2012-02-17 | Remove (Obsolete).4.8 | Ralf Corsépius | |
2012-02-17 | Remove (Moved to git.rtems.org/data/git/rtems-crossrpms.git). | Ralf Corsépius | |
2011-01-21 | 2011-01-21 Eric Norum <wenorum@lbl.gov> | Joel Sherrill | |
* libmisc/capture/capture.c: Avoid using TCB of task just deleted. | |||
2010-12-16 | 2010-12-16 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | |
* SUPPORT: Update address. | |||
2010-11-16 | 2010-11-16 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | |
PR 1718/cpukit * sapi/include/confdefs.h: POSIX threads are allocated twice the minimum stack space by default. confdefs.h only accounts for one minimum -- not the 2x factor. | |||
PR 1717/cpukit * libcsupport/src/gxx_wrappers.c: Free memory on error. | |||
2010-11-11 | 2010-11-11 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | |
PR 1716/doc * user/concepts.t: print_name example used a variable which did not match the name of the passed in parameter. | |||
2010-11-01 | 2010-11-01 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | |
PR 1714/doc * user/datatypes.t, user/part.t: Add missing description of rtems_status_codes. | |||
2010-10-01 | 2010-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
PR 1708/build: * aclocal/check-cpuopts.m4: Fix m4-quoting. | |||
2010-09-23 | 2010-09-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* aclocal/check-cpuopts.m4: Add AC_LANG_SOURCE. | |||
2010-08-27 | 2010-08-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | |
PR 1693/filesystem * libfs/src/imfs/memfile.c: IMFS_memfile_get_block_pointer() was checking incorrect pointer and thus had dead code. | |||
PR 1692/filesystem * libcsupport/include/rtems/libio.h, libfs/src/imfs/imfs_eval.c: Fix implementation and use of rtems_libio_is_valid_perms(). | |||
2010-06-21 | 2010-06-21 Peter Dufault <dufault@hda.com> | Joel Sherrill | |
PR 1570/cpukit * posix/src/semtimedwait.c: This routine is supposed to return -1/errno NOT the status directly. | |||
2010-03-18 | Upgrade to 4.8.24.8.2 | Joel Sherrill | |
2010-03-18 | 2010-03-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
PR 1497/bsps * startup/bspclean.c: Do not enable interrupts while waiting for board to reset. | |||
2010-03-11 | Remove. | Ralf Corsepius | |
2010-01-11 | Sync with CVS-HEAD. | Ralf Corsepius | |
2010-01-11 | Bump version. | Ralf Corsepius | |
2010-01-11 | Fix oversight. | Ralf Corsepius | |
2010-01-11 | Set default osname to centos5. | Ralf Corsepius | |
Remove fedora. | |||
2010-01-11 | Add rtems-4.8-release. | Ralf Corsepius | |
2010-01-11 | Add INSTALL | Ralf Corsepius | |
2010-01-11 | Remove (Bogusly checked in into CVS) | Ralf Corsepius | |
2009-12-10 | 2009-12-10 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
PR 1482 * posix/src/ptimer1.c: Exit dispatching critical section. | |||
2009-09-15 | 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
PR 1441/cpukit * libcsupport/src/tcgetprgrp.c: Remove. * libcsupport/src/tcgetpgrp.c: New (Renamed from libcsupport/src/tcgetprgrp.c). * libcsupport/Makefile.am: Add libcsupport/src/tcgetpgrp.c. Remove libcsupport/src/tcgetprgrp.c. | |||
2009-09-15 | This commit was manufactured by cvs2svn to create branch 'rtems-4-8-branch'. | cvs2git | |
Cherrypick from master 2009-09-15 05:32:49 UTC Ralf Corsepius <ralf.corsepius@rtems.org> '2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org>': cpukit/libcsupport/src/tcgetpgrp.c | |||
2009-09-09 | 2009-09-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* sp46/init.c: Make compile on 4.8 branch. * sp46/sp46.scn: New file. | |||
2009-07-26 | Sync with rtems-4.9. | Ralf Corsepius | |
2009-07-26 | Update. | Ralf Corsepius | |
2009-07-24 | Remove. | Ralf Corsepius | |
2009-07-24 | New. | Ralf Corsepius | |
2009-07-24 | Regenerate. | Ralf Corsepius | |
2009-07-24 | Update. | Ralf Corsepius | |
2009-07-24 | Bump GDB_RPMREL. | Ralf Corsepius | |
2009-07-24 | Minor fixes. | Ralf Corsepius | |
2009-07-23 | Remove. | Ralf Corsepius | |
2009-07-23 | Sync. with rtems-4.10. | Ralf Corsepius | |
2009-07-21 | Regenerate. | Ralf Corsepius | |
2009-07-21 | Bump *_RPMREL. | Ralf Corsepius | |
2009-07-21 | Sync with rtems-4.10. | Ralf Corsepius | |
2009-07-21 | Abandon mingw32, cygwin. | Ralf Corsepius | |
2009-07-21 | Remove. | Ralf Corsepius | |
