2008-03-07 | 2008-03-07 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
PR 1280/tools * shttpd/log.c: Broaden logic so all gcc versions < 4.3.0 will enable work around. | |||
2007-09-06 | 2007-09-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* shttpd/compat_rtems.c: Style clean up. | |||
2007-07-30 | changes | Ralf Corsepius | |
2007-07-30 | 2007-07-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* shttpd/log.c: Add preliminary version of SPLIT_SNPRINTF to work-around bug m68k/coldfire -fomit-frame-pointer bug http://gcc.gnu.org/bugzilla/show_bug.cgi?id=32307. | |||
2007-07-24 | Don't build most of my_* wrappers for rtems. | Ralf Corsepius | |
2007-07-24 | Don't build my_stat for rtems. | Ralf Corsepius | |
2007-07-24 | Prefix all non-public symbols with _shttp_. | Ralf Corsepius | |
2007-07-12 | 2007-07-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* shttpd/compat_rtems.c, shttpd/compat_rtems.h: Add port to listen on to shttpd initialization. | |||
2007-06-12 | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* shttpd/defs.h: Eliminate my_strncasecmp. * shttpd/string.c: Eliminate my_strncasecmp. | |||
2007-06-12 | Eliminate my_strlcpy. | Ralf Corsepius | |
2007-06-12 | Eliminate my_strdup, my_strndup. | Ralf Corsepius | |
* shttpd/Makefile.am: Add -DHAVE_MD5 to use md5 routines from libmd.a. | |||
2007-06-11 | Remove. | Ralf Corsepius | |
2007-06-11 | Regenerate. | Ralf Corsepius | |
2007-06-11 | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* shttpd/Makefile.am: Conditionally build on LIBNETWORKING. | |||
* shttpd/compat_rtems.h: Include <arpa/inet.h>. Add config.h support. | |||
* shttpd/compat_rtems.h: Define closesocket. | |||
2007-06-11 | New. | Ralf Corsepius | |
* shttpd/compat_rtems.h: Add IS_DIRSEP_CHAR. | |||
2007-06-11 | Use size_t for stack sizes. | Ralf Corsepius | |
* shttpd/Makefile.am: New. | |||
2007-06-11 | Remove (Renamed to Makefile.shttpd) | Ralf Corsepius | |
2007-06-11 | Rename shttpd's Makefile | Ralf Corsepius | |
2007-06-11 | Import from shttpd-1.37. | Ralf Corsepius | |
