* AUTHORS, COPYING, README: Convert to UNIX CR/LF style.
* mingw-path.nsi: Change the forward slashes to back slashes for
Windows.
* filewrite.nsi, getparameters.nsi, instance-check.nsi,
mingw-path.nsi, sm-dummy.nsi, strslash.nsi, strstr.nsi,
options.nsi: Added the shared between the 2 installer scripts.
* msys-path.nsi: Fixed the last LF bug.
* rtems-autotools.nsi, rtems-tools.nsi: Fixed the instance check,
added a start menu, remove pages from target installers.
* rtems.ini: Fixed the URL links. Added support link.
* rtems_logo.bmp: Trimmed a little more to get a better image.
* ba-wrap.sh: Stop on a error.
* build-exes.sh: Use the option parameter variables. Change the
order the section appear in the installer.
* rtems_logo.bmp: Clipped to get the correct proportions
in the installer's header.
* upload.sh: Install only the specific build installers.
* rtems.ini: Change to show the actual web paths.
* version: Build 15.
* build-exes.sh, msys-path.nsi, rtems-autotools.nsi,
rtems-tools.nsi: Fixed MSYS path detection. Fixed the uninstaller
registry data. Changed the way the top level is generated. Now all
the sections are added no matter what target is specified.
* README, build-rpms.sh, rtems.ini, build-exes.sh,
rtems-tools.nsi: Updated to the new 4.8 build plus a new
installer.
* autoconf.def, automake.def, ba-wrap.sh, build-autotools.sh,
msys-path.nsi, rtems-autotools.nsi, target-section-text,
upload.sh, version: New to version 4.8. Autotools is built when
installing.
* build-rpms.sh: Fix typos.
* build.sh: Log the script command lines.
* build-rpms.sh:
Updated to handle a different build processor to a i686.
* build-exes.sh:
Removed the tool version as Ralf has removed it from the
rpms.
2006-08-05 Chris Johns <chrisj@rtems.org>
* build-exes.sh: Update the release tag.
2006-08-04 Chris Johns <chrisj@rtems.org>
* build-exes.sh: Updated to support the new installer.
* build-rpms.sh:
Updated to use common rather than base. More rpmbuild work
arounds.
* build.sh: Fix the return code when used with tee.
* rtems.ini: Updated hello screen.
* rtems-tools.nsi: Generate the batch files when
installing.
* AUTHORS, README: Convert to DOS format.
2006-07-22 Chris Johns <chrisj@rtems.org>
* COPYING, build.sh, rtems-license.rtf:
Changes to the installer and an extra script to build all.
* build-rpms.sh: Add the build-rpms.sh here until moved to crossrpms.
* AUTHORS, ChangeLog, README: Add the support files.
