* math/init.c, mathf/init.c: Use DEVFS since we do have devices.
PR 1890/cpukit
* psxmsgq01/init.c: POSIX says msg_prio is allowed to be NULL.
PR 1855/cpukit
* Makefile.am, configure.ac: Correct signal processing during
pthread_join. We are supposed to unblock the thread waiting on a
pthread_join(), dispatch the signal handler, account for it
potentially overwriting errno, and then have the thread return to
blocking within pthread_join().
* psxeintr_join/.cvsignore, psxeintr_join/Makefile.am,
psxeintr_join/init.c, psxeintr_join/psxeintr_join.doc,
psxeintr_join/psxeintr_join.scn: New files.
PR 1867/cpukit
* Makefile.am, configure.ac, psx12/task.c, psxkey03/init.c,
psxrwlock01/test.c: Correct implementation of pthread_exit() and
pthread_join() to support the case where a thread is joinable but
calls pthread_exit() before a thread has attempted to join.
* psx16/.cvsignore, psx16/Makefile.am, psx16/init.c, psx16/psx16.doc,
psx16/psx16.scn: New files.
* samples/fileio/init.c, samples/fileio/system.h: Add support for
create a RAM disk from the shell to aid bug testing on the 4.10
branch.
'rtems-4-10-branch'.
Cherrypick from master 2011-03-18 10:11:40 UTC Ralf Corsepius <ralf.corsepius@rtems.org> '2010-04-09 Ralf Corsépius <ralf.corsepius@rtems.org>':
cpukit/zlib/ChangeLog
cpukit/zlib/ChangeLog.zlib
cpukit/zlib/FAQ
cpukit/zlib/Makefile.am
cpukit/zlib/README
cpukit/zlib/adler32.c
cpukit/zlib/compress.c
cpukit/zlib/crc32.c
cpukit/zlib/deflate.c
cpukit/zlib/deflate.h
cpukit/zlib/doc/algorithm.txt
cpukit/zlib/gzclose.c
cpukit/zlib/gzguts.h
cpukit/zlib/gzlib.c
cpukit/zlib/gzread.c
cpukit/zlib/gzwrite.c
cpukit/zlib/infback.c
cpukit/zlib/inffast.c
cpukit/zlib/inflate.c
cpukit/zlib/inflate.h
cpukit/zlib/inftrees.c
cpukit/zlib/inftrees.h
cpukit/zlib/trees.c
cpukit/zlib/uncompr.c
cpukit/zlib/zconf.h
cpukit/zlib/zlib.3
cpukit/zlib/zlib.h
cpukit/zlib/zutil.c
cpukit/zlib/zutil.h
testsuites/libtests/mathf/.cvsignore
testsuites/libtests/mathf/Makefile.am
testsuites/libtests/mathf/mathf.scn
Cherrypick from master 2011-02-02 13:58:02 UTC Ralf Corsepius <ralf.corsepius@rtems.org> 'New (Split out from math/).':
testsuites/libtests/mathf/domathf.c
testsuites/libtests/mathf/init.c
* sp69/init.c: Use "ld" instead of PRId32 to print
struct timespec->tv_nsec.
* support/include/tmacros.h: Remove PRIxblksize_t, PRIxblkcnt_t.
* include/pmacros.h: Add PRIxblksize_t, PRIxblkcnt_t.
* configure.ac: Add AC_CHECK_SIZEOF([blksize_t]),
AC_CHECK_SIZEOF([blkcnt_t]).
* sp19/inttest.h: Use PRIx32 instead of "lx".
* sp04/tswitch.c: Shrink memory requirements.
* cpuuse/tswitch.c: Shrink memory requirements.
* math/math.scn, mathf/mathf.scn: Regenerate.
* Makefile.am, configure.ac: Add mathf/.
* math/init.c, math/Makefile.am: Reflect having split-out mathf.
* math/domathf.c, math/domathl.c: Remove.
* mathf/Makefile.am, mathf/domathf.c, mathf/init.c,
mathf/mathf.scn: New (Split out from math/).
