2008-12-12 | 2008-12-12 Joel Sherrill <joel.sherrill@OARcorp.com>network-demos-4-9-1 | Joel Sherrill | |
* VERSION: Updated to network-demos-4.9.1. | |||
2008-10-15 | 2008-10-15 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
PR 1331/networking * init.c: Improve comments and explanation of options to rtems_telnetd_initialize. | |||
2008-09-29 | 2008-09-29 Joel Sherrill <joel.sherrill@OARcorp.com>network-demos-4-9-0 | Joel Sherrill | |
* VERSION: Updated to network-demos-4.9.0. | |||
2008-09-26 | 2008-09-26 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* init.c: Eliminate boolean for bool. | |||
2008-08-21 | This commit was manufactured by cvs2svn to create branch 'network- | cvs2git | |
demos-4-9-branch'. Sprout from master 2008-08-21 16:40:37 UTC Joel Sherrill <joel.sherrill@OARcorp.com> '2008-08-21 Joel Sherrill <joel.sherrill@oarcorp.com>' Cherrypick from ERIC-NORUM 1998-07-30 14:42:29 UTC Joel Sherrill <joel.sherrill@OARcorp.com> 'base from Eric Norum -- Demos.30May1998.tar.gz': ttcp/ttcp_orig/ttcp.1 | |||
2008-08-21 | 2008-08-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* networkconfig-mpc8313erdb.h: New file. | |||
* ttcp_orig/ttcp.c: Fix warning. | |||
* init.c: Fix missing initializers warning. | |||
2008-08-20 | 2008-08-20 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* networkconfig-qemu.h, networkconfig.h: Add missing initializers. | |||
* shttpd_ext.c: Fix warning. | |||
2008-05-22 | 2008-05-22 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* init.c: Add shell configuration. | |||
2008-02-05 | 2008-02-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* networkconfig-icecube.h, networkconfig-qemu.h, networkconfig.h: Updated to include new fields and expand tabs. | |||
* init.c: Now works. | |||
* README: Fix typo. | |||
2007-12-19 | 2007-12-19 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* init.c: Shell now has some commands that require filesystems with bdbuf support. | |||
2007-12-06 | 2007-12-06 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* Makefile, init.c: Make sure POSIX threading is enabled if using GoAhead. | |||
2007-11-09 | 2007-11-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile: bin2c now rtems-bin2c. | |||
* init.c: Test improved. | |||
2007-11-06 | 2007-11-06 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* Makefile: No use of objdump. | |||
2007-09-25 | 2007-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile: Added telnetd test. | |||
* .cvsignore: New file. | |||
* .cvsignore, ChangeLog, Makefile, init.c: New files. | |||
* test.c: Remove warning. | |||
* mcast.c: Remove warning. | |||
* networkconfig-icecube.h: Fix MAC address and typo. | |||
* Makefile: Build native ttcp as side-effect of main build. * rtems_ttcp.c: Fix warning. | |||
* .cvsignore, Makefile, init.c: Switch to using rtems-bin2c for initial filesystem image. | |||
2007-09-19 | 2007-09-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile: Add mcast. | |||
2007-09-19 | Fix typo. | Joel Sherrill | |
* Makefile: Clean up. | |||
* Makefile: Initial add of multicast test. | |||
* ChangeLog, Makefile, README, init.c, listener.c, mcast.c, mcast_params.h, mcast_route.c, rootfs/etc/host.conf, rootfs/etc/hosts: New files. | |||
2007-09-14 | 2007-09-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* networkconfig.h: Loopback only network configuration tweaked to have a hostname. | |||
* networkconfig.h: Loopback only network configuration. Use one of the real ones as an example. | |||
2007-09-07 | 2007-09-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* shttpd_index.html: Fix URL for shttpd. | |||
* networkconfig-qemu.h: Disable DHCP and use static IP. * networkconfig.h: Use only loopback so tests can run OK on any target even if they can't do anything. * networkconfig-icecube.h: New file. | |||
* goahead_index.html: This is not preprocessed so hard code name. * init.c: Simple HTTPD is using ~39K stack space with this test. Make the stack for the SHTTPD server 48K. | |||
2007-09-06 | 2007-09-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* shttpd_ext.c: Use new name. | |||
* Makefile, init.c, rootfs/.cvsignore: Add some dynamic content. Can now look at cpu usage, reset cpu usage and print a stack usage report. * goahead_index.html, shttpd.png, shttpd_ext.c, shttpd_index.html: New files. * index.html.in: Removed. | |||
2007-09-04 | 2007-09-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* init.c: Remove TARFILE_XXX macros. | |||
* Makefile: Use bin2c to more reliably turn the tarfile into a linkable object file. Ignore .cvsignore when making tarfile. * init.c: Clean up tarfile symbol definitions. * .cvsignore, rootfs/.cvsignore: New files. | |||
2007-08-16 | 2007-08-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile: Account for -B architecture option. | |||
* init.c: Change clock tick to 1 millisecond. * rtems_ttcp.c: Add CPU usage reporting. * ttcp_orig/ttcp.c: Add -m option for delaying between writes. | |||
2007-08-07 | 2007-08-07 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* VERSION: Updated to network-demos-4.7.99.2. | |||
2007-07-18 | 2007-07-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* networkconfig-qemu.h: New file. | |||
* networkconfig.h: Make the NFS server, remote filesystem, and directory to look at configurable. | |||
* Makefile: Do not restrict size of heap. | |||
* Makefile: Eliminate unneeded temp.o |
