* HELP.html, bsp_howto/support.t, relnotes/status.texi,
started_ada/buildada.t: Remove references to posix/Unix port.
* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* posix_users/.cvsignore, rgdb_specs/.cvsignore, rtems_gdb/.cvsignore,
started/.cvsignore, started_ada/.cvsignore: Add more generated files.
* configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry,
porting/cpumodels.t, started/buildc.t, started_ada/buildada.t,
user/preface.texi: i960 obsoleted.
* ChangeLog: Merge-in ada_user/ChangeLog.
* ChangeLog: Merge-in started_ada/ChangeLog.
* ada_user/ChangeLog, started_ada/ChangeLog: Remove.
* buildada.t: mips64orion port removed as mips port more completely
covers the MIPS family.
* Makefile.am: Cosmetics.
* intro.t, started_ada.texi, tversions.texi: Merge from branch.
* buildada.t, gdb.t, tversions.texi:
Don't use VARIABLEs containing '-' in @set and @value (violates
texi-syntax).
* started_ada.texi: Set @setfilename started_ada.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* Makefile.am: Corrected link.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
C version of Getting Started.
to work with pdf generation.
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
<Stephan.Wilms@CWA.de>.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
pdf version of figures.
Disabled building of pdf for both the C and Ada Getting Started manuals
because texi2pdf can not handle the construct:
@set URL http://www.rtems.com
@uref{@value{URL},@value{URL}}
It will be reenabled as soon as this problem is fixed.
figures included.
