* if_re/if_re.c: fixed 'unused variable' warning by
commenting via #ifndef __rtems__ (since code which uses
the 'msi_disable' var is commented the same way).
* if_pcn/if_pcn.c: fixed 'type-punned pointer' warning.
Use 'memcpy' to copy 2 bytes to a short. This requires
another #ifdef __rtems__, however.
* if_bge/if_bge.c: bge_intr must be passed as a 'handler'
to bus_setup_intr(). However, the irq_check_dis and irq_enable
methods seem to still be skeletons so this driver won't work...
(I have no hardware or emulation available to test).
* libbsdport/alldrv.c: Revert.
* if_bge/if_bge.c, libbsdport/alldrv.c: Add local changes (untested).
* bsd_eth_drivers/libbsdport/sysbus.cL Fixed the print message for
no IRQ handler.
* bsd_eth_drivers/libbsdport/misc.c: Add m_defrag and what else it
needed. The RL driver needs it.
* bsd_eth_drivers/libbsdport/libbsdport_post.h: Remove the define
for m_defrag.
* bsd_eth_drivers/libbsdport/libbsdport.h: Add if_maddr_rlock and
if_maddr_runlock.
* bsd_eth_drivers/libbsdport/bus.h: Add the
bus_space_write_stream_4 call.
* bsd_eth_drivers/libbsdport/libbsdport_post.h,
bsd_eth_drivers/libbsdport/alldrv.c,
bsd_eth_drivers/if_re/Makefile.am: Add RL driver support.
* bsd_eth_drivers/if_re/if_re.c, bsd_eth_drivers/if_re/if_rlreg.h:
Updated to the lastest version.
* bsd_eth_drivers/if_re/if_rl.c: New. This is for the Realtek
8129/8139 PCI NIC while the RE driver does only the 8139C+
version.
* links.am: Fixed the links so they work with absolute paths.
* if_re/Makefile.am: added 'if_rlreg.h' to SOURCES so
that it is 'distributed'.
* if_em/31000_osdep.h: added missing 'void' return
type of __out_le32() inline function.
* libbsdport/rtems_callout.c: fixed possible race
condition. callout_stop() must check again from
critical/protected section of code if callout is still on
the list/active. Otherwise, the callout-task could
have executed and removed the callout between
callout_stop() checking the p_prev pointer and
entering the critical section.
* if_em/Makefile.am, if_em/e1000_osdep.h, if_em/if_em.c:
Changed 'e1000_osdep.h' to provide stdalone I/O methods for
select architectures (x86 and PPC -- others fall back on
libbsdport/bus.h). This lets the low-level driver (everything
except for 'if_em.c/if_em.h') API be independent of
BSD networking and libbsdport which is desirable since
certain applications may wish to just use the low-level
API for implementing dedicated 'raw-ethernet' drivers
for BSD-independent, proprietary GigE communication.
* libbsdport/alldrv.c: reactivate weak aliases for all
known/supported drivers. This magic allows the user to
just link the desired (sub-)set of drivers.
* libbsdport/libbsdport.h: define _KERNEL only if not defined already
(e.g., from Makefile).
* libbsdport/alldrv.c, libbsdport/libbsdport_api.h: Add include
<stdio.h> for FILE *.
- bugfix: bus_write_2() must map to bus_space_write_2 (not 4)
included commits to RCS files with non-trunk default branches.
- removed definition of 'bswap32' (now in libbsdport)
- removed definition of 'callout_active' (now in libbsdport)
- removed definition of 'callout_pending' (now in libbsdport)
- removed bus_dmamap_load() -- I believe the version from libbsdport
should work (but setting the bus addr to zero probably not).
- added (__rtems__) specific code to set multicast address filter
- added ETHER_SIOCMULTIFRAG() macro (__rtems__ specific) to ioctl.
a sentinel. If the user decides only to link a subset of
driver the probe algorithm skips entries matching the
sentinel.
- added more diagnostic messages which can be enabled by
setting 'libbsdportAttachVerbose' to nonzero. This
is quite helpful.
- added the ugliest of all hack -- i386 pcibios API returns
wrong number for bus count :-( [the max bus number instead
of the count]. We simply add 1 to this number...
sentinel.
- added definition of PCIR_CACHELNSZ
- added definition of PCIM_CMD_MWRICEN
- added pci_get_revid()
- moved mii_mediachg() macro-stub to libbsdport_post.h
- added definition for 'bootverbose'
- added bus_release_resources()
- added dummy handle for giant mutex.
- added resource_int_value() stub (returns ENOENT).
- added resource_long_value() stub (returns ENOENT).
- added bus_read_1(), bus_read_2(), bus_read_4()
bus_write_1(), bus_write_2(), bus_write_4().
- honour BUS_DMA_ZERO flag.
- changed 'vaddr' arg from caddr_t to void*
indicating whether a callout was pending.
- added callout_active(), callout_pending(), callout_deactivate().
ether_addmulti()/ether_delmulti() return ENETRESET (which is acually
an OK status).
- moved mii_mediachg() dummy from libbsdport.h to libbsdport_post.h
- added rtems_mii_phy_probe(). This is a helper albeit RTEMS specific.
Porting the whole MII/media stuff is still too much ATM.
- removed files that are generated by autreconf after checkout
and added them to .cvsignore
(SLAC tag 'joel-bsd-drivers-20090214')
* configure.ac, bsd_eth_drivers/Makefile.am,
bsd_eth_drivers/libbsdport/libbsdport_api.h: Add first cut at
Broadcomm BCM57xx driver.
* bsd_eth_drivers/if_bge/.cvsignore,
bsd_eth_drivers/if_bge/Makefile.am, bsd_eth_drivers/if_bge/if_bge.c,
bsd_eth_drivers/if_bge/if_bgereg.h: New files.
APIs are really different.
- must not use INTR_FAST anymore since this will (deliberately) produce
a compile-time error (see <sys/bus.h>)
hint what the porter has to do.
the newer API calls a 'filter' -- however, it must be equipped
with a proper return value.
- as long as MII stuff is not implememented we fake an OK link
by setting rl_link=1.
- removed re_intr_check_dis(), re_intr_en()
* bsd_eth_drivers/re/if_re.c: Almost runs.
* bsd_eth_drivers/libbsdport/sysbus.c: Revert Till's patch.
