PR 1391/bsps
* startup/spurious.c: Format was %d but had leading 0x.
* startup/linkcmds: All SPARC executables should include
rtems_get_version_string so the monitor used can provide RTEMS
awareness based upon the version.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* startup/spurious.c: Fix typo from previous commit.
* console/debugputs.c, include/bsp.h, leon_smc91111/leon_smc91111.c,
startup/spurious.c: Remove debug print methods that are redundant
with prntk and replace their use with printk.
* startup/linkcmds: Handle .data.* sections
* startup/linkcmds: Add .rela.dyn sections.
* startup/linkcmds: Add .gnu.linkonce.b.* section.
* startup/linkcmds: Add sections required by newer gcc versions.
