* Makefile: Add shell test.
* Makefile: Add new tests. Most of these eitehr demonstrate or verify a
particular functionality.
* cpuuse/Makefile, cpuuse/cpuuse.adb, exception_test2/Makefile,
exception_test2/exceptiontest2.adb, exception_test3/Makefile,
exception_test3/exceptiontest3.adb: New files.
* Makefile, rtems_init.c: Add ada_from_c_task example.
* Makefile: Added exception_test.
* Makefile, Makefile.shared, rtems_init.c, irq_test/interrupt_pkg.adb,
irq_test/interrupt_pkg.ads, irq_test/irqforce.c,
irq_test/irqtest.adb, rootfs/etc/hosts: Adding new tests as
improvements are made to the RTEMS port of the GNAT run-time.
* empty/Makefile, empty/README, empty/empty.adb,
hello_via_task/.cvsignore, hello_via_task/Makefile,
hello_via_task/hello.adb, irq_test/.cvsignore, irq_test/Makefile,
irq_test/README, irq_test_c/.cvsignore, irq_test_c/Makefile,
irq_test_c/README, irq_test_c/init.c, irq_test_c/irqforce.c: New files.
* Makefile: Add stack_check test.
* Makefile.shared: Add EXTRA_GNATFLAGS so stack_check can specify
the flags -fstack-check.
* ChangeLog: New tests. Clean up. Rework so all tests use the same
shared Makefile for the hard logic of producing an executable.
* Makefile, Makefile.shared, README.Makefiles, networkconfig.h,
rtems_init.c: New files.
