2006-09-11 | Remove extra CRLF. | Chris Johns | |
2006-07-11 | Eliminate scndir, docdir. Use rtems_testsdir instead. | Ralf Corsepius | |
2005-11-13 | Convert to using *_PROGRAMS. | Ralf Corsepius | |
2005-11-11 | Rework. | Ralf Corsepius | |
2005-11-11 | Cosmetics. | Ralf Corsepius | |
2005-11-11 | Eliminate TEST. | Ralf Corsepius | |
2005-11-11 | Expand psxtests.am. | Ralf Corsepius | |
2005-11-10 | Eliminate DOCTYPES. | Ralf Corsepius | |
2005-11-09 | AM_CPPFLAGS += -I..../support/include. | Ralf Corsepius | |
2005-11-07 | Add ../include/pmacros.h | Ralf Corsepius | |
2005-11-07 | Remove SRC, PRINT_SRC. | Ralf Corsepius | |
2005-11-07 | Switch back to include compile.am instead of amcompile.am | Ralf Corsepius | |
2005-11-07 | Partial conversion to automake. | Ralf Corsepius | |
2005-09-01 | 2005-09-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
PR 628/rtems * psx04/init.c, psx04/psx04.scn: Update tests to reflect a signal of 0 being an error. | |||
2004-04-16 | Remove stray white spaces. | Ralf Corsepius | |
2004-04-01 | * psx01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. | Ralf Corsepius | |
* psx02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psx13/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxcancel/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxchroot01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxfile01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxmount/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxmsgq01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxreaddir/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxstat/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxtime/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * psxtimer/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. | |||
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* psx01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * psx02/Makefile.am: Ditto. * psx03/Makefile.am: Ditto. * psx04/Makefile.am: Ditto. * psx05/Makefile.am: Ditto. * psx06/Makefile.am: Ditto. * psx07/Makefile.am: Ditto. * psx08/Makefile.am: Ditto. * psx09/Makefile.am: Ditto. * psx10/Makefile.am: Ditto. * psx11/Makefile.am: Ditto. * psx12/Makefile.am: Ditto. * psx13/Makefile.am: Ditto. * psxcancel/Makefile.am: Ditto. * psxchroot01/Makefile.am: Ditto. * psxfile01/Makefile.am: Ditto. * psxmount/Makefile.am: Ditto. * psxmsgq01/Makefile.am: Ditto. * psxreaddir/Makefile.am: Ditto. * psxsem01/Makefile.am: Ditto. * psxstat/Makefile.am: Ditto. * psxtime/Makefile.am: Ditto. * psxtimer/Makefile.am: Ditto. | |||
2003-12-01 | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* include/Makefile.am: Reformat. * psx01/Makefile.am: Remove all-local: $(ARCH). * psx02/Makefile.am: Remove all-local: $(ARCH). * psx03/Makefile.am: Remove all-local: $(ARCH). * psx04/Makefile.am: Remove all-local: $(ARCH). * psx05/Makefile.am: Remove all-local: $(ARCH). * psx06/Makefile.am: Remove all-local: $(ARCH). * psx07/Makefile.am: Remove all-local: $(ARCH). * psx08/Makefile.am: Remove all-local: $(ARCH). * psx09/Makefile.am: Remove all-local: $(ARCH). * psx10/Makefile.am: Remove all-local: $(ARCH). * psx11/Makefile.am: Remove all-local: $(ARCH). * psx12/Makefile.am: Remove all-local: $(ARCH). * psx13/Makefile.am: Remove all-local: $(ARCH). * psxcancel/Makefile.am: Remove all-local: $(ARCH). * psxchroot01/Makefile.am: Remove all-local: $(ARCH). * psxfile01/Makefile.am: Remove all-local: $(ARCH). * psxhdrs/Makefile.am: Remove all-local: $(ARCH). * psxmount/Makefile.am: Remove all-local: $(ARCH). * psxmsgq01/Makefile.am: Remove all-local: $(ARCH). * psxreaddir/Makefile.am: Remove all-local: $(ARCH). * psxsem01/Makefile.am: Remove all-local: $(ARCH). * psxstat/Makefile.am: Remove all-local: $(ARCH). * psxtime/Makefile.am: Remove all-local: $(ARCH). * psxtimer/Makefile.am: Remove all-local: $(ARCH). | |||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* psx01/init.c, psx01/system.h, psx01/task.c, psx02/init.c, psx02/system.h, psx02/task.c, psx03/init.c, psx03/system.h, psx03/task.c, psx04/init.c, psx04/system.h, psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/system.h, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/system.h, psx06/task.c, psx06/task2.c, psx07/init.c, psx07/system.h, psx07/task.c, psx08/init.c, psx08/system.h, psx08/task1.