2007-05-11 | 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp07/tdelete.c, sp08/Makefile.am, sp09/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am, spsize/size.c: Add optional managers to Makefiles. Clean up test cases so last output line follows END OF pattern. Make sure test case all run. All tests appeared ok on sis. | |||
2006-07-11 | Eliminate scndir, docdir. Use rtems_testsdir instead. | Ralf Corsepius | |
2005-11-13 | Convert to use *_PROGRAMS. | Ralf Corsepius | |
2005-11-11 | Rework. | Ralf Corsepius | |
2005-11-11 | Eliminate TEST. | Ralf Corsepius | |
2005-11-11 | Expand sptests.am. | Ralf Corsepius | |
2005-11-10 | Eliminate DOCTYPES. | Ralf Corsepius | |
2005-11-09 | AM_CPPFLAGS += -I..../support/include. | Ralf Corsepius | |
2005-11-07 | Remove SRC, PRINT_SRC. | Ralf Corsepius | |
2005-11-07 | Switch back to include compile.am instead of amcompile.am | Ralf Corsepius | |
2005-11-07 | Partial conversion to automake. | Ralf Corsepius | |
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* sp01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * sp02/Makefile.am: Ditto. * sp03/Makefile.am: Ditto. * sp04/Makefile.am: Ditto. * sp05/Makefile.am: Ditto. * sp06/Makefile.am: Ditto. * sp07/Makefile.am: Ditto. * sp08/Makefile.am: Ditto. * sp09/Makefile.am: Ditto. * sp11/Makefile.am: Ditto. * sp12/Makefile.am: Ditto. * sp13/Makefile.am: Ditto. * sp14/Makefile.am: Ditto. * sp15/Makefile.am: Ditto. * sp16/Makefile.am: Ditto. * sp17/Makefile.am: Ditto. * sp19/Makefile.am: Ditto. * sp20/Makefile.am: Ditto. * sp21/Makefile.am: Ditto. * sp22/Makefile.am: Ditto. * sp23/Makefile.am: Ditto. * sp24/Makefile.am: Ditto. * sp25/Makefile.am: Ditto. * sp26/Makefile.am: Ditto. * sp27/Makefile.am: Ditto. * sp28/Makefile.am: Ditto. * sp29/Makefile.am: Ditto. * sp30/Makefile.am: Ditto. * sp31/Makefile.am: Ditto. * sp32/Makefile.am: Ditto. * spfatal/Makefile.am: Ditto. * spsize/Makefile.am: Ditto. | |||
2003-12-01 | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* sp01/Makefile.am: Remove all-local: $(ARCH). * sp02/Makefile.am: Remove all-local: $(ARCH). * sp03/Makefile.am: Remove all-local: $(ARCH). * sp04/Makefile.am: Remove all-local: $(ARCH). * sp05/Makefile.am: Remove all-local: $(ARCH). * sp06/Makefile.am: Remove all-local: $(ARCH). * sp07/Makefile.am: Remove all-local: $(ARCH). * sp08/Makefile.am: Remove all-local: $(ARCH). * sp09/Makefile.am: Remove all-local: $(ARCH). * sp11/Makefile.am: Remove all-local: $(ARCH). * sp12/Makefile.am: Remove all-local: $(ARCH). * sp13/Makefile.am: Remove all-local: $(ARCH). * sp14/Makefile.am: Remove all-local: $(ARCH). * sp15/Makefile.am: Remove all-local: $(ARCH). * sp16/Makefile.am: Remove all-local: $(ARCH). * sp17/Makefile.am: Remove all-local: $(ARCH). * sp19/Makefile.am: Remove all-local: $(ARCH). * sp20/Makefile.am: Remove all-local: $(ARCH). * sp21/Makefile.am: Remove all-local: $(ARCH). * sp22/Makefile.am: Remove all-local: $(ARCH). * sp23/Makefile.am: Remove all-local: $(ARCH). * sp24/Makefile.am: Remove all-local: $(ARCH). * sp25/Makefile.am: Remove all-local: $(ARCH). * sp26/Makefile.am: Remove all-local: $(ARCH). * sp27/Makefile.am: Remove all-local: $(ARCH). * sp28/Makefile.am: Remove all-local: $(ARCH). * sp29/Makefile.am: Remove all-local: $(ARCH). * sp30/Makefile.am: Remove all-local: $(ARCH). * sp31/Makefile.am: Remove all-local: $(ARCH). * sp32/Makefile.am: Remove all-local: $(ARCH). * spfatal/Makefile.am: Remove all-local: $(ARCH). * spsize/Makefile.am: Remove all-local: $(ARCH). | |||
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
Makefile.am: Reflect having moved automake. sp01/Makefile.am: Reflect having moved automake. sp02/Makefile.am: Reflect having moved automake. sp03/Makefile.am: Reflect having moved automake. sp04/Makefile.am: Reflect having moved automake. sp05/Makefile.am: Reflect having moved automake. sp06/Makefile.am: Reflect having moved automake. sp07/Makefile.am: Reflect having moved automake. sp08/Makefile.am: Reflect having moved automake. sp09/Makefile.am: Reflect having moved automake. sp11/Makefile.am: Reflect having moved automake. sp12/Makefile.am: Reflect having moved automake. sp13/Makefile.am: Reflect having moved automake. sp14/Makefile.am: Reflect having moved automake. sp15/Makefile.am: Reflect having moved automake. sp16/Makefile.am: Reflect having moved automake. sp17/Makefile.am: Reflect having moved automake. sp19/Makefile.am: Reflect having moved automake. sp20/Makefile.am: Reflect having moved automake. sp21/Makefile.am: Reflect having moved automake. sp22/Makefile.am: Reflect having moved automake. sp23/Makefile.am: Reflect having moved automake. sp24/Makefile.am: Reflect having moved automake. sp25/Makefile.am: Reflect having moved automake. sp26/Makefile.am: Reflect having moved automake. sp27/Makefile.am: Reflect having moved automake. sp28/Makefile.am: Reflect having moved automake. sp29/Makefile.am: Reflect having moved automake. sp30/Makefile.am: Reflect having moved automake. sp31/Makefile.am: Reflect having moved automake. sp32/Makefile.am: Reflect having moved automake. spfatal/Makefile.am: Reflect having moved automake. spsize/Makefile.am: Reflect having moved automake. | |||
2002-09-14 | 2002-09-14 Aaron J. Grier <aaron@frye.com> | Joel Sherrill | |
* PR271 was not applicable against the current source but included a nice test that Joel decided to add to the tree as sp32. * sp32/Makefile.am, sp32/init.c, sp32/sp32.scn: New file. * Makefile.am, configure.ac: Modified to reflect addition. |
