2013-03-19 | Merge official 4.10.2 sources into rcc-1.2 branchrcc-v1.2.9 | Daniel Hellstrom | |
2013-03-18 | PCI-RASTA: set GRPCI1 target cache-line-size to avoid poor performancercc-v1.2.8 | Daniel Hellstrom | |
2013-03-14 | GRETH: cleaned up parts of PHY init code | Daniel Hellstrom | |
2013-03-14 | GRETH: changed the PHY initialization sequence | Daniel Hellstrom | |
1. read_mii() now returns 0xffff on failure. It is more robust when it comes to reading the reset bit in the control register, that is the first access. 2. write_mii() now has error printout like read_mii(). 3. Additional (optional) PHY access debugging is now available by enabling GRETH_DEBUG_MII. Even successful accesses are printed. 4. Let PHY do power-down (not only reset) to get in a good state, this is just in case the PHY input pin settings are sampled only on PHY power-up on some PHYs. 5. PHY GBit advertisement is disabled if Gbit is not supported by MAC. Or forced if supported. 6. Auto-nego is started if supported by PHY, before it was started only if default set by PHY. 7. Reset Sequence updated: * one must wait until reset bit is self-cleared. * the DD (Disable Duplex Detection) bit is set, only affects EDCL capable devices. This lets RTEMS handle PHY initialization | |||
2013-03-12 | GRETH: forcing autonegotiation during PHY initialization | Daniel Hellstrom | |
Looking at PHY Ctrl register without reseting it will give back old register content, that is not stable. Instead the PHY is reset and the autonogotiation capability is read out and started if present. | |||
2013-03-12 | GRETH: updated worker Deamon thread name | Daniel Hellstrom | |
The name was probably copied from the DEC21140 driver | |||
2013-03-06 | GRPCI: initialize cache-line-size and latency timer | Daniel Hellstrom | |
In some GRPCI cores not setting the cache line size could result in long prefetches on the AMBA bus which would lead to bad performance when doing PCI reads to GRPCI target interface (DMA). Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | |||
2013-03-06 | GR1553BC: fix memory leak when closing BC driver | Daniel Hellstrom | |
2013-01-18 | GRSPW: fixed SET_RMAPEN and SET_RMAPBUFDIS | Daniel Hellstrom | |
Both ioctl commands destroyed the control register by writing the content of the status register into it. | |||
2012-11-19 | GPTIMER: support separate & shared irq by clearing pending bit after ISRrcc-v1.2.7 | Daniel Hellstrom | |
2012-11-19 | SPW_BUS: Cannot verify when writing 3 bytes is not allowed | Arvid Bjorkengren | |
2012-11-19 | GPTIMER: Only probe pending bit on timer0 | Daniel Hellstrom | |
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: Arvid Bjorkengren <arvid@gaisler.com> | |||
2012-11-19 | RMAP: Removed a compile warning. | Arvid Bjorkengren | |
2012-10-08 | DRVMGR/SPW_BUS: Don't add index to virq, probably a copy/paste error.rcc-v1.2.6 | Arvid Bjorkengren | |
2012-10-08 | DRVMGR/SPW_BUS: Mask instead of unregister interrupt from SpW ISR | Arvid Bjorkengren | |
... when temporarily disabling IRQ from the ISR (and corresponding for enable) This is because low-level routines will return RTEMS_CALLED_FROM_ISR when unregister is called from an ISR. Implement SPW-BUS IRQ mask/unmask functions and bug fix interrupt register/unregister functions. | |||
2012-10-08 | DRVMGR/SPW_BUS: ISR now has a correct prototype | Arvid Bjorkengren | |
2012-10-08 | AMBAPP_BUS_RMAP: Check mask when handling interrupts. | Arvid Bjorkengren | |
2012-10-08 | AMBAPP_BUS_RMAP: IRQ is now enabled properly when registered | Arvid Bjorkengren | |
2012-10-08 | RMAP: Make sure buffers are 64-bit aligned to improve odds of getting a fast ↵ | Arvid Bjorkengren | |
memcpy-operation. | |||
2012-10-08 | DRVMGR: Fix to stop optimization from generating broken code. | Arvid Bjorkengren | |
drvmgr_func_call() caused NULL pointer exception | |||
2012-07-06 | GRSPW_PKT: the PKT_FLAG_ bit-mask is only 16-bit, fixed translation flagsrcc-v1.2.5 | Daniel Hellstrom | |
2012-06-19 | APBUART: fix GRMON -u support for older UARTsrcc-v1.2.4 | Daniel Hellstrom | |
2012-06-19 | GRSPW: New packet based driver for SPW/SPW2/SPW2_DMA | Daniel Hellstrom | |
