2006-04-24 | 2006-04-24 Joel Sherrill <joel@OARcorp.com>network-demos-4-6-6network-demos-4-6-branch | Joel Sherrill | |
* VERSION: Updated to network-demos-4.6.6. | |||
2005-10-06 | 2005-10-06 Joel Sherrill <joel@OARcorp.com>network-demos-4-6-5 | Joel Sherrill | |
* VERSION: Updated to network-demos-4.6.5. | |||
2005-09-01 | 2005-09-01 Joel Sherrill <joel@OARcorp.com>network-demos-4-6-4 | Joel Sherrill | |
* VERSION: Updated to network-demos-4.6.4. | |||
2004-10-18 | 2004-10-18 Joel Sherrill <joel@OARcorp.com>network-demos-4-6-2 | Joel Sherrill | |
* VERSION: Updated to network-demos-4.6.2. | |||
2004-04-08 | 2004-04-08 Joel Sherrill <joel@OARcorp.com>network-demos-4-6-1 | Joel Sherrill | |
* VERSION: Updated to network-demos-4.6.1. | |||
2004-01-20 | 2004-01-20 Joel Sherrill <joel@OARcorp.com>network-demos-4-6-0 | Joel Sherrill | |
* VERSION: Updated to network-demos-4.6.0. | |||
2003-10-13 | 2003-10-13 Joel Sherrill <joel@OARcorp.com>network-demos-4-6-0pre5 | Joel Sherrill | |
* VERSION: Updated to network-demos-4.6.0pre5. | |||
2003-10-13 | 2003-10-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
2003-09-26 | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
2003-09-18 | 2003-09-18 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | |
PR 494/networking * Changed Makefile to not use objcopy to create a linkable object file from the tar file. Instead, ld links it in directly. | |||
2003-09-18 | 2003-09-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
PR 493/networking * dnstest/init.c, http/Makefile, http/init.c, http/system.h, netdemo/init.c, netlink/init.c, ntp/init.c, select/init.c, select/test.c, tftpTest/init.c, tftpTest/test.c, ttcp/init.c, ttcp/rtems_ttcp.c: Made all the tests compile and eliminated warnings except in the ttcp_orig code. * Makefile: New file. * netlink/system.h: Removed. | |||
2003-07-03 | 2003-07-03 Joel Sherrill <joel@OARcorp.com>network-demos-4-6-0pre4 | Joel Sherrill | |
* VERSION: Updated to network-demos-4.6.0pre4. | |||
2003-02-11 | 2003-02-11 Joel Sherrill <joel@OARcorp.com>network-demos-4-6-0pre1 | Joel Sherrill | |
* VERSION: Updated to network-demos-4.6.0pre1. | |||
2003-01-28 | This commit was manufactured by cvs2svn to create branch 'network- | cvs2git | |
demos-4-6-branch'. Sprout from master 2003-01-28 22:22:09 UTC Joel Sherrill <joel.sherrill@OARcorp.com> '2003-01-28 Joel Sherrill <joel@OARcorp.com>' Cherrypick from ERIC-NORUM 1998-07-30 14:42:29 UTC Joel Sherrill <joel.sherrill@OARcorp.com> 'base from Eric Norum -- Demos.30May1998.tar.gz': ttcp/ttcp_orig/ttcp.1 | |||
2003-01-28 | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* VERSION: Updated to network-demos-20030128. | |||
* init.c: Increase number of file descriptors and use IMFS instead of mini-IMFS as filesystem. | |||
2002-10-21 | 2002-10-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* VERSION: Updated to network-demos-20021018. | |||
2002-10-18 | 2002-10-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* VERSION: Updated to /usr1/rtems/releases/netdemos-20021018. | |||
* dnstest/init.c, netdemo/init.c, netlink/init.c, ntp/init.c, rpc_demo/init.c, select/init.c, tftpTest/init.c, ttcp/init.c: define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS to 20 for enough sockets and CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM even if not absolutely needed for networking. | |||
2001-08-31 | changed version to ss-20010831 | Joel Sherrill | |
2001-08-31 | 2001-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* SUPPORT: New file. | |||
* README, networkconfig.h, netdemo/README, tftpTest/test.c: Merged missing stuff from 4.5 branch. * http/Makefile, http/init.c: Minor modifications to improve buildability. | |||
2000-12-14 | 2000-12-14 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | |
* networkconfig.h: Default to using bootp host for tftp test. | |||
* init.c, test.c: Added test of write capability. | |||
2000-12-14 | 2000-12-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* ChangeLog: New file. | |||
2000-07-12 | Patch from Andrew Bythell <abythell@nortelnetworks.com> that should | Joel Sherrill | |
allow the http demo to build a correct starting filesystem and run. Formerly, the http demo did not configure the filesystem as needed or build the tar file such that GoAhead could find it. | |||
2000-07-12 | Adding and deleting files for branch and main trunk. | Joel Sherrill | |
2000-05-09 | new file added on 4.5 branch | Joel Sherrill | |
2000-04-29 | New test from Eric Norum <eric@cls.usask.ca> to exercise RPC/XDR. | Joel Sherrill | |
2000-01-04 | Changed version to 20000104. | Joel Sherrill | |
1999-12-14 | Changed CONFIGURATION_MICROSECONDS_PER_TICK definition to a more reasonable | Joel Sherrill | |
value. | |||
1999-11-16 | Changed version to 19991116. | Joel Sherrill | |
1999-11-16 | Cleaned up to make it a bit easier to generate sizes. | Joel Sherrill | |
1999-11-12 | New test to determine network application sizes. | Joel Sherrill | |
1999-11-10 | Patch from Eric Norum <eric@cls.usask.ca> to add the new fields to | Joel Sherrill | |
the network configuration example. | |||
1999-11-10 | New ntp demo test from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | |
1999-10-28 | Changed version to 19991028. | Joel Sherrill | |
1999-10-28 | New httpd sample test from Emmanuel Raguet. | Joel Sherrill | |
1999-08-20 | Changed version to 19990820. | Joel Sherrill | |
1999-07-12 | Patch from Eric Norum <eric@cls.usask.ca>: | Joel Sherrill | |
I changed the TFTP test program and TFTP driver to reflect the changes in the way paths are passed to the TFTP driver. The TFTP driver now needs a proper `dotted-decimal' hostname as the second component of the path name. | |||
1999-07-09 | Changed version to 199900709. | Joel Sherrill | |
1999-06-11 | Patch from Ian Lance Taylor <ian@airs.com> to test new "interrupt-ish" | Joel Sherrill | |
driven select on socket support. After the patch to RTEMS, I have appended a patch to netdemos-19990407/select/test.c to test the new functionality and demonstrate one way it might be used. To run the new test instead of the select test, change doSocket to call echoServer2 instead of echoServer. | |||
1999-06-11 | Updated. | Joel Sherrill | |
1999-04-07 | Changed to bogus information. | Joel Sherrill | |
1999-04-01 | Patch from Eric Norum <eric@skatter.usask.ca> to take advantage of new | Joel Sherrill | |
routines in RTEMS. | |||
1999-02-10 | Added debug print when test can't get a buffer. This is probably a fatal | Joel Sherrill | |
error in the stack but it would be nice to get a message from the test just in case. | |||
1999-02-10 | Modified to delay at startup. | Joel Sherrill | |
1999-02-10 | Modified to support TFTP filesystem. | Joel Sherrill | |
1999-02-10 | Added call to rtems_bsdnet_show_inet_routes(). | Joel Sherrill | |
1999-02-10 | Removed warnings. | Joel Sherrill | |
