2011-02-02 | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Require autoconf-2.68, automake-1.11.1. | |||
2009-11-28 | Whitespace removal. | Ralf Corsepius | |
2009-10-21 | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Remove reference to bare BSP. Simplify RTEMS_BSP_LIST setup. | |||
2007-03-27 | 2007-03-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Use MKDIR_P instead of mkdir_p. | |||
2006-12-02 | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: New BUG-REPORT address. | |||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Require autoconf-2.60. Require automake-1.10. | |||
2004-10-18 | 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Rework checking for BSPs. | |||
* acinclude.m4: Remove RTEMS_CHECK_CPU. * configure.ac: Remove RTEMS_CHECK_CPU, RTEMS_ENABLE_BARE. | |||
2004-09-24 | Fix typo in previous change. | Ralf Corsepius | |
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Require automake > 1.9. | |||
2004-03-31 | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Add --with-project-root, --with-project-top to rtems_bsp_configure. | |||
2004-02-17 | 2004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* Makefile.am: Cosmetics. * configure.ac: Add support for --disable-rtemsbsp. Cosmetics. | |||
2003-12-14 | 2003-12-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* Makefile.am: Remove RTEMS_BSP-subdir rule. * configure.ac: Let AC_CONFIG_FILES(Makefile..) append explictit rules for RTEMS_BSP-subdirs. | |||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||
2003-12-11 | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* configure.ac: Cosmetics. * Makefile.am: Cosmetics. | |||
2003-10-23 | 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* acinclude.m4: Merge-in former ../aclocal/config-subdirs.m4. * configure.ac: remove RTEMS_CANONICAL_HOST. | |||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||
2003-03-25 | Merger from rtems-4-6-branch. | Ralf Corsepius | |
2003-02-11 | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||
* configure.ac: AC_PREREQ(2.57). | |||
2002-10-21 | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* configure.ac: Fix --enable-rtemsbsp= handling. | |||
2002-10-11 | 2002-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* configure.ac: Apply RTEMS_CONFIGURE_ARGS_QUOTE. | |||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||
2002-01-06 | 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* Makefile.am: Remove make from SUBDIRS. * configure.ac: Remove make from CONFIG_SUBDIRS, cosmetics. | |||
2001-10-11 | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. |
