2011-12-13 | Upgrade to 4.10.24.10.2 | Joel Sherrill | |
2011-07-21 | Upgrade to 4.10.14.10.1 | Joel Sherrill | |
2011-02-08 | Ensure all version instances say 4.10. | Joel Sherrill | |
2010-05-11 | 2010-05-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/bsp-alias.m4: Change quoting to work-round http://www.freebsd.org/cgi/query-pr.cgi?pr=146378. | |||
2009-10-23 | 2009-10-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/check-custom-bsp.m4: Be less verbose. | |||
2009-10-21 | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/bsp-alias.m4: Fix quoting bug. | |||
2009-10-17 | Remove "blacklist". | Ralf Corsepius | |
2009-10-17 | Remove "${srcdir}/${RTEMS_TOPdir}/make/custom/$1". | Ralf Corsepius | |
2009-10-16 | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/bsp-alias.m4: Remove bare BSP (Abandoned). | |||
2009-10-16 | Cosmetics. | Ralf Corsepius | |
* aclocal/bsp-alias.m4: Pickup bsps from c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom*.cfg. | |||
2009-10-15 | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/check-bsps.m4: Pickup bsps from c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom*.cfg. | |||
* aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for *.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom. | |||
2009-10-14 | Remove posix/unix simulator. | Ralf Corsepius | |
2009-10-05 | renamed lpc24xx BSPs | Thomas Doerfler | |
2009-10-01 | 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* aclocal/bsp-alias.m4: Add BSP for GDB ARM simulator so we can easily experiment with and debug different ARM architectural variations. | |||
2009-09-14 | 2009-09-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/check-bsps.m4: Add csb337 bsp family. | |||
2009-07-23 | 2009-07-23 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/enable-itron.m4: Default to not building itron. | |||
2009-05-28 | 2009-05-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* aclocal/bsp-alias.m4: Add csb637 as variant of csb337. | |||
2009-02-27 | * README: Added NCS. | Thomas Doerfler | |
* Makefile.am, configure.ac, preinstall.am: Added BSP variants. * console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed register settings. Cleanup. * include/bsp.h: Added network defines and functions. * include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status sizes. * include/system-clocks.h, misc/system-clocks.c: Added micro seconds delay function that uses Timer 1. Changed PLL setup. * network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478, startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New files. * startup/bspstart.c: Added EMC initialization. Changes for ROM boot. | |||
2009-02-19 | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* aclocal/bsp-alias.m4: Add simsh2e. | |||
2009-02-06 | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/canonical-target-name.m4: Remove comment referring to HPUX9. | |||
2009-02-05 | Remove pck6 BSP. | Ralf Corsepius | |
2008-12-30 | 2008-12-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/check-bsps.m4: remove stray ")" from rtl22xx_t alias. | |||
2008-12-22 | Remove tic4x. | Ralf Corsepius | |
2008-10-14 | 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add h8sxsim as variant of h8sim. | |||
2008-10-02 | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add M32C port and m32csim BSP. | |||
2008-10-01 | 2008-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
PR 1324/bsps * aclocal/check-bsps.m4: Revert Joel's icecube patch. | |||
2008-09-25 | 2008-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Recognize the the GDB SuperH simulator is just an architectural simulator and does not include devices. Rename existing simulator BSP configurations to simsh1 and simsh2 and add simsh4. | |||
2008-09-24 | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Joel Sherrill | |
PR 1324/bsps * aclocal/check-bsps.m4: Add missing icecube. | |||
2008-09-22 | 2008-09-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/version.m4: Bump RTEMS_API to 4.10. Bump _RTEMS_VERSION to 4.9.99.0. | |||
2008-09-22 | added BSP for ARM LPC24xx | Thomas Doerfler | |
2008-09-08 | added new BSP for powerpc/tqm8xx boards | Thomas Doerfler | |
2008-08-15 | 2008-08-15 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | |
* src/lib/libbsp/mips/jmr3904/tools/runtest: Add bf537Stamp. | |||
2008-07-27 | Require AC_DISABLE_OPTION_CHECKING. | Ralf Corsepius | |
AC_PREREQ(2.62). | |||
2008-07-27 | Remove doxygen comments. | Ralf Corsepius | |
2008-07-14 | updated gen83xx BSP | Thomas Doerfler | |
updated haleakala BSP added MPC55xx BSP | |||
2008-07-11 | added BSP to m68k | Thomas Doerfler | |
adapted PPC exception code | |||
2008-02-20 | s/AC_HELP/AS_HELP/. | Ralf Corsepius | |
2007-11-06 | 2007-11-06 Ray Xu <rayx.cn@gmail.com> | Joel Sherrill | |
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: | |||
2007-09-21 | 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0. | |||
2007-08-10 | added BSP hsc_cm01 | Thomas Doerfler | |
2007-08-07 | Upgrade to 4.7.99.2 | Joel Sherrill | |
2007-08-06 | 2007-08-06 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* README.configure, aclocal/bsp-alias.m4: Rename EP5200 to IceCube since that is the nickname for the Freescale evaluation board it is based upon. BSP was tested on a Freescale MPC5200LITE. | |||
2007-08-02 | 2007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* Makefile.maint, configure.ac, release_support: Remove RDBG. * aclocal/enable-rdbg.m4: Removed. | |||
2007-07-10 | compilable release of virtex/gen83xx/gen5200 powerpc adaptations. Merged ↵ | Thomas Doerfler | |
many different versions of new exception handling code to shared sources. | |||
2007-06-20 | 2007-06-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* aclocal/bsp-alias.m4, README.configure: Add ep5200, IceCube, 5200Lite. | |||
2007-05-15 | 2007-05-15 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* README.configure, aclocal/check-bsps.m4: Remove references to mbx860_1b since it is just an alternate name for the mbx860_001b. | |||
2007-05-11 | 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Per Jiri Gaisler remove unused erc32nfp and leon1 BSP variants. | |||
2007-03-13 | Upgrade to 4.7.99.1 | Joel Sherrill | |
