These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
PR 1589/build
* leaf.cfg, Templates/Makefile.leaf: Remove obsolete optional manager
capability.
* host.cfg.in: Remove (Unused).
* custom/default.cfg: Update to account for movement of .cfg files.
* Makefile.am: Remove (merged into ../Makefile.am).
* compilers/gcc-target-default.cfg: Remove (Unused).
* Makefile.am: Reflect change above.
* compilers/gcc-no_bsp.cfg: Remove (Unused).
PR 1532/testing
* host.cfg.in: Add initial tests for untar capabilities.
* custom/bare.cfg: Remove (Abandoned).
* Makefile.am: Remove custom/bare.cfg.
* Makefile.am: Remove custom/no_bsp.cfg.
* custom/no_bsp.cfg:
Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* Makefile.am: Reflect custom/*.cfg having moved.
* custom/av5282.cfg, custom/csb360.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360_040.cfg, custom/gen68360.cfg,
custom/pgh360.cfg, custom/genmcf548x.cfg,
custom/m5484FireEngine.cfg, custom/idp.cfg, custom/mcf5206elite.cfg,
custom/mcf52235.cfg, custom/mcf5235.cfg, custom/mcf5329.cfg,
custom/mrm332.cfg, custom/mvme136.cfg, custom/mvme147.cfg,
custom/mvme147s.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg,
custom/mvme167.cfg, custom/ods68302.cfg, custom/sim68000.cfg,
custom/simcpu32.cfg, custom/uC5282.cfg:
* custom/csb336.cfg, custom/csb337.cfg, custom/csb637.cfg,
custom/edb7312.cfg, custom/gba.cfg, custom/arm1136jfs.cfg,
custom/arm1136js.cfg, custom/arm7tdmi.cfg, custom/arm920.cfg,
custom/armcortexa9.cfg, custom/gp32.cfg, custom/gumstix.cfg,
custom/lpc24xx.cfg, custom/lpc24xx_ea.cfg,
custom/lpc24xx_ncs_ram.cfg, custom/lpc24xx_ncs_rom_ext.cfg,
custom/lpc24xx_ncs_rom_int.cfg, custom/nds.cfg,
custom/rtl22xx.cfg, custom/rtl22xx_t.cfg,
custom/smdk2410.cfg:
* custom/csb350.cfg, custom/genmongoosev.cfg,
custom/hurricane.cfg, custom/jmr3904.cfg, custom/rbtx4925.cfg
custom/rbtx4938.cfg:
* custom/m32csim.cfg:
* custom/m32rsim.cfg:
* custom/lm32_evr.cfg:
* custom/icecube.cfg, custom/pm520_cr825.cfg, pm520_ze30.cfg:
* custom/hsc_cm01.cfg, custom/mpc8313erdb.cfg,
custom/mpc8349eamds.cfg:
* custom/bf537Stamp.cfg, custom/eZKit533.cfg:
* custom/brs5l.cfg:
* custom/h8sim.cfg, custom/h8sxsim.cfg:
* custom/c3xsim.cfg, custom/c4xsim.cfg:
* custom/pghplus.cfg:
* custom/ep1a.cfg, custom/gen5200.cfg, custom/gen83xx.cfg,
custom/haleakala.cfg, custom/mbx821_001.cfg,
custom/mbx821_002.cfg, custom/mbx821_002b.cfg,
custom/mbx860_001b.cfg, custom/mbx860_002.cfg,
custom/mbx860_005b.cfg, custom/mbx860_1b.cfg,
custom/mbx8xx.cfg, custom/mcp750.cfg, custom/mpc5566evb.cfg,
custom/mpc55xx.cfg, custom/mpc8260ads.cfg, custom/mtx603e.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg,
custom/mvme5500.cfg, custom/psim.cfg, custom/qemuppc.cfg,
custom/score603e.cfg, custom/ss555.cfg, custom/tqm8xx.cfg,
custom/tqm8xx_stk8xx.cfg, custom/virtex.cfg:
* custom/nios2_iss.cfg:
* custom/leon3.cfg, custom/leon2.cfg, custom/sis.cfg,
custom/erc32.cfg:
* custom/avrtest.cfg:
* custom/i386ex.cfg, custom/pc486.cfg, custom/ts_386ex.cfg,
custom/pc386.cfg, custom/pc586.cfg, custom/pc386dx.cfg,
custom/pc686.cfg:
* custom/gensh1.cfg, custom/gensh2.cfg, custom/gensh4.cfg,
custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh2e.cfg,
custom/simsh4.cfg:
* custom/Cygwin-posix.cfg, custom/FreeBSD-posix.cfg,
custom/Linux-posix.cfg, custom/Solaris-posix.cfg, custom/posix.cfg:
Remove.
