2011-02-02 | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Require autoconf-2.68, automake-1.11.1. | |||
2009-12-08 | 2009-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* tmitronsem01/system.h: Use rtems_test_assert() consistently instead of system assert(). rtems_test_assert() is designed to integrate into the RTEMS test suite infrastructure. | |||
2009-10-30 | 2009-10-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* include/timesys.h: Use PRId32. | |||
2009-10-30 | Use PRId32. | Ralf Corsepius | |
2009-10-20 | 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Don't add -ansi -fasm to CFLAGS. | |||
2009-04-03 | Eliminate _exe_/.exe. | Ralf Corsepius | |
2009-04-03 | 2009-04-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* tmitronsem01/Makefile.am: Makefile.am: Eliminate _exe_/.exe. | |||
2008-09-17 | 2008-09-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* include/timesys.h: Rename STACK_CHECKER_ON to more appropriate CONFIGURE_STACK_CHECKER_ENABLED. | |||
2008-08-31 | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* tmitronsem01/Makefile.am, tmitronsem01/init.c: Eliminate empty function from every benchmark timer driver. Fix spelling. | |||
2008-02-01 | 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* tmitronsem01/init.c: Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a clock_settime case for < 1988. | |||
2006-12-02 | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: New BUG-REPORT address. | |||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Require autoconf-2.60. Require automake-1.10. | |||
2006-07-11 | Eliminate scndir, docdir. Use rtems_testsdir instead. | Ralf Corsepius | |
2006-07-11 | 2006-07-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* tmitronsem01/Makefile.am: Eliminate scndir, docdir. Use rtems_testsdir instead. | |||
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. | |||
2005-11-13 | Fix my email address | Ralf Corsepius | |
2005-11-13 | Convert to using *_PROGRAMS. | Ralf Corsepius | |
2005-11-13 | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* tmitronsem01/Makefile.am: Convert to using *_PROGRAMS. | |||
2005-11-11 | Fix typos. | Ralf Corsepius | |
2005-11-11 | * tmitronsem01/Makefile.am: Rework. | Ralf Corsepius | |
2005-11-11 | Rework. | Ralf Corsepius | |
2005-11-11 | Cosmetics. | Ralf Corsepius | |
2005-11-11 | Eliminate TEST. | Ralf Corsepius | |
2005-11-11 | Expand tmitrontests.am. | Ralf Corsepius | |
2005-11-11 | Remove. | Ralf Corsepius | |
2005-11-11 | 2005-11-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* tmitrontests.am: Remove. * tmitronsem01/Makefile.am: Expand tmitrontests.am. | |||
2005-11-10 | Eliminate DOCTYPES. | Ralf Corsepius | |
2005-11-09 | AM_CPPFLAGS += -I..../support/include. | Ralf Corsepius | |
2005-11-09 | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* tmitronsem01/Makefile.am: AM_CPPFLAGS += -I..../support/include. | |||
* tmitrontests.am: Set project_bspdir=$(PROJECT_ROOT) | |||
2005-11-07 | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* tmitrontests.am: Remove LIB_VARIANT. | |||
2005-11-07 | Remove SRC, PRINT_SRC. | Ralf Corsepius | |
2005-11-07 | * tmitronsem01/Makefile.am: Remove SRC, PRINT_SRC. | Ralf Corsepius | |
2005-11-07 | Switch back to include compile.am instead of amcompile.am | Ralf Corsepius | |
* Makefile.am: Cleanup. | |||
2005-11-07 | Add $(PGM): ${ARCH}/$(dirstamp). | Ralf Corsepius | |
* tmitrontests.am: Add $(PGM): ${ARCH}/$(dirstamp). * tmitronsem01/Makefile.am: Partial conversion to automake. | |||
2005-11-07 | Partial conversion to automake. | Ralf Corsepius | |
2004-09-24 | Fix typo in previous change. | Ralf Corsepius | |
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Require automake > 1.9. | |||
2004-04-20 | Remove stray white spaces. | Ralf Corsepius | |
2004-04-01 | * tmitronsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. | Ralf Corsepius | |
2004-04-01 | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | |
* tmitronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>. | |||
2004-03-30 | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | |
* include/timesys.h: Convert to using c99 fixed size types. | |||
2004-03-26 | 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | |
* include/Makefile.am: Remove. * Makefile.am: Merge-in include/Makefile.am. * configure.ac: Reflect changes above. | |||
2004-03-25 | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* configure.ac: Add 2nd arg to RTEMS_TOP. | |||
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* tmitronsem01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | |||
2003-12-18 | 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* tmitrontests.am: Add dirstamp support. | |||
2003-12-17 | 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* tmitrontests.am: Use $(mkdir_p) instead of $(mkinstalldirs). | |||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. |