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx09/system.h, psx10/init.c, psx10/system.h, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/system.h, psx11/task.c, psx12/init.c, psx12/system.h, psx12/task.c, psx13/main.c, psx13/test.c, psxcancel/init.c, psxfile01/main.c, psxfile01/test.c, psxhdrs/clock01.c, psxhdrs/clock02.c, psxhdrs/clock03.c, psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c, psxhdrs/cond01.c, psxhdrs/cond02.c, psxhdrs/cond03.c, psxhdrs/cond04.c, psxhdrs/cond05.c, psxhdrs/cond06.c, psxhdrs/cond07.c, psxhdrs/cond08.c, psxhdrs/cond09.c, psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c, psxhdrs/key04.c, psxhdrs/mutex01.c, psxhdrs/mutex02.c, psxhdrs/mutex03.c, psxhdrs/mutex04.c, psxhdrs/mutex05.c, psxhdrs/mutex06.c, psxhdrs/mutex07.c, psxhdrs/mutex08.c, psxhdrs/mutex09.c, psxhdrs/mutex10.c, psxhdrs/mutex11.c, psxhdrs/mutex12.c, psxhdrs/mutex13.c, psxhdrs/mutex14.c, psxhdrs/mutex15.c, psxhdrs/mutex16.c, psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c, psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c, psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c, psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c, psxhdrs/proc13.c, psxhdrs/proc14.c, psxhdrs/pthread01.c, psxhdrs/pthread02.c, psxhdrs/pthread03.c, psxhdrs/pthread04.c, psxhdrs/pthread05.c, psxhdrs/pthread06.c, psxhdrs/pthread07.c, psxhdrs/pthread08.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c, psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c, psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c, psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c, psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c, psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c, psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c, psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread31.c, psxhdrs/pthread32.c, psxhdrs/pthread33.c, psxhdrs/pthread34.c, psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/sched01.c, psxhdrs/sched02.c, psxhdrs/sched03.c, psxhdrs/sched04.c, psxhdrs/sched05.c, psxhdrs/sched06.c, psxhdrs/sched07.c, psxhdrs/sched08.c, psxhdrs/signal01.c, psxhdrs/signal02.c, psxhdrs/signal03.c, psxhdrs/signal04.c, psxhdrs/signal05.c, psxhdrs/signal06.c, psxhdrs/signal07.c, psxhdrs/signal08.c, psxhdrs/signal09.c, psxhdrs/signal10.c, psxhdrs/signal11.c, psxhdrs/signal12.c, psxhdrs/signal13.c, psxhdrs/signal14.c, psxhdrs/signal15.c, psxhdrs/signal16.c, psxhdrs/signal17.c, psxhdrs/signal18.c, psxhdrs/signal19.c, psxhdrs/signal20.c, psxhdrs/signal21.c, psxhdrs/signal22.c, psxhdrs/signal23.c, psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c, psxhdrs/time01.c, psxhdrs/time02.c, psxhdrs/time03.c, psxhdrs/time04.c, psxhdrs/time05.c, psxhdrs/time06.c, psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c, psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c, psxhdrs/time13.c, psxhdrs/timer01.c, psxhdrs/timer02.c, psxhdrs/timer03.c, psxhdrs/timer04.c, psxhdrs/timer05.c, psxhdrs/timer06.c, psxhdrs/timer07.c, psxmsgq01/init.c, psxmsgq01/system.h, psxsem01/system.h, psxstat/main.c, psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c, psxtimer/system.h: URL for license changed. | |||
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. psx01/Makefile.am: Reflect having moved automake. psx02/Makefile.am: Reflect having moved automake. psx03/Makefile.am: Reflect having moved automake. psx04/Makefile.am: Reflect having moved automake. psx05/Makefile.am: Reflect having moved automake. psx06/Makefile.am: Reflect having moved automake. psx07/Makefile.am: Reflect having moved automake. psx08/Makefile.am: Reflect having moved automake. psx09/Makefile.am: Reflect having moved automake. psx10/Makefile.am: Reflect having moved automake. psx11/Makefile.am: Reflect having moved automake. psx12/Makefile.am: Reflect having moved automake. psx13/Makefile.am: Reflect having moved automake. psxcancel/Makefile.am: Reflect having moved automake. psxchroot01/Makefile.am: Reflect having moved automake. psxfile01/Makefile.am: Reflect having moved automake. psxhdrs/Makefile.am: Reflect having moved automake. psxmount/Makefile.am: Reflect having moved automake. psxmsgq01/Makefile.am: Reflect having moved automake. psxreaddir/Makefile.am: Reflect having moved automake. psxsem01/Makefile.am: Reflect having moved automake. psxstat/Makefile.am: Reflect having moved automake. psxtime/Makefile.am: Reflect having moved automake. psxtimer/Makefile.am: Reflect having moved automake. | |||
