2019-06-05 | Add patch used by RTEMS 6 epiphany GDB on FreeBSD | Sebastian Huber | |
2019-02-19 | Add patch used by RTEMS 5 epiphany GDB on FreeBSD | Sebastian Huber | |
2018-12-19 | 4.9/gcc/gcc-core-4.3.2-rtems4.9-20181217.diff: New file | Joel Sherrill | |
Enable 4.9 tools to build with a modern makeinfo. Tested on CentOS 7. Added like other 4.9 tool patches. | |||
2017-11-13 | Add tool patches warning | Sebastian Huber | |
Update #2949. | |||
2017-11-10 | Remove tools/5 patches | Sebastian Huber | |
Update #3220. | |||
2017-11-09 | Add tools/5 patches | Sebastian Huber | |
Update #3220. | |||
2017-11-09 | Add tools/5 patch | Sebastian Huber | |
Update #3220. | |||
Update #3220. | |||
Update #3220. | |||
Update #3220. | |||
Update #3220. | |||
2017-07-10 | Add Newlib patch | Sebastian Huber | |
Original patch contains a Cygwin part which is not present in the Newlib snapshot archive. | |||
2017-06-12 | Add PR-ada-81070.diff | Sebastian Huber | |
2017-03-21 | patch: ARM: Fix IEEE-754 sqrt optimization | Sebastian Huber | |
Update #2948. | |||
2017-03-21 | patch: ARM: Optimize IEEE-754 sqrt implementation | Sebastian Huber | |
Update #2948. | |||
2016-12-23 | Add Newlib patch for RTEMS 4.12 | Sebastian Huber | |
2016-11-14 | Add 4.12/.../gdb-7.11-sis-leon2-leon3.diff from gaisler.org | Joel Sherrill | |
2016-11-14 | Add 4.12/.../binutils-2.26-gas-reloc.patch from gaisler.org | Joel Sherrill | |
2016-09-02 | 4.10: Add NIOS2 newlib patch. | Chris Johns | |
2016-09-02 | 4.10: Add NIOS2 gcc patch. | Chris Johns | |
2016-09-02 | 4.10: Add NIOS2 binutils patch. | Chris Johns | |
2016-09-02 | 4.10: Add FreeBSD Python patch. | Chris Johns | |
2016-09-02 | 4.10: Add the gdb-7.11 ERC patches to 4.10. | Chris Johns | |
2016-09-02 | 4.10: Add the automake patch to the 4.10 patches. | Chris Johns | |
2016-03-16 | 4.12: Patches for ERC simualtor for gdb-7.11. | Chris Johns | |
The patches fix the endian checks in the simulator, print filtering, and the run command. Updates #2644. | |||
2016-03-11 | Add a gdb-7.11 patch for 4.12. | Chris Johns | |
2016-03-10 | Bugfix: gdb-7.3.1 couldn't be build with a modern texinfo package. | Götz Pfeiffer | |
The texinfo documentation of binutils contained some constructs that are errors, at least for a modern version of texinfo (version 6.0 and newer). This meant that gdb-7.3.1 couldn't be build e.g. on fedora-22. A patch file was added to fix the problematic parts of the documentation. Close #2520. | |||
2016-03-10 | Bugfix: gcc-4.4.7 couldn't be build with a modern texinfo package. | Götz Pfeiffer | |
The texinfo documentation of binutils contained some constructs that are errors, at least for a modern version of texinfo (version 6.0 and newer). This meant that gcc-4.4.7 couldn't be build e.g. on fedora-22. A patch file was added to fix the problematic parts of the documentation. Update #2520. | |||
2016-03-10 | Bugfix: binutils-2.20.1 couldn't be build with a modern texinfo package. | Götz Pfeiffer | |
The texinfo documentation of binutils contained some constructs that are errors, at least for a modern version of texinfo (version 6.0 and newer). This meant that binutils-2.20.1 couldn't be build e.g. on fedora-22. A patch file was added to fix the problematic parts of the documentation. Update #2520. | |||
2016-02-29 | Add aarch64 and x86_64 binutils and gdb patches. | Chris Johns | |
2016-02-29 | Fix ithe automake warning with newer perl versions. | Chris Johns | |
This patch is based on this post .. https://lists.gnu.org/archive/html/automake-patches/2015-07/msg00000.html This warnign appears with a recent MSYS2. Update #2616. | |||
2016-02-19 | Add Windows specific waf support for MSYS2. | Chris Johns | |
Limit the compilers used to gcc and clang. Clang has not been tested. Users with MSVC install does not need to remove now. Force the os.sep path to the standard '\\' on Windows. The MSYS2 python sets it to '/' for internal project reasons. Doing this does cause waf problems when running configure so only do this for the build target. Closes #2583. | |||
2016-02-19 | Disable installing PYO and PYC. Fix install paths. | Chris Johns | |
Installing PYO and PYC does not work so disable this. Move the Python check to the top level and have a single place. Fix the install paths a revert the 'from . import' changes. This is resolved by installing into the correct paths. | |||
2015-11-12 | Python 3 compatibility | Sebastian Huber | |
2015-11-12 | Add tools patches for RTEMS 4.12. | Chris Johns | |
2015-08-11 | add microwindows patches | YANG Qiao | |
2015-04-03 | Add QEMU patch for openrisc to recognize halt signals | Hesham ALMatary | |
2015-04-02 | Update gdb-sim-lm32uart.diff to gdb-7.9 | Joel Sherrill | |
2015-03-27 | Add Jiri Gaisler SIS patch set for gdb 7.9 | Joel Sherrill | |
This patch set adds a lot of new capability including support for the leon2 and leon3. It also eliminates the difference between the initial state of the simulated erc32 and the real hardware. | |||
2015-03-17 | gdb/python: Update the support to a recent RTEMS. | Chris Johns | |
2015-02-25 | Modified waf scripts to have a minimum python version requirement of 2.6.6, ↵ | Adit Sahasrabudhe | |
instead of 2.7.3 | |||
2015-02-08 | Install the rtems-test command. | Chris Johns | |
This installs the Python RTEMS Toolkit. The copmiler has been switched from forcing gcc to allowing waf to detect the host's tool chain. | |||
2015-01-09 | Add PowerPC patches for GCC 4.9.2 | Sebastian Huber | |
2014-12-04 | Add SPARC patches for GCC 4.9.2 | Sebastian Huber | |
These patches are already present in the GCC 4.9 branch and will be available with GCC 4.9.3. | |||
2014-12-04 | gdb patch to add leon2/3 support to sis | Jiri Gaisler | |
This fixes the commit 4bdba3e552f22bbd82ffc9ab2c915a7b4f2eadd5 which added a patch patch. | |||
2014-12-02 | tools/gdb: Add a patch for gdb-7.7/gdb-7.8 SPARC. | Chris Johns | |
This patch updates and merges the previous SPARC patches as well as providing update LEON2/LEON3 support in the SIS simulator. | |||
2014-09-13 | waf: Include waf in the souce tree and updated README on building. | Chris Johns | |
Add support to build all parts of The RTEMS Tools project. | |||
2014-08-26 | gdb-python: Update so 'rtems task' lists the classic tasks. | Chris Johns | |
This is a first pass at cleaning up the support. To use: $ waf configure --prefix=$HOME/development/rtems/4.11 $ waf build install Start GDB and break at Init: (gdb) py import rtems (gdb) rtems task will list the classic API tasks. | |||
2014-08-25 | gdb-python: Add waf script to install under a prefix. | Chris Johns | |
2014-08-25 | gdb-python: Clean up and ignore waf generated files. | Chris Johns | |
