Backported build infrastructure and .tcfg files from master.
BSPs for simulators which do not include a clock tick interrupt source
are incapable of running some tests successfully. This is a common
characteristic of some BSPs and a fixed set of tests. There is no point
in duplicating this list of tests in those BSPs test configuration.
Read testsuites/testdata/require-tick-isr.tcfg for details.
Conflicts:
testsuites/automake/test-subdirs.am
tools/build/rtems-test-check
* configure.ac: Remove nios2 (unsupported, no toolchain).
* eolstrip.c: Readdress use of ctype methods per recommendation from
D.J. Delorie on the newlib mailing list. We should pass an unsigned
char into these methods.
* Makefile.am: Rename bin2c to rtems-bin2c.
* bin2c.c: Updated license after author changed it.
* bin2c.c: Update comments.
* bin2c.c: Significant improvements -- add multiple options, generate
both C and H files, do not always generate static. fix indentation,
add comments.
* bin2c.c: New file.
http://www.wxwidgets.org/wiki/index.php/Embedding_PNG_Images-Bin2c_In_C
* Makefile.am: Add bin2c so we can have a more reliable way to convert
binary files to objects. If they are in C, we can use the correct CPU
CFLAGS and they will link easier.
* linkcmds.c, linkcmds.h, memory.c, memory.h, sample.ptf: New files.
* bridges.c: corrected detection of bridged connections
* clocks.c: removed a printf
* linkcmds.[ch] new files, added output of linker script
* Makefile.am: added new files
* memory.[ch]: new files, detection of memory in SOPC configuration
* nios2gen.c: updated command line parsing and output control
* output.[ch]: improved output of BSP header file
* ptf.[ch]: added ptf_dump_ptf_item and small fixes
* sample.ptf: new file, sample configuration for nios2gen
* README: updated
* nios2gen.c: Added some very basic support for --help and --version
options along with output that is roughly in GNU format. This is
required by help2man. help2man expects this all to be written to
stdout instead of stderr so this was changed as well.
* ChangeLog: New file.
* configure.ac: New port to Altera NIOS II.
* nios2/.cvsignore, nios2/Makefile.am, nios2/README, nios2/bridges.c,
nios2/bridges.h, nios2/clocks.c, nios2/clocks.h, nios2/configure.ac,
nios2/devices.c, nios2/devices.h, nios2/nios2gen.c, nios2/output.c,
nios2/output.h, nios2/ptf.c, nios2/ptf.h: New files.
* doxy-filter: New.
* Makefile.am: Add doxy-filter.
* ampolish3.in: Remove.
* Makefile.am: Remove ampolish3.
* configure.ac: Remove ampolish3, perl.
* shgen.c: include <stdlib.h>.
* ampolish3.in: Check Makefile.am for SUBDIRS.
Add all-am: for PREINSTALL_FILES.
* ampolish3.in: Add all: for PREINSTALL_FILES.
Add all-local for TMPINSTALL_FILES.
Misc bug fixes.
* ampolish3.in: Check if Makefile.am already contains CLEANFILES or
DISTCLEANFILES.
* ampolish3.im: Update.
* ampolish3.in: Sync with private bleeding-edge .
* ampolish3.in: Use @PERL@, partial update from local sources.
* configure.ac: Add ampolish3.
* Makefile.am: Add ampolish3.
* ampolish3.in: New.
* configure.ac: Remove RTEMS_CPU_SUBDIRS.
* Makefile.am: Add EXTRA_DIST = search-id.sh multigen
cvsignore-add.sh.
* Makefile.am: DIST_SUBDIRS = @subdirs@.
* Makefile.am: Let shgen.1 depend on shgen$(EXEEXT).
* Makefile.am: Cosmetics.
* Makefile.am: Obsoleting HP PA-RISC port.
* hppa1.1/.cvsignore, hppa1.1/ChangeLog, hppa1.1/Makefile.am,
hppa1.1/configure.ac, hppa1.1/genoffsets.c: Removed.
* genoffsets.c: URL for license changed.
