.h: Disable DHCP and use static IP.
* networkconfig.h: Use only loopback so tests can run OK on any target
even if they can't do anything.
* networkconfig-icecube.h: New file.
* VERSION: Updated to network-demos-4.7.99.2.
* networkconfig-qemu.h: New file.
* networkconfig.h: Make the NFS server, remote filesystem, and
directory to look at configurable.
* Makefile: Remove netlink. It appeared to be a hacked copy of http.
* netlink/ChangeLog, netlink/Makefile, netlink/index.html,
netlink/init.c, netlink/networkconfig.h, netlink/system.h: Removed.
* Makefile: New file.
* VERSION: Updated to network-demos-4.7.99.1.
* VERSION: Updated to network-demos-4.6.99.2.
* VERSION: Updated to network-demos-20030128.
* VERSION: Updated to network-demos-20021018.
* VERSION: Updated to /usr1/rtems/releases/netdemos-20021018.
* dnstest/init.c, netdemo/init.c, netlink/init.c, ntp/init.c,
rpc_demo/init.c, select/init.c, tftpTest/init.c, ttcp/init.c:
define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS to 20 for enough
sockets and CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM even if not
absolutely needed for networking.
* SUPPORT: New file.
* README, networkconfig.h, netdemo/README, tftpTest/test.c: Merged
missing stuff from 4.5 branch.
* http/Makefile, http/init.c: Minor modifications to improve
buildability.
* networkconfig.h: Default to using bootp host for tftp test.
* ChangeLog: New file.