This patch adds a new driver for the GRSPW SpaceWire AMBA interface family. The new driver does not implement a standard RTEMS driver, instead it provides only a library interface to the GRSPW devices. This driver can be used to implement a RTEMS I/O driver or used directly. New features compared with old GRSPW driver: * zero-copy packet interface * possibility to send/receive mulitple packets per call * optional interrupt awaken work-task to process TX/RX queues * DMA channels support. Before only first DMA channel supported * Separate DMA and link control * Packet based error flags Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | |||
2012-06-19 | LEON3: fixed nano seconds support in TLIB | Daniel Hellstrom | |
The _Watchdog_Nanoseconds_since_tick_handler() function caller does not take into account that the timer counter may wrap, underflow or overflow. Instead, the driver must take that into account. This GPTIMER DrvMgr driver patch makes use of the IRQ-Pending bit to determine if a underflow has happened. In that case a greater time than one tick is returned (even considering the function name..). The TLIB clock layer must also ACK the interrupt pending bit, otherwise we couldn't determine whether an IRQ is pending or if belongs to un old already handled tick IRQ. Note that this patch only fixes the DrvMgr GPTIMER driver and TLIB, the standard LEON3 GPTIMER driver still needs a fix. Reported-by: Rolf Schroedter <rolf.schroedter@dlr.de> Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | |||
2012-05-24 | GRTM: fixed bug where transmitter start loop was optimized awayrcc-v1.2.3 | Daniel Hellstrom | |
2012-05-16 | GRPCI: fix target BAR1 initialization | Daniel Hellstrom | |
2012-04-05 | LEON APBUART: bad formula for scaler to baudrate conversion | Daniel Hellstrom | |
2012-03-27 | DRVMGR: insert_dev_into_bus depends on dev->drv, init earlierrcc-v1.2.2 | Daniel Hellstrom | |
2012-03-27 | GRETH-DRVMGR: moved the MEM-load (force-cache-miss) logic to BSP | Daniel Hellstrom | |
2012-03-27 | GRETH: moved the MEM-load (force-cache-miss) logic to BSP | Daniel Hellstrom | |
2012-03-27 | GRETH-DRVMGR: removed the use of rtems_set_clock() in auto-nego timeout | Daniel Hellstrom | |
2012-03-27 | GRETH: removed the use of rtems_set_clock() in auto-nego timeout | Daniel Hellstrom | |
2012-03-27 | ambapp_{grlib,leon2}_init1: config->bus_type not initialized. | Magnus Hjorth | |
2012-03-27 | b1553rt.c: rt_init: Preserve rtaddr and rtpar fields on init. | Magnus Hjorth | |
2012-03-27 | LEON2: added PCIF driver againrcc-v1.2.1 | Daniel Hellstrom | |
PCIF driver was accidentaly removed by commit b96029546014ab1b3da33b7e3917bc9d3d0d5453. | |||
2012-03-27 | LEON3: fixed GRETH conflict in Makefile.am no. 2 | Daniel Hellstrom | |
2012-03-27 | LEON3: fixed GRETH conflict in Makefile.am | Daniel Hellstrom | |
2012-03-27 | LEON3: fix CONSOLE_MAX in cons.c, build error | Daniel Hellstrom | |
2012-03-27 | LEON: renamed GPIO register names, fixed double definitions | Daniel Hellstrom | |
2012-03-27 | DRVMGR: Fix drvmgr_for_each_dev breadth-first search bug | Daniel Hellstrom | |
2012-03-27 | b1553rt: Workaround for reset mode command issue | Magnus Hjorth | |
The B1553RT wrapper has been designed so that when a reset remote terminal mode code is recieved, the whole wrapper is reset including the RT address and IRQ mask. Fortunately, the IRQ is delivered before this happens, so we can detect this in the driver and restore the control register contents. | |||
2012-03-27 | LEON3: fix conversion miss when struct gptimer was introduced | Daniel Hellstrom | |
2012-03-27 | LEON2: SMC9111 IRQ setup fix, shared-IRQ conversion miss | Daniel Hellstrom | |
2012-03-27 | DRVMGR: fix TOPO printout compile warning | Daniel Hellstrom | |
2012-03-27 | DRVMGR: fix bug in drvmgr_for_each_dev_breadth | Daniel Hellstrom | |
2012-03-27 | DRVMGR: Added missing string.h include | Daniel Hellstrom | |
2012-03-27 | DRVMGR: removed faulty lock handling | Daniel Hellstrom | |
2012-03-27 | pci_bus.c: minor cleanup | Daniel Hellstrom | |
2012-03-27 | SPARC: Removed unused file shared/bspstart.c | Daniel Hellstrom | |
2012-03-27 | LEON: Cleaned up Makefile.am and preinstall.am to match clean branch | Daniel Hellstrom | |
Added libchip/network/greth.c GRETH driver initialization to BSP again (leon3/leon_greth/). |
