2011-12-13 | 2011-12-13 Joel Sherrill <joel.sherrilL@OARcorp.com>network-demos-4-10-2network-demos-4-10-branch | Joel Sherrill | |
* VERSION: Updated to network-demos-4.10.2. | |||
2011-07-21 | 2011-07-21 Joel Sherrill <joel.sherrilL@OARcorp.com>network-demos-4-10-1 | Joel Sherrill | |
* VERSION: Updated to network-demos-4.10.1. | |||
2011-03-04 | 2011-03-04 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | |
* networkconfig-qemu.h: VirtualBox uses 10.0.x.x for its eth0 so we need to switch to 10.1.x.x for things to work. * networkconfig-loopback.h: New file. | |||
2011-02-08 | 2011-02-08 Joel Sherrill <joel.sherrilL@OARcorp.com>network-demos-4-10-0 | Joel Sherrill | |
* VERSION: Updated to network-demos-4.10.0. | |||
2011-02-08 | 2011-02-08 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | |
* init.c: Make compile. | |||
2010-07-03 | 2010-06-29 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | |
* init.c: Update for mount API changes. | |||
2010-02-12 | This commit was manufactured by cvs2svn to create branch 'network- | cvs2git | |
demos-4-10-branch'. Sprout from master 2010-02-12 17:38:30 UTC Joel Sherrill <joel.sherrill@OARcorp.com> '2010-02-12 Joel Sherrill <joel.sherrill@oarcorp.com>' Cherrypick from ERIC-NORUM 1998-07-30 14:42:29 UTC Joel Sherrill <joel.sherrill@OARcorp.com> 'base from Eric Norum -- Demos.30May1998.tar.gz': ttcp/ttcp_orig/ttcp.1 | |||
2010-02-12 | 2010-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* ttcp/rtems_ttcp.c: Update timeval usage. | |||
2009-11-23 | 2009-11-23 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile, goahead_index.html, init.c, shttpd_ext.c, shttpd_index.html: Add Mongoose HTTPD support. * mongoose_ext.c, mongoose_index.html: New files. | |||
2009-11-13 | 2009-11-13 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* VERSION: Updated to network-demos-4.9.3. | |||
2009-05-15 | move old changelog entries to proper location. | Thomas Doerfler | |
init.c: Provide custom shell environment. | |||
2009-05-13 | 2009-05-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* networkconfig-qemu.h: Now works on qemu with fxp driver in RTEMS, the newer version in libbsdport, and on the real NIC in the Winsystems PC in RTEMS Lab. | |||
* Makefile: Allow overrides from invoking environment. | |||
* Makefile, init.c, system.h: Allow overrides from invoking environment. Also move RTEMS Configuration to bottom of init.c. | |||
2009-05-12 | 2009-05-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* init.c: Now build with libbsdport. | |||
* Makefile, init.c: Now build with libbsdport. | |||
* Makefile: Now build with libbsdport. | |||
2009-05-05 | Enable shell login checks. | Thomas Doerfler | |
2009-04-14 | Updated telnet demon initialization | Thomas Doerfler | |
2009-02-10 | 2009-02-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* networkconfig-qemu.h: Add option for qemu to use PCI i82551 NIC. | |||
* Makefile: Fix typo. | |||
2008-10-15 | 2008-10-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
PR 1331/networking * init.c: Improve comments and explanation of options to rtems_telnetd_initialize. | |||
2008-09-18 | 2008-09-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* networkconfig.h: Revert previous patch. Use loopback configuration only. | |||
2008-09-17 | Remove dupe entry. | Joel Sherrill | |
2008-09-17 | 2008-09-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* networkconfig-mpc8313erdb.h, networkconfig.h: Rename STACK_CHECKER_ON to more appropriate CONFIGURE_STACK_CHECKER_ENABLED. | |||
* init.c: Rename STACK_CHECKER_ON to more appropriate CONFIGURE_STACK_CHECKER_ENABLED. | |||
* ChangeLog, init.c: Rename STACK_CHECKER_ON to more appropriate CONFIGURE_STACK_CHECKER_ENABLED. | |||
2008-09-12 | 2008-09-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* init.c: Eliminate use of boolean type. Use C99 bool. | |||
2008-08-21 | 2008-08-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* networkconfig-mpc8313erdb.h: New file. | |||
* ttcp_orig/ttcp.c: Fix warning. | |||
* init.c: Fix missing initializers warning. | |||
2008-08-20 | 2008-08-20 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* networkconfig-qemu.h, networkconfig.h: Add missing initializers. | |||
* shttpd_ext.c: Fix warning. | |||
2008-05-22 | 2008-05-22 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* init.c: Add shell configuration. | |||
2008-02-05 | 2008-02-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* networkconfig-icecube.h, networkconfig-qemu.h, networkconfig.h: Updated to include new fields and expand tabs. | |||
* init.c: Now works. | |||
* README: Fix typo. | |||
2007-12-19 | 2007-12-19 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* init.c: Shell now has some commands that require filesystems with bdbuf support. | |||
2007-12-06 | 2007-12-06 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* Makefile, init.c: Make sure POSIX threading is enabled if using GoAhead. | |||
2007-11-09 | 2007-11-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile: bin2c now rtems-bin2c. | |||
* init.c: Test improved. | |||
2007-11-06 | 2007-11-06 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* Makefile: No use of objdump. | |||
2007-09-25 | 2007-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* Makefile: Added telnetd test. | |||
* .cvsignore: New file. | |||
* .cvsignore, ChangeLog, Makefile, init.c: New files. | |||
* test.c: Remove warning. | |||
* mcast.c: Remove warning. | |||
* networkconfig-icecube.h: Fix MAC address and typo. | |||
* Makefile: Build native ttcp as side-effect of main build. * rtems_ttcp.c: Fix warning. |
