* Makefile: Account for -B architecture option.
* init.c: Change clock tick to 1 millisecond.
* rtems_ttcp.c: Add CPU usage reporting.
* ttcp_orig/ttcp.c: Add -m option for delaying between writes.
* VERSION: Updated to network-demos-4.7.99.2.
* networkconfig-qemu.h: New file.
* networkconfig.h: Make the NFS server, remote filesystem, and
directory to look at configurable.
* Makefile: Do not restrict size of heap.
* Makefile: Eliminate unneeded temp.o
* init.c: Make the NFS server, remote filesystem, and directory to look
at configurable.
* ChangeLog, init.c: Clean up and now works on PowerPC/ep5200.
* ChangeLog, rootfs/etc/host.conf, rootfs/etc/hosts: New files.
Initial add of NFS Client test.
* .cvsignore, Makefile, dirutils.c, init.c, rootfs/rtems_logo.jpg:
New files.
* init.c: Account for adding port to shttpd initialization.
* ChangeLog, Makefile, init.c: No switchable from GoAhead to SHTTPD but
defaults to SHTTPD. The displayed index.html will indicate which
httpd implementation is enabled. The user should edit the Makefile to
switch settings.
* index.html.in: New file.
* rootfs/index.html: Removed.
* Makefile: Make slightly smarter on LD arguments. Do not pick
up CVS files in tarball.
* init.c: Turn off tracing on GoAhead. More debug.
* rootfs/etc/hosts: Match OAR setup for EP5200.
* rootfs/index.html: Cleanup and use RTEMS Logo.
* rootfs/rtems_logo.jpg: New files.
* rootfs/web/index.html: Removed.
* Makefile: Include all managers.
* init.c: Make the test just a bit more verbose in case the
network initialization failure.
* Makefile: Remove netlink. It appeared to be a hacked copy of http.
* netlink/ChangeLog, netlink/Makefile, netlink/index.html,
netlink/init.c, netlink/networkconfig.h, netlink/system.h: Removed.
* Makefile, init.c: Clean up. Make name of TARFILE related symbols
conditional based upon architecture. Change way desired object format
is determined so all BSPs compile this test.
* test.c: Delete unused code.
* Makefile: Remove tarfile when make clean.
* Makefile: New file.
* init.c: More warnings removed.
* init.c, test.c: More warnings removed.
* test.c: More warnings removed.
* rtems_ttcp.c, ttcp_orig/ttcp.c: Now compiles reasonably cleanly with
CVS head.
* init.c: Now compiles reasonably cleanly with CVS head.
* Makefile, init.c: Now compiles reasonably cleanly with CVS head.
* Makefile, init.c, system.h: Now compiles reasonably cleanly with CVS
head.
* init.c: confdefs.h should be rtems/confdefs.h
* init.c, system.h: confdefs.h should be rtems/confdefs.h
* init.c: Replace CONFIGURE_TEST_XXX with CONFIGURE_APPLICATION_XXX.
* VERSION: Updated to network-demos-4.7.99.1.
* VERSION: Updated to network-demos-4.6.99.2.
* VERSION: Updated to network-demos-20030128.
* init.c: Increase number of file descriptors and use IMFS instead of
mini-IMFS as filesystem.
* VERSION: Updated to network-demos-20021018.
* VERSION: Updated to /usr1/rtems/releases/netdemos-20021018.
* dnstest/init.c, netdemo/init.c, netlink/init.c, ntp/init.c,
rpc_demo/init.c, select/init.c, tftpTest/init.c, ttcp/init.c:
define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS to 20 for enough
sockets and CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM even if not
absolutely needed for networking.
* SUPPORT: New file.
* README, networkconfig.h, netdemo/README, tftpTest/test.c: Merged
missing stuff from 4.5 branch.
* http/Makefile, http/init.c: Minor modifications to improve
buildability.
* networkconfig.h: Default to using bootp host for tftp test.
* init.c, test.c: Added test of write capability.
* ChangeLog: New file.
allow the http demo to build a correct starting filesystem and
run. Formerly, the http demo did not configure the filesystem
as needed or build the tar file such that GoAhead could find it.
value.