2003-05-29 | 2003-05-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* psx02/init.c, psx04/init.c, psx13/test.c, psxchroot01/test.c, psxhdrs/pthread07.c, psxmsgq01/init.c, psxreaddir/test.c, psxtimer/psxtimer.c: Removed warnings. | |||
2002-11-14 | 2002-11-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* psx01/psx01.scn, psx02/psx02.scn, psx03/psx03.scn, psx04/psx04.scn, psx05/psx05.scn, psx06/psx06.scn, psx07/psx07.scn, psx08/psx08.scn, psx09/psx09.scn, psx10/psx10.scn, psx11/psx11.scn, psx12/psx12.scn: Per PR239 update the IDs in the various screens. | |||
2002-08-11 | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* psx01/Makefile.am: Use .$(OBJEXT) instead of .o. * psx02/Makefile.am: Use .$(OBJEXT) instead of .o. * psx03/Makefile.am: Use .$(OBJEXT) instead of .o. * psx04/Makefile.am: Use .$(OBJEXT) instead of .o. * psx05/Makefile.am: Use .$(OBJEXT) instead of .o. * psx06/Makefile.am: Use .$(OBJEXT) instead of .o. * psx07/Makefile.am: Use .$(OBJEXT) instead of .o. * psx08/Makefile.am: Use .$(OBJEXT) instead of .o. * psx09/Makefile.am: Use .$(OBJEXT) instead of .o. * psx10/Makefile.am: Use .$(OBJEXT) instead of .o. * psx11/Makefile.am: Use .$(OBJEXT) instead of .o. * psx12/Makefile.am: Use .$(OBJEXT) instead of .o. * psx13/Makefile.am: Use .$(OBJEXT) instead of .o. * psxcancel/Makefile.am: Use .$(OBJEXT) instead of .o. * psxchroot01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxfile01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxhdrs/Makefile.am: Use .$(OBJEXT) instead of .o. * psxmount/Makefile.am: Use .$(OBJEXT) instead of .o. * psxmsgq01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxreaddir/Makefile.am: Use .$(OBJEXT) instead of .o. * psxsem01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxstat/Makefile.am: Use .$(OBJEXT) instead of .o. * psxtime/Makefile.am: Use .$(OBJEXT) instead of .o. * psxtimer/Makefile.am: Use .$(OBJEXT) instead of .o. | |||
2002-08-02 | 2002-08-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c, psx05/init.c, psx06/init.c, psx07/init.c, psx08/task3.c, psx09/init.c, psx10/init.c, psx11/init.c, psx12/init.c, psx13/Makefile.am, psx13/main.c, psx13/test.c, psxcancel/init.c, psxchroot01/Makefile.am, psxchroot01/main.c, psxchroot01/test.c, psxfile01/Makefile.am, psxfile01/main.c, psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c, psxfile01/test_write.c, psxmount/Makefile.am, psxmount/main.c, psxmount/test.c, psxmsgq01/init.c, psxreaddir/Makefile.am, psxreaddir/main.c, psxreaddir/test.c, psxsem01/init.c, psxstat/Makefile.am, psxstat/main.c, psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c: Modified. | |||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx02/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx03/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx04/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx05/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx06/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx07/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx08/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx09/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx10/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx11/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx12/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx13/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxcancel/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxchroot01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxfile01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxhdrs/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxmount/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxmsgq01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxreaddir/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxsem01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxstat/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxtime/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxtimer/Makefile.am: Remove AUTOMAKE_OPTIONS. | |||
