summaryrefslogtreecommitdiff
path: root/README (unfollow)
AgeCommit message (Collapse)Author
2020-04-27README: Fix the rtems.git lineChris Johns
Updates #3231
2018-04-11Updated README.Chris Johns
2015-05-21Top files: Update and prep for release branchJoel Sherrill
2015-05-14README:XXXJoel Sherrill
2013-04-23README: Update README and INSTALL to try to be GNU'ish.Gedare Bloom
2013-04-23README: Rewrite and reduceGedare Bloom
Delete old bit-rotting README files and rewrite the README to point readers toward authoritative sources of documentation.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2000-09-012000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill
* LICENSE.NET, README, README.configure: Spelling corrections.
1997-04-25Updated to point to README.configure for build instructions.Joel Sherrill
