instead of 2.7.3
This installs the Python RTEMS Toolkit.
The copmiler has been switched from forcing gcc to allowing waf
to detect the host's tool chain.
Add support to build all parts of The RTEMS Tools project.
Use waf to build covoar.
Add support to kill running tests if the user presses control-c.
. parameter is a glob
. default is *.exe as it was
. it is a convenient way to select a particular test to run over and
over again while debugging it, without laboriously manipulating the
.exe's that are present (i.e. moving/deleting them)
