* Makefile.am: Don't install html_imagesdir unconditionally.
* Makefile.am, configure.ac, index.html.in: Add initial version of
RTEMS Shell Manual. This is largely a starting point but has most of
the required structure.
* shell/.cvsignore, shell/Makefile.am, shell/file.t, shell/general.t,
shell/memory.t, shell/network.t, shell/preface.texi, shell/rtems.t,
shell/shell.texi: New files.
* Makefile.am, configure.ac, develenv/direct.t: Remove RDBG.
* rgdb_specs/.cvsignore, rgdb_specs/Makefile.am, rgdb_specs/comm.t,
rgdb_specs/conclusion.t, rgdb_specs/daemon.t,
rgdb_specs/gdbinternals.t, rgdb_specs/interfacing.t,
rgdb_specs/intro.t, rgdb_specs/layers.eps, rgdb_specs/layers.jpg,
rgdb_specs/layers.txt, rgdb_specs/objectives.t,
rgdb_specs/process.eps, rgdb_specs/process.jpg,
rgdb_specs/process.txt, rgdb_specs/revision.t,
rgdb_specs/rgdb_specs.texi, rgdb_specs/seqbreak.eps,
rgdb_specs/seqbreak.jpg, rgdb_specs/seqbreak.txt,
rgdb_specs/seqdetach.eps, rgdb_specs/seqdetach.jpg,
rgdb_specs/seqdetach.txt, rgdb_specs/seqinit.eps,
rgdb_specs/seqinit.jpg, rgdb_specs/seqinit.txt, rtems_gdb/.cvsignore,
rtems_gdb/Makefile.am, rtems_gdb/commands.t, rtems_gdb/example.t,
rtems_gdb/intro.t, rtems_gdb/rtems_gdb.texi, rtems_gdb/started.t,
rtems_gdb/swarch.t, rtems_gdb/trouble.t: Removed.
* Makefile.am, configure.ac, develenv/direct.t: Remove gnu_docs. Now
included with RPMs.
* gnu_docs/.cvsignore, gnu_docs/ChangeLog, gnu_docs/Makefile.am,
gnu_docs/Tool_Doc_Instructions, gnu_docs/gen_docs,
gnu_docs/gnu_footer.html, gnu_docs/gnu_header.html,
gnu_docs/index.html, gnu_docs/mk_install_dir, gnu_docs/refcard.html,
gnu_docs/rtems_tools_index.html: Removed.
* Makefile.am, configure.ac, index.html.in: FAQ should now be
completely in the Wiki.
* FAQ/.cvsignore, FAQ/FAQ.texi, FAQ/Makefile.am, FAQ/basic.t,
FAQ/bsp.t, FAQ/build45.t, FAQ/concepts.t, FAQ/debug.t,
FAQ/endoftime.t, FAQ/entry, FAQ/freesw.t, FAQ/hwdebugaids.t,
FAQ/projects.t, FAQ/stamp-vti, FAQ/tools.t, FAQ/version.texi,
common/timemac.texi, common/timetbl.t, common/timing.t: Removed.
* Makefile.am, configure.ac, FAQ/stamp-vti, FAQ/version.texi,
common/cpright.texi: Merging CPU Supplements into a single document.
As part of this removed the obsolete and impossible to maintain size
and timing information.
* cpu_supplement/.cvsignore, cpu_supplement/Makefile.am,
cpu_supplement/arm.t, cpu_supplement/i386.t, cpu_supplement/m68k.t,
cpu_supplement/mips.t, cpu_supplement/powerpc.t,
cpu_supplement/preface.texi, cpu_supplement/sh.t,
cpu_supplement/sparc.t, cpu_supplement/tic4x.t: New files.
* supplements/.cvsignore, supplements/Makefile.am,
supplements/supplement.am, supplements/arm/.cvsignore,
supplements/arm/BSP_TIMES, supplements/arm/ChangeLog,
supplements/arm/Makefile.am, supplements/arm/arm.texi,
supplements/arm/bsp.t, supplements/arm/callconv.t,
supplements/arm/cpumodel.t, supplements/arm/cputable.t,
supplements/arm/fatalerr.t, supplements/arm/intr_NOTIMES.t,
supplements/arm/memmodel.t, supplements/arm/preface.texi,
supplements/arm/timeBSP.t, supplements/c4x/.cvsignore,
supplements/c4x/BSP_TIMES, supplements/c4x/ChangeLog,
supplements/c4x/Makefile.am, supplements/c4x/bsp.t,
supplements/c4x/c4x.texi, supplements/c4x/callconv.t,
supplements/c4x/cpumodel.t, supplements/c4x/cputable.t,
supplements/c4x/fatalerr.t, supplements/c4x/intr_NOTIMES.t,
supplements/c4x/memmodel.t, supplements/c4x/preface.texi,
supplements/c4x/timeBSP.t, supplements/i386/.cvsignore,
supplements/i386/ChangeLog, supplements/i386/FORCE386_TIMES,
supplements/i386/Makefile.am, supplements/i386/bsp.t,
supplements/i386/callconv.t, supplements/i386/cpumodel.t,
supplements/i386/cputable.t, supplements/i386/fatalerr.t,
supplements/i386/i386.texi, supplements/i386/intr_NOTIMES.t,
supplements/i386/memmodel.t, supplements/i386/preface.texi,
supplements/i386/timeFORCE386.t, supplements/m68k/.cvsignore,
supplements/m68k/ChangeLog, supplements/m68k/MVME136_TIMES,
supplements/m68k/Makefile.am, supplements/m68k/bsp.t,
supplements/m68k/callconv.t, supplements/m68k/cpumodel.t,
supplements/m68k/cputable.t, supplements/m68k/fatalerr.t,
