* test.c: Remove warning.
* mcast.c: Remove warning.
* networkconfig-icecube.h: Fix MAC address and typo.
* .cvsignore: New file.
* Makefile: Build native ttcp as side-effect of main build.
* rtems_ttcp.c: Fix warning.
* .cvsignore, Makefile, init.c: Switch to using rtems-bin2c for initial
filesystem image.
* Makefile: Add mcast.
* Makefile: Clean up.
* Makefile: Initial add of multicast test.
* ChangeLog, Makefile, README, init.c, listener.c, mcast.c,
mcast_params.h, mcast_route.c, rootfs/etc/host.conf,
rootfs/etc/hosts: New files.
* networkconfig.h: Loopback only network configuration tweaked to have
a hostname.
* networkconfig.h: Loopback only network configuration. Use one of the
real ones as an example.
* shttpd_index.html: Fix URL for shttpd.
* networkconfig-qemu.h: Disable DHCP and use static IP.
* networkconfig.h: Use only loopback so tests can run OK on any target
even if they can't do anything.
* networkconfig-icecube.h: New file.
* goahead_index.html: This is not preprocessed so hard code name.
* init.c: Simple HTTPD is using ~39K stack space with this test.
Make the stack for the SHTTPD server 48K.
* shttpd_ext.c: Use new name.
* Makefile, init.c, rootfs/.cvsignore: Add some dynamic content.
Can now look at cpu usage, reset cpu usage and print a stack
usage report.
* goahead_index.html, shttpd.png, shttpd_ext.c, shttpd_index.html:
New files.
* index.html.in: Removed.
* init.c: Remove TARFILE_XXX macros.
* Makefile: Use bin2c to more reliably turn the tarfile into a
linkable object file. Ignore .cvsignore when making tarfile.
* init.c: Clean up tarfile symbol definitions.
* .cvsignore, rootfs/.cvsignore: New files.
* Makefile: Account for -B architecture option.
* init.c: Change clock tick to 1 millisecond.
* rtems_ttcp.c: Add CPU usage reporting.
* ttcp_orig/ttcp.c: Add -m option for delaying between writes.
* VERSION: Updated to network-demos-4.7.99.2.
* networkconfig-qemu.h: New file.
* networkconfig.h: Make the NFS server, remote filesystem, and
directory to look at configurable.
* Makefile: Do not restrict size of heap.
* Makefile: Eliminate unneeded temp.o
* init.c: Make the NFS server, remote filesystem, and directory to look
at configurable.
* ChangeLog, init.c: Clean up and now works on PowerPC/ep5200.
* ChangeLog, rootfs/etc/host.conf, rootfs/etc/hosts: New files.
Initial add of NFS Client test.
* .cvsignore, Makefile, dirutils.c, init.c, rootfs/rtems_logo.jpg:
New files.
* init.c: Account for adding port to shttpd initialization.
* ChangeLog, Makefile, init.c: No switchable from GoAhead to SHTTPD but
defaults to SHTTPD. The displayed index.html will indicate which
httpd implementation is enabled. The user should edit the Makefile to
switch settings.
* index.html.in: New file.
* rootfs/index.html: Removed.
* Makefile: Make slightly smarter on LD arguments. Do not pick
up CVS files in tarball.
* init.c: Turn off tracing on GoAhead. More debug.
* rootfs/etc/hosts: Match OAR setup for EP5200.
* rootfs/index.html: Cleanup and use RTEMS Logo.
* rootfs/rtems_logo.jpg: New files.
* rootfs/web/index.html: Removed.
* Makefile: Include all managers.
* init.c: Make the test just a bit more verbose in case the
network initialization failure.
* Makefile: Remove netlink. It appeared to be a hacked copy of http.
* netlink/ChangeLog, netlink/Makefile, netlink/index.html,
netlink/init.c, netlink/networkconfig.h, netlink/system.h: Removed.
* Makefile, init.c: Clean up. Make name of TARFILE related symbols
conditional based upon architecture. Change way desired object format
is determined so all BSPs compile this test.
* test.c: Delete unused code.
* Makefile: Remove tarfile when make clean.
* Makefile: New file.
* init.c: More warnings removed.
* init.c, test.c: More warnings removed.
* test.c: More warnings removed.
* rtems_ttcp.c, ttcp_orig/ttcp.c: Now compiles reasonably cleanly with
CVS head.
* init.c: Now compiles reasonably cleanly with CVS head.
* Makefile, init.c: Now compiles reasonably cleanly with CVS head.
* Makefile, init.c, system.h: Now compiles reasonably cleanly with CVS
head.
* init.c: confdefs.h should be rtems/confdefs.h
* init.c, system.h: confdefs.h should be rtems/confdefs.h
