summaryrefslogtreecommitdiff
path: root/make/custom (follow)
AgeCommit message (Collapse)Author
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-02-01Remove all .cvsignore files.Joel Sherrill
2011-04-012011-04-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* custom/default.cfg: Update to account for movement of .cfg files.
2009-10-16Remove (Abandoned).Ralf Corsepius
2009-10-15Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius
2009-10-152009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* custom/lm32_evr.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/brs5l.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/h8sim.cfg, custom/h8sxsim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/c3xsim.cfg, custom/c4xsim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/nios2_iss.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-14Remove.Ralf Corsepius
2009-10-05add missing filesThomas Doerfler
2009-10-05renamed config filesThomas Doerfler
2009-10-012009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* Makefile.am: Add new BSP variants for ARM simulator in GDB. * custom/arm1136jfs.cfg, custom/arm1136js.cfg, custom/arm7tdmi.cfg, custom/arm920.cfg, custom/armcortexa9.cfg: New files.
2009-09-242009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* Makefile.am: Add qemuppc.cfg. * custom/qemuppc.cfg: New file.
2009-09-142009-09-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* custom/gen83xx.cfg: Remove -funit-at-a-time.
2009-08-272009-08-27 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* custom/leon2.cfg, custom/leon3.cfg: Fix typo.
2009-06-042009-06-04 Xi Yang <hiyangxi@gmail.com>Joel Sherrill
* Makefile.am: New Gumstix BSP. * custom/gumstix.cfg: New file.
2009-05-282009-05-28 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* custom/csb637.cfg: New file.
2009-02-27added missing filesThomas Doerfler
2009-02-27 * README: Added NCS.Thomas Doerfler
* Makefile.am, configure.ac, preinstall.am: Added BSP variants. * console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed register settings. Cleanup. * include/bsp.h: Added network defines and functions. * include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status sizes. * include/system-clocks.h, misc/system-clocks.c: Added micro seconds delay function that uses Timer 1. Changed PLL setup. * network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478, startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New files. * startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
2009-02-192009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* custom/simsh2e.cfg: New file.
2009-02-172009-02-17 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill
PR 1371/bsps * custom/mvme167.cfg: mvme167 needs to convert ELF -> pure binary RALF.
2009-02-172009-02-17 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* custom/uC5282.cfg: Add cvs Id.
2009-02-112009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* custom/h8sxsim.cfg: Small H8SX should be optimized for size.
2009-02-06Remove.Ralf Corsepius
2009-02-052009-02-05 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* custom/pck6.cfg: Remove.
2008-12-042008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi>Joel Sherrill
* Makefile.am: Add Lattice Mico32 support. * custom/lm32_evr.cfg: New file.
2008-11-202008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* custom/avrtest.cfg: New file.
2008-11-202008-11-20 Daron Chabot <daronchabot@gmail.com>Joel Sherrill
PR 1337/bsps * custom/pc386.cfg: Stripping .rodata section produces unusable executables for the i386-rtems target.
2008-10-142008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* Makefile.am: Add h8sxsim BSP variant. * custom/h8sxsim.cfg: New file.
2008-10-10Added -msoft-float and removed -funit-at-a-time in CPU_CFLAGSThomas Doerfler
2008-10-022008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* custom/m32rsim.cfg: New file.
* custom/m32csim.cfg: New file.
2008-10-02Remove -Dvirtex.Ralf Corsepius
2008-10-02Remove RTEMS_TQM_MODEL.Ralf Corsepius
2008-10-02Remove RTEMS_BOARD_MODEL.Ralf Corsepius
2008-10-02Remove RTEMS_BOARD_MODEL. Remove RTEMS_54XX_DERIVATE (Unused).Ralf Corsepius
2008-10-02Remove RTEMS_BOARD_MODEL, RTEMS_83XX_DERIVATE.Ralf Corsepius
