summaryrefslogtreecommitdiff
path: root/cpukit/score/cpu/bfin/headers.am (follow)
AgeCommit message (Collapse)Author
2018-10-10build: Include header.am in cpukit/Makefile.amSebastian Huber
Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets rid of all subtree Makefile.am and the sudirs hack.
2018-03-12bfin/include/rtems/score/types.h: Eliminate this fileJoel Sherrill
Updates #3327.
2018-01-25Remove make preinstallChris Johns
