- Add python as a unit test variant.
- Add support to run the unit tests for the rtemstoolkit python
modules from waf. Enter './waf test' for the tests to be run on
python2 and python3.
- Update the importing of rtemstoolkit modules to the standard
method which works on python2 and python3.
- Update the README.
Closes #3536
Update #3461.
Corresponding RTEMS commit is 75933d5d25cd50f80162b7a0d2f66a5534e1763f.
Update #3380.
Update #3220.
Limit the compilers used to gcc and clang. Clang has not been tested.
Users with MSVC install does not need to remove now.
Force the os.sep path to the standard '\\' on Windows. The MSYS2 python
sets it to '/' for internal project reasons. Doing this does cause waf
problems when running configure so only do this for the build target.
Closes #2583.
Installing PYO and PYC does not work so disable this. Move the
Python check to the top level and have a single place.
Fix the install paths a revert the 'from . import' changes. This
is resolved by installing into the correct paths.
One section is supported [version] with a 'release' entry.
Support a top level VERSION file that defines an RTEMS release.
Fix the install of the python modules including thertems-test.
Update the git python module to the RSB version. Fix the options to
not call clean and to call dirty.
Update the version python module.
Fix the rtld C++ support to the VERSION file and the top level waf
script.
Fix biulding the mmap Windows code.
Fix installing the files for Windows.
On FreeBSD use --host=mingw32 for Windows. If you use another
OS you might need to add the specific windows host to the
top level wscript file.
Add support to build all parts of The RTEMS Tools project.