2001-09-19 | 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* psx01/Makefile.am: include leaf.am instead of leaf.cfg. * psx11/Makefile.am: include leaf.am instead of leaf.cfg. * psxcancel/Makefile.am: include leaf.am instead of leaf.cfg. * psx02/Makefile.am: include leaf.am instead of leaf.cfg. * psx13/Makefile.am: include leaf.am instead of leaf.cfg. * psxtime/Makefile.am: include leaf.am instead of leaf.cfg. * psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg. * psx07/Makefile.am: include leaf.am instead of leaf.cfg. * psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg. * psxtimer/Makefile.am: include leaf.am instead of leaf.cfg. * psx10/Makefile.am: include leaf.am instead of leaf.cfg. * psx08/Makefile.am: include leaf.am instead of leaf.cfg. * psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg. * psxfile01/Makefile.am: include leaf.am instead of leaf.cfg. * psx05/Makefile.am: include leaf.am instead of leaf.cfg. * psx09/Makefile.am: include leaf.am instead of leaf.cfg. * psxmount/Makefile.am: include leaf.am instead of leaf.cfg. * psxstat/Makefile.am: include leaf.am instead of leaf.cfg. * psx12/Makefile.am: include leaf.am instead of leaf.cfg. * psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg. * psxsem01/Makefile.am: include leaf.am instead of leaf.cfg. * psx03/Makefile.am: include leaf.am instead of leaf.cfg. * psx04/Makefile.am: include leaf.am instead of leaf.cfg. * psx06/Makefile.am: include leaf.am instead of leaf.cfg. | |||
2001-04-20 | 2001-04-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* psx04/init.c, psx04/psx04.scn, psx07/init.c, psx07/psx07.scn, psxfile01/psxfile01.scn, psxmsgq01/psxmsgq01.scn, psxreaddir/test.c, psxstat/psxstat.scn, psxstat/test.c, psxtime/psxtime.scn, psxtimer/psxtimer.scn: Various adjustments so test output matches screens more reliably. | |||
2000-09-05 | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am | |||
2000-09-01 | 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am, psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am: Use AM_CPPFLAGS += instead of AM_CPPFLAGS = | |||
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | |
2000-04-13 | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | |
adds .cvsignore. | |||
2000-01-31 | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | |||
1999-11-23 | Moved pmacros.h to include not support/include. | Joel Sherrill | |
1999-11-23 | Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
to convert the psxtests directory from Makefile.in to Makefile.am. | |||
1999-11-17 | Updated copyright notice. | Joel Sherrill | |
1999-10-21 | Increased stack size of initialization thread. | Joel Sherrill | |
1999-03-16 | Commented out test case that no long works since addition of POSIX timers. | Joel Sherrill | |
1998-12-03 | Added Comment that a result is valid at 4 or 5 seconds. | Jennifer Averett | |
1998-02-17 | updated copyright to 1998 | Joel Sherrill | |
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | |
of switching to the modified GNU GPL. | |||
1996-09-18 | new files | Joel Sherrill | |
1996-08-23 | Changed all EFAULTS to EINVALs | Mark Johannes | |
1996-08-23 | Filled in the screen | Mark Johannes | |
1996-08-15 | init: added tests for pthread_kill and kill errors. | Mark Johannes | |
1996-08-08 | Added task2 and task3 prototypes and ids | Mark Johannes | |
1996-08-08 | Signal_info_handler: added multiple signal cases to finish out the test | Mark Johannes | |
1996-06-13 | Added more test cases for kill() and alarm(). kill() now can unblock a | Joel Sherrill | |
thread which has the signal unblocked. | |||
1996-06-12 | new files | Joel Sherrill | |
