2009-02-06 | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* Makefile.maint: rtems_api=4.10. | |||
* Makefile.maint: Dump stuff hanging around for much too long. | |||
2007-09-04 | 2007-09-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* Makefile.maint: touch all documentation master files so the date on the manual reflects the release date of the software. | |||
2007-08-07 | 2007-08-07 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* Makefile.maint: Add touching master files for various manuals so the date on the cover page will reflect the date a tarball is cut. | |||
2007-08-02 | 2007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* Makefile.maint, configure.ac, release_support: Remove RDBG. * aclocal/enable-rdbg.m4: Removed. | |||
2007-02-22 | Fix stupid typo | Ralf Corsepius | |
2007-02-22 | use cvs -q | Ralf Corsepius | |
2007-02-22 | Don't redirect output of make tag | Ralf Corsepius | |
2007-02-22 | Sync with rtems-4-7-branch. | Ralf Corsepius | |
2007-02-22 | Eliminate hard-coded PATHs. | Ralf Corsepius | |
Add rtems_api. Sort TOOL_VERSIONS. | |||
2007-02-22 | Rename TEST_TAG into TAG_SUFFIX. | Ralf Corsepius | |
2007-02-22 | Move TOOL_VERSIONS into tarball. | Ralf Corsepius | |
2007-02-22 | Preps for testing. | Ralf Corsepius | |
2007-02-22 | Simplify rpm -qa call | Ralf Corsepius | |
2007-02-21 | 2007-02-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* Makefile.maint: Added TOOL_VERSIONS stanza and fixed typo. | |||
2007-02-21 | Misc. hacks | Ralf Corsepius | |
2007-02-15 | 2007-02-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* Makefile.maint: Use VERSION as master source for version.m4's. | |||
2007-01-28 | 2007-01-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* Makefile.maint: Sync nomenclature with that being used in cpukit/score/include/rtems/system.h (major->minor, minor->revision). | |||
2007-01-27 | 2007-01-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* Makefile.maint: Remove references to cpukit/score/include/rtems/system.h. | |||
2007-01-27 | Add CVS_RUN. | Ralf Corsepius | |
2007-01-26 | Misc. updates. | Ralf Corsepius | |
2007-01-26 | New. | Ralf Corsepius | |
