* Makefile.am, preinstall.am: i2c should be on branch as well as CVS
head.
* Makefile.am, preinstall.am: Use the following new drivers from
sparc/shared: PCI, b1553BRM, SpaceWire(GRSPW), CAN (GRCAN), Raw UART.
* Makefile.am, preinstall.am: LEON3 AMBA PnP bus scanning moved to
shared/amba/amba.c and shared/include/ambapp.h. The AMBA scanning was
improved to take account for PnP info address translation. This is
useful when scanning remote AMBA busses for example when a board
connected with PCI has an AMBA bus that needs to be scanned, before
the addresses was hard coded. Also, LEON2 now have AMBA PnP bus
scanning support. By using the new AMBA scanning routines it is
possible to isolate the AMBA scanning code to ambapp.c, however
existing drivers should be updated to use them in order to save
space.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
