PR 1378/filesystem
* libfs/src/imfs/deviceio.c: IMFS device lseek should return the
current offset.
PR 1391/bsps
* startup/spurious.c: Format was %d but had leading 0x.
PR 1376/filesystem
* libcsupport/include/rtems/libio.h, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_file.c, libfs/src/imfs/deviceio.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/memfile.c: lseek handlers should return off_t.
PR 1380/bsps
* include/bsp.h: Switch to English comments.
PR 1388/cpukit
* sp09/screen05.c, sp09/screen09.c, sp09/sp09.scn: Classic Semaphores
allow both priority inherit and ceiling attributes to be set on
semaphore create. These attributes are mutually exclusive and this
should be an error.
PR 1388/cpukit
* rtems/src/semcreate.c: Classic Semaphores allow both priority inherit
and ceiling attributes to be set on semaphore create. These
attributes are mutually exclusive and this should be an error.
PR 1387/doc
* user/intr.t: Add Interrupt Manager services to list of services
callable from ISR.
* custom/uC5282.cfg: Add cvs Id.
PR 1359/cpukit
* libcsupport/src/libio.c: rtems_libio_allocate:
rtems_libio_iop_freelist incorrectly zeroed on semaphore error. Now
checks error and does not modify anything until sure it has created
semaphore.
PR 1363/filesystem
* libfs/src/dosfs/fat.h: Fix issue where 32 bit values are not written
correctly in FAT f/s data.
PR 1364/cpukit
* libcsupport/src/gxx_wrappers.c: Fix compilation problems when
diagnostics enabled.
Joel Sherrill <joel.sherrill@oarcorp.com>
PR 1357/cpukit
* rtems/src/tasks.c: Ensure creating a task with no ASR is honored.
PR 1354/bsps
* network/network.c: In some cases it can occur that an empty mbuf is
put on the descriptor chain. (We found it especially then when
transmitting fragmented IP Packets.) Since the actual buffer
descriptor pointer will be incremented after every inserted mbuf
(txBd = sc->txBdBase + sc->txBdHead;) even if m->m_len of the current
mbuf was zero. This leads to the bug.
PR 1350/bsps
* network/lan91c11x.c: Do not write 65th element into 64 element array.
* user/region.t: Malloc Family is not implemented in termios of Region
Manager after 4.7. Correct documentation.
PR 1348/cpukit
* Makefile.am, configure.ac: Add test of special case of resetting cpu
usage information while a period is running.
* sp46/.cvsignore, sp46/Makefile.am, sp46/init.c, sp46/sp46.doc: New files.
PR 1348/cpukit
* rtems/src/ratemonperiod.c: Properly handle period statistics after
cpu usage information is reset while a period is running.
* user/concepts.t: Id has four parts not three.
PR 1337/bsps
* custom/pc386.cfg: Stripping .rodata section produces unusable
executables for the i386-rtems target.
* user/concepts.t: Use 32 bit version centered.
* ada_user/Makefile.am, user/Makefile.am: Make C and Ada manual build
again after adding figure.
PR 1332: call BSP_uart_termios_set()/BSP_uart_intr_ctrl()
only from 'firstOpen' and only if this is a serial console.
PR 1334/doc
* user/Makefile.am, user/concepts.t, user/overview.t, user/part.t,
user/task.t: Correct typos and correctly document 4 parts of 32-bit
object id.
* user/ObjectId-32Bits.eps, user/ObjectId-32Bits.png: New files.
PR 1333/cpukit
* libcsupport/include/rtems/termiostypes.h: Typo on type name -- should
be rtems_device_minor_number.
PR 1330/cpukit
* libcsupport/src/malloc.c: Should print begin field not start field.
PR 1316/cpukit
* score/src/coremsgbroadcast.c: Give error when message is too large
like when sending a message. This was the documented behavior.
PR 1324/bsps
* aclocal/check-bsps.m4: Add missing icecube.
PR 564/cpukit
* sapi/include/confdefs.h: Fix incorrect name. Was missed in an earlier
renaming sweep.
Backport arm-endianness hack from rtems-4.10.
PR 1301/cpukit
* sapi/src/debug.c: Let _Debug_Is_enabled return TRUE|FALSE.
* libnetworking/netinet/tcp_var.h: Fix broken declaration of
tcp_trace().
* user/clock.t: Correct discussion of timeval.
PR 500/misc
* libcsupport/src/termios.c: Avoid potential buffer overflow.
PR 1297/cpukit
* psxrwlock01/psxrwlock01.scn, psxrwlock01/test.c: Fix NULL attribute
pointer handling.
