* preinstall.am: Save changes again to make tagger happy.
* Makefile.am, preinstall.am: You need main() to link all applications.
There is no C++ specific way to link currently.
* Makefile.am, startup/main.c: Now can link with C compiler and not
require C++ compiler to link. The file rtems-ctor.cc is not being
built but if there is a need for C++ code to run on this BSP, then it
will have to be addressed. The simplest solution which might work is
to check the RTEMS system state before calling bsp_start() in main().
* startup/bspstart.c: Use uintptr_t for address arithmetics.
* bsp_specs: Remove -qrtems_debug.
* startup/rtems-ctor.cc: Conditionally disable non-GCC code.
* Makefile.am: Add preinstall.am.
* include/bsp.h: New header guard.
* Makefile.am: Merge rtems-ctor.o into libbsp.a.
Fix building rtems-ctor.o and no-ctor.o.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* Makefile.am: Build main.o for !HAS_CXX.
Set EXEEXT = <empty> (Workaround to a bug in automake).
* startup/exit.c: Include <rtems/clockdrv.h> instead of <clockdrv.h>.
* clock/clock.c, include/bsp.h, shmsupp/cause_intr.c,
shmsupp/getcfg.c, shmsupp/lock.c, startup/bspstart.c: Convert to
using c99 fixed size types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* configure.ac: Remove AM_CONDITIONAL(HAS_MP).
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* startup/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* wrapup/Makefile.am: Remove GENERIC_FILES.
* startup/Makefile.am: Add custom compilation rule for
rtems-ctor$(LIB_VARIANT).$(OBJEXT).
* shmsupp/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
* timer/timer.c: Obsoleting HP PA-RISC port and removing all
references.
* clock/clock.c, console/console.c, include/bsp.h, shmsupp/addrconv.c,
shmsupp/cause_intr.c, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c,
startup/exit.c, startup/setvec.c, timer/timer.c: URL for license
changed.
shmsupp/Makefile.am: Reflect having moved automake.
* configure.ac: Add BSPOPTS (WORKSPACE_MB, HEAPSPACE_MB).
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS. Cosmetical
changes.
