2018-11-23 | rtemstoolkit: Add unit testing for the python modules | Chris Johns | |
- Add support to run the unit tests for the rtemstoolkit python modules from waf. Enter './waf test' for the tests to be run on python2 and python3. - Update the importing of rtemstoolkit modules to the standard method which works on python2 and python3. - Update the README. | |||
2017-04-25 | rtemstoolkit: Move host support access into a separate module. | Chris Johns | |
Moving the host support into a module lets it get used where options is not being used. | |||
2016-03-03 | Update rtems-tool to support Python 2 and 3. | Chris Johns | |
Add solaris and netbsd. Close #2619. | |||
2015-02-08 | Fixes to the run the waf built tests when installed. | Chris Johns | |
2014-02-15 | rt: Add the rtems-tester. | Chris Johns | |
