summaryrefslogtreecommitdiff
path: root/aclocal/enable-tests.m4 (unfollow)
AgeCommit message (Collapse)Author
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-05-07Revert: Remove CVS IdsJoel Sherrill
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details.
2012-05-04Remove CVS-Ids.Ralf Corsépius
2008-02-20s/AC_HELP/AS_HELP/.Ralf Corsepius
2003-11-262003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius
* aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4, aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4, aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rdbg.m4, aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4, aclocal/multilib.m4, aclocal/path-ksh.m4, aclocal/project-root.m4, aclocal/rtems-top.m4, aclocal/tool-paths.m4, acinclude.m4: Fix underquoting to silence automake-1.8.
2003-08-222003-08-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius
* aclocal/enable-rtems-debug.m4: New (Missed in yesterday's patches). * aclocal/enable-tests.m4: Change to support --enable-tests=no|yes|samples, default is samples.
2002-10-292002-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius
* aclocal/enable-bare.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-cxx.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-inlines.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-itron.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-multiprocessing.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-networking.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-posix.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-rdbg.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-rtemsbsp.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-tests.m4: Improve quoting of AC_HELP_STRING. (autoconf > 2.54 seems to have problems with the old form of quoting).
2001-09-132001-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill
* configure.in: autoupdate to autoconf-2.52. * bootstrap: Add handling for configure.ac, make autoheader verbose, fix auto*tool invocation order. * aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING. * aclocal/enable-bare.m4: Introduce AC_HELP_STRING. * aclocal/enable-cxx.m4: Introduce AC_HELP_STRING. * aclocal/enable-gcc28: Introduce AC_HELP_STRING. * aclocal/enable-inlines.m4: Introduce AC_HELP_STRING. * aclocal/enable-itron.m4: Introduce AC_HELP_STRING. * aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING. * aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING. * aclocal/enable-networking.m4: Introduce AC_HELP_STRING. * aclocal/enable-posix.m4: Introduce AC_HELP_STRING. * aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING. * aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING. * aclocal/enable-tests.m4: Introduce AC_HELP_STRING. * aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in RTEMS_CONFIG_PER_BSP conditional. * aclocal/multilib.m4: Introduce AC_HELP_STRING. * aclocal/rtems-debug.m4: Introduce AC_HELP_STRING. * aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
1999-04-12Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to correct theJoel Sherrill
--enable-tests problem a better way.
1999-04-06Eric Norum <eric@skatter.usask.ca> noticed that the documentation andJoel Sherrill
configure scripts did not match on the default value of --enable-tests.
1999-03-19Towards automake VIII patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill
OK, I 've made up my mind to cut a big chunk of my automake-patches (:-). Below you can find a drop-in replacement of the aclocal directory. It contains a lot of new macro files, most of them are directly cut from rtems top-level configure script, some are new some are identical to former versions. The motivation behind these files is to reuse parts from rtems current top-level configure.in script in up-coming subdirectory configure.in scripts. I'd like to ask you to untar the archive ontop of the source tree and to add/commit these files to CVS. Adding these files should not have any influence on RTEMS momentary configuration (except of you are required to run aclocal -I aclocal && autoconf afterwards), because most of them currently are not used at all. --------- BTW: Please upgrade to autoconf-2.13 and automake-2.4, if you havn't done this already (egcs/CVS require them, too). My upcoming automake files require automake-2.4 which requires autoconf-2.13 or later.
