2011-02-02 | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Require autoconf-2.68, automake-1.11.1. | |||
2009-10-21 | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Remove reference to bare BSP. Simplify RTEMS_BSP_LIST setup. | |||
2008-12-04 | 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi> | Joel Sherrill | |
* TOOL_TARGETS: Add Lattice Mico32 support. | |||
2008-10-02 | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* src/aclocal/rtems-cpu-subdirs.m4: Add new M32R port. It is just a beginning but the BSP is functional enough to initialize and shutdown RTEMS. | |||
2007-05-10 | Back off patch which should not have been committed. | Joel Sherrill | |
2007-05-10 | 2007-05-10 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
PR 1237/rtems * src/lib/libbsp/shared/bsplibc.c: Add logic to prevent stack creep when interrupts occur at a sufficient rate that the interrupted thread never gets to clean its stack. This patch ensures that an interrupted thread will not nest ISR dispatches on its stack. | |||
2007-03-27 | 2007-03-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Use MKDIR_P instead of mkdir_p. | |||
2006-12-02 | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: New BUG-REPORT address. | |||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Require autoconf-2.60. Require automake-1.10. | |||
2006-08-09 | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | |
* TOOL_TARGETS: New port to Altera NIOS II. | |||
2005-11-13 | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* Makefile.am: Remove depend-am. | |||
2004-10-18 | 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Rework checking for BSPs. | |||
* acinclude.m4: Remove RTEMS_CHECK_CPU. * configure.ac: Remove RTEMS_CHECK_CPU, RTEMS_ENABLE_BARE. | |||
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Require automake > 1.9. | |||
2004-03-31 | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | |
* configure.ac: Add --with-project-root, --with-project-top to rtems_bsp_configure. | |||
2004-02-17 | 2004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* Makefile.am: Cosmetics. * configure.ac: Add support for --disable-rtemsbsp. Cosmetics. | |||
2004-01-07 | 2004-01-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* ACKNOWLEDGEMENTS: Remove efi68k and efi332 references as they are no longer in the tree. | |||
2003-12-17 | 2003-12-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* release_support: Removed -- accidentally added to wrong directory. | |||
* release_support: New file -- assistant to new cut_release script. | |||
2003-12-14 | 2003-12-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* Makefile.am: Remove RTEMS_BSP-subdir rule. * configure.ac: Let AC_CONFIG_FILES(Makefile..) append explictit rules for RTEMS_BSP-subdirs. | |||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* Makefile.am: Use mkdir_p instead of mkinstalldirs. | |||
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||
2003-12-11 | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* configure.ac: Cosmetics. * Makefile.am: Cosmetics. | |||
2003-11-26 | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* acinclude.m4: Fix underquoting to silence automake-1.8. | |||
2003-10-23 | 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* acinclude.m4: Merge-in former ../aclocal/config-subdirs.m4. * configure.ac: remove RTEMS_CANONICAL_HOST. | |||
* Makefile.am: Don't explictly invoke $MAKE preinstall. | |||
2003-10-02 | 2003-10-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* acinclude.m4: New. Add RTEMS_CHECK_CPU. | |||
2003-09-26 | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* ACKNOWLEDGEMENTS: Obsoleting HP PA-RISC port and removing all references. | |||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||
2003-03-25 | Merger from rtems-4-6-branch. | Ralf Corsepius | |
2003-02-15 | Merger from rtems-4-6-branch | Ralf Corsepius | |
2003-02-11 | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||
* configure.ac: AC_PREREQ(2.57). | |||
2002-11-07 | 2002-11-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* TOOL_TARGETS: Updated. * PROBLEMS, README, REQUIRES, TESTED, UPDATE_HELP: Removed since they were obsolete. | |||
2002-11-02 | 2002-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* Makefile.am: Use mkinstalldirs instead of mkdir. | |||
2002-10-21 | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* configure.ac: Fix --enable-rtemsbsp= handling. | |||
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||
2002-10-11 | 2002-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | |
* configure.ac: Apply RTEMS_CONFIGURE_ARGS_QUOTE. | |||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||
2002-01-06 | 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* Makefile.am: Remove make from SUBDIRS. * configure.ac: Remove make from CONFIG_SUBDIRS, cosmetics. | |||
2001-10-11 | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | |||
2001-05-25 | 2001-05-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* TESTED: Corrected the name of the MRM332 BSP. | |||
* TESTED: Updated the list of BSPs. * TOOLS_TARGETS: Updated the list of tools and object formats. | |||
2001-03-14 | 2001-03-08 Ralf Corsepiu <corsepius@faw.uni-ulm.de> | Joel Sherrill | |
* configure.in: Use ${MAKE} in message at the end of the configure.in. | |||
2001-02-05 | 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* configure.in: Apply _RTEMS_ADJUST_SRCDIR. | |||
2000-12-14 | 2000-12-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* TESTED: Added comment on 68en302 now that there is a network driver. | |||
2000-11-25 | 2000-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* TESTED: Added jmr3904 entry. | |||
2000-11-21 | 2000-11-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* TESTED: Added new sparc variations (erc32, leon, and Tharsys). | |||
2000-11-10 | 2000-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* configure.in: catch -enable-rtemsbsp (Allowed by autoconf). Autoconf allows one to pass -enable-*, but this file expected --enable*. | |||
2000-11-09 | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. |
