2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2014-03-20 | tests/libtests: Use <rtems/test.h> | Sebastian Huber | |
2012-05-31 | Revert "Revert "libtests/math*: Avoid generated files"" | Ralf Corsépius | |
This reverts commit 87c8d8aba6a9582ca5eeacd332b5b107e26ea50f. | |||
2012-05-31 | Revert "libtests/math*: Avoid generated files" | Ralf Corsépius | |
This reverts commit 6a5bd1c65c005457455db344f2ee831d7a5cf99b. | |||
2012-05-24 | Revert "Revert "libtests/math*: Avoid generated files"" | Ralf Corsépius | |
2012-05-23 | Revert "libtests/math*: Avoid generated files" | Ralf Corsépius | |
2012-05-22 | libtests/math*: Avoid generated files | Sebastian Huber | |
Use C pre-processor instead of shell commands. | |||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2012-05-07 | Revert: Remove CVS Ids | Joel Sherrill | |
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | |||
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | |
2012-02-01 | Remove all .cvsignore files. | Joel Sherrill | |
2011-12-13 | 2011-12-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* math/init.c, mathf/init.c, mathl/init.c: Move configuration section. * math/domath.c, mathf/domathf.c, mathl/domathl.c: Regenerate. * math/domath.in: Generate domath* prototype. | |||
2011-02-22 | Add HAVE_CONFIG_H. | Ralf Corsepius | |
2011-02-14 | 2011-02-14 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | |
* math/init.c, mathf/init.c, mathl/init.c: Now run. | |||
2011-02-02 | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* math/math.scn, mathf/mathf.scn, mathl/mathl.scn: Regenerate. | |||
2011-02-02 | New (Split out from math/). | Ralf Corsepius | |