supplements/m68k/intr_NOTIMES.t, supplements/m68k/m68k.texi,
supplements/m68k/memmodel.t, supplements/m68k/preface.texi,
supplements/m68k/timeMVME136.t, supplements/m68k/timedata.t,
supplements/mips/.cvsignore, supplements/mips/BSP_TIMES,
supplements/mips/ChangeLog, supplements/mips/Makefile.am,
supplements/mips/bsp.t, supplements/mips/callconv.t,
supplements/mips/cpumodel.t, supplements/mips/cputable.t,
supplements/mips/fatalerr.t, supplements/mips/intr_NOTIMES.t,
supplements/mips/memmodel.t, supplements/mips/mips.texi,
supplements/mips/preface.texi, supplements/mips/timeBSP.t,
supplements/powerpc/.cvsignore, supplements/powerpc/ChangeLog,
supplements/powerpc/DMV177_TIMES, supplements/powerpc/Makefile.am,
supplements/powerpc/PSIM_TIMES, supplements/powerpc/bsp.t,
supplements/powerpc/callconv.t, supplements/powerpc/cpumodel.t,
supplements/powerpc/cputable.t, supplements/powerpc/fatalerr.t,
supplements/powerpc/intr_NOTIMES.t, supplements/powerpc/memmodel.t,
supplements/powerpc/powerpc.texi, supplements/powerpc/preface.texi,
supplements/powerpc/timeDMV177.t, supplements/powerpc/timePSIM.t,
supplements/sh/.cvsignore, supplements/sh/BSP_TIMES,
supplements/sh/ChangeLog, supplements/sh/Makefile.am,
supplements/sh/bsp.t, supplements/sh/callconv.t,
supplements/sh/cpumodel.t, supplements/sh/cputable.t,
supplements/sh/fatalerr.t, supplements/sh/intr_NOTIMES.t,
supplements/sh/memmodel.t, supplements/sh/preface.texi,
supplements/sh/sh.texi, supplements/sh/timeBSP.t,
supplements/sparc/.cvsignore, supplements/sparc/ChangeLog,
supplements/sparc/ERC32_TIMES, supplements/sparc/Makefile.am,
supplements/sparc/bsp.t, supplements/sparc/callconv.t,
supplements/sparc/cpumodel.t, supplements/sparc/cputable.t,
supplements/sparc/fatalerr.t, supplements/sparc/intr_NOTIMES.t,
supplements/sparc/memmodel.t, supplements/sparc/preface.texi,
supplements/sparc/sparc.texi, supplements/sparc/timeERC32.t,
supplements/template/.cvsignore, supplements/template/BSP_TIMES,
supplements/template/ChangeLog, supplements/template/Makefile.am,
supplements/template/bsp.t, supplements/template/callconv.t,
supplements/template/cpumodel.t, supplements/template/cputable.t,
supplements/template/fatalerr.t, supplements/template/intr_NOTIMES.t,
supplements/template/memmodel.t, supplements/template/preface.texi,
supplements/template/template.texi, supplements/template/timeBSP.t: Removed.
* Makefile.am: Remove AUTOMAKE_FILES.
Add ../scripts/setup.def ../COPYING to EXTRA_DIST.
Add rtems.html.in to EXTRA_DIST.
* Makefile.am: Add missing '\'. Reformat.
PR 513/doc
* Makefile.am, index.html.in: Rename Getting Started to be non-language
specific and remove link to Ada Getting Started. Also install missing
graphic.
* configure.ac: Merger from rtems-4-6-branch.
Purge hppa1.1.
* index.html.in: Purge hppa1.1.
* project.am: Merger from rtems-4-6-branch.
* rtems_support.html.in: Purge hppa1.1.
* Makefile.am, configure.ac: Remove src2html references.
* index.html.in: Update to reflect partial update of Development
Environment Guide.
* Makefile.am: Merge-in images/Makefile.am, common/Makefile.am.
* images/Makefile.am: Remove.
* common/Makefile.am: Remove.
* main.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS.
* bootstrap: Remove.
* VERSION: Remove.
* Makefile.am:
Remove bootstrap.
Add ACLOCAL_AMFLAGS.
* configure.ac: Add RTEMS_TOP.
* .cvsignore: Reworked.
* Makefile.am: Remove texinfo/texinfo.tex
* bootstrap: Removed.
* configure.ac: Add pkgdocdir. Let htmldir be rooted at pkgdocdir.
* main.am: Remove TEXINFO_TEX.
* project.am: Let dvidir, psdir, pdfdir be rooted at pkgdocdir.
Remove commented out make-variables.
* .cvsignore: Add autom4te.cache, install-sh, mdate-sh, missing,
mkinstalldirs, texinfo.tex.
* Makefile.am: Add main.am to AUTOMAKE_FILES.
* configure.ac: Add AC_CONFIG_AUX_DIR([.]).
* project.am: Remove custom .texi and stamp-vti rules.
* main.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
* project.am: Reworked.
* main.am: New.
* configure.ac: New.
* configure.in: Removed.
* bootstrap: Sync with RTEMS's toplevel bootstrap.sh.
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