* math/init.c:
Use fprintf(stdout,..) instead of printf.
Use CONFIGURE_APPLICATION_DISABLE_FILESYSTEM.
Cherrypick from master 2011-02-01 05:48:30 UTC Ralf Corsepius <ralf.corsepius@rtems.org> '2011-02-01 Ralf Corsepius <ralf.corsepius@rtems.org>':
cpukit/libmisc/stringto/stringtolongdouble.c
testsuites/libtests/POSIX/htonl.c
testsuites/libtests/math/.cvsignore
testsuites/libtests/math/Makefile.am
testsuites/libtests/math/domath.c
testsuites/libtests/math/domath.in
testsuites/libtests/math/domathf.c
testsuites/libtests/math/domathl.c
testsuites/libtests/math/init.c
* math/math.scn: New.
* math/domath.c, math/domathf.c, math/domath.in,
math/domathl.c, math/init.c, math/Makefile.am:
New (Import from rtems-4.11).
* Makefile.am: Add math/
* configure.ac: Add math/Makefile.
PR 1708/build:
* aclocal/check-cpuopts.m4: Fix m4-quoting.
* configure.ac: Check for pthread_attr_{get,set}cputime instead of
pthread_pthread_attr_{get,set}cputime (Typo).
* aclocal/check-cpuopts.m4: Add AC_LANG_SOURCE.
* POSIX/Makefile.am: Add htonl.
* POSIX/htonl.c: New.
* iostream/init.cc: Remove the hack.
* psxfile01/test.c, psxmount/test.c, psxreaddir/test.c,
psxstat/test.c: Update to the new mount API.
* fileio/init.c: Update to new mount API.
* iostream/init.cc: Hack to work around confdefs.h in C++.
* iostream/system.h: Add comment about base miniIMFS.
* configure.ac: Add AC_CHECK_SIZEOF(off_t).
* include/pmacros.h: Add PRIdoff_t.
* support/include/tmacros.h: Remove PRIdoff_t.
* psxfile01/test.c, psxfile01/psxfile01.scn: This file now
exercises the _rename_r in libcsupport. For now, it also
provides two fsmount_me_h handlers to enable certain error
checking paths
PR 1433/cpukit
* block08/bdbuf_tests.c: Enabled tests 1.1, 1.2 and 1.3.
* block08/bdbuf_test1_1.c, block08/bdbuf_test1_2.c,
block08/bdbuf_test1_3.c: Use RTEMS_IO_ERROR instead of
RTEMS_NO_MEMORY.
* block01/init.c, block02/init.c, block03/init.c, block04/init.c,
block05/init.c, block06/init.c, block07/init.c, block09/init.c,
block10/init.c: Changed CONFIGURE_MAXIMUM_SEMAPHORES defines.
* Makefile.am: Move POSIX in front of other tests.
* support/include/tmacros.h: Changed check_dispatch_disable_level() to
treat all non-zero values of _Thread_Dispatch_disable_level equally.
* psxfile01/test.c: Add check for errno on chdir(NULL).
* psxrdwrv/test.c: Use SIZE_MAX not SSIZE_MAX.
* psx07/init.c, psx07/task.c: Introduce enough of a delay so the Init()
thread can reliably reach the pthread_join() call.
* psxreaddir/psxreaddir.scn, psxreaddir/test.c: Do not test for
rewinddir(NULL) since we are now using newlib's implementation and it
does not check for NULL. This causes a fault on some targets.
* bspcmdline01/init.c: Fix assert conditional.
* POSIX/flockfile.c, POSIX/funlockfile.c, POSIX/ftrylockfile.c: New.
* POSIX/Makefile.am: Add flockfile, funlockfile, ftrylockfile.
* capture/init.c: Remove unused variable "out".
* psx07/init.c, psx09/init.c, psx12/init.c, psxhdrs/pthread11.c,
psxhdrs/pthread22.c, psxhdrs/sched01.c, psxhdrs/sched03.c:
Reflect POSIX changes to sched_param.
