2018-01-23 | linux/of.h: Add of_find_node_by_path() | Sebastian Huber | |
Update #3277. | |||
2018-01-23 | linux/of.h: Add of_read_number() | Sebastian Huber | |
Update #3277. | |||
2018-01-23 | linux/of.h: Add of_n_size_cells() | Sebastian Huber | |
Update #3277. | |||
2018-01-23 | linux/of.h: Add of_n_addr_cells() | Sebastian Huber | |
Update #3277. | |||
2018-01-23 | linux/sort.h: New file | Sebastian Huber | |
Update #3277. | |||
2018-01-23 | linux/smp.h: Avoid function call overhead | Sebastian Huber | |
Update #3277. | |||
2018-01-23 | linux/compiler.h: Define __cold | Sebastian Huber | |
Update #3277. | |||
2018-01-23 | Add rtems_bsd_ifconfig() | Sebastian Huber | |
2018-01-19 | ehci_mpc83xx.c: Fix for qoriq hypervisor guest | Sebastian Huber | |
2017-12-05 | Add rtems_bsd_initialize_dhcp() | Sebastian Huber | |
2017-11-17 | Revert "RWLOCK(9): Add reader/writer lock implementation" | Sebastian Huber | |
This was accidentally committed. This reverts commit 97a98f6cd767b3a68279890488c7b451788f84f4. | |||
2017-11-17 | Revert "SX(9): Implement with reader/writer lock" | Sebastian Huber | |
This was accidentally committed. This reverts commit cc7a8d87e7307db738bf39ab1ca3ce1053f1c163. | |||
2017-11-16 | SX(9): Implement with reader/writer lock | Sebastian Huber | |
2017-11-16 | RWLOCK(9): Add reader/writer lock implementation | Sebastian Huber | |
2017-11-16 | LOCKING(9): Remove dead code (DDB) | Sebastian Huber | |
2017-11-16 | LOCKING(9): Remove dead code (KDTRACE_HOOKS) | Sebastian Huber | |
2017-11-16 | LOCKING(9): Update to current FreeBSD version | Sebastian Huber | |
2017-11-10 | at91_mci: Port to RTEMS and adapt for atsam. | Christian Mauderer | |
2017-11-10 | saf1761_otg: Port to RTEMS. | Christian Mauderer | |
2017-11-10 | wpa_supplicant: Add lock. | Christian Mauderer | |
2017-11-10 | wpa_supplicant: Move forking command into own file. | Christian Mauderer | |
The malloc wrapper must not be disabled. Therefore the command that uses malloc without a wrapper has to live in another file. | |||
2017-11-10 | Add wpa_supplicant_fork command. | Sichen Zhao | |
Add fork command for wpa supplicant to start a new task. | |||
2017-11-10 | Port wpa supplicant to RTEMS. | Sichen Zhao | |
Add wpa_supplicant lib support and shell command support in RTEMS. | |||
2017-11-10 | Port BBB sd driver files to RTEMS. | Sichen Zhao | |
So BBB can mount and read eMMC and SD card. | |||
2017-11-10 | Add rtems_bsd_ifconfig_lo0() | Sebastian Huber | |
2017-10-26 | Fix general PowerPC build | Sebastian Huber | |
2017-10-24 | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | |
Update #3117. | |||
2017-10-23 | dpaa: Use only one FMan MAC SGT zone | Sebastian Huber | |
2017-10-23 | dpaa: Add "libbsd,dedicated-portal" to QMan portals | Sebastian Huber | |
By default, the network interfaces use a pool channel, see dpaa_get_channel() in dpaa_eth_priv_probe(). To enable a dedicated QMan software portal, use libbsd,dedicated-portal = "enabled";. This option is useful for special purpose 10Gbit/s Ethernet processing. / { soc: soc@ffe000000 { fman0: fman@400000 { enet7: ethernet@f2000 { libbsd,dedicated-portal = "enabled"; }; }; }; }; | |||
2017-10-23 | dpaa: Add <soc/fsl/dpaa.h> | Sebastian Huber | |
2017-10-23 | linux: Move upper_32_bits() and lower_32_bits() | Sebastian Huber | |
2017-10-23 | linux: Make Linux types available in user-space | Sebastian Huber | |
2017-10-23 | linux: Include missing <sys/errno.h> | Sebastian Huber | |
2017-10-23 | Add rtems_bsd_set_if_input() | Sebastian Huber | |
2017-10-23 | dpaa: Get c45 ids | Sebastian Huber | |
2017-10-23 | dpaa: No error if MII attach failed | Sebastian Huber | |
2017-10-23 | dpaa: Support c45 phys | Sebastian Huber | |
2017-10-23 | dpaa: Implement GENMASK() similar to Linux | Sebastian Huber | |
2017-10-23 | dpaa: Use receive checksum offload | Sebastian Huber | |
2017-10-23 | Linux update to 4.11-rc5 | Sebastian Huber | |
Linux baseline a71c9a1c779f2499fb2afc0553e543f18aff6edf (4.11-rc5). | |||
2017-10-23 | Import DPAA driver snapshot | Sebastian Huber | |
Imported from Freescale Linux repository git://git.freescale.com/ppc/upstream/linux.git commit 2774c204cd8bfc56a200ff4dcdfc9cdf5b6fc161. Linux compatibility layer is partly from FreeBSD. | |||
2017-10-20 | Import CRC32 support from FreeBSD | Sebastian Huber | |
2017-10-20 | Initialize BSD user extension earlier | Sebastian Huber | |
2017-10-20 | blist: Import from FreeBSD | Sebastian Huber | |
2017-10-20 | Fix INVARIANTS support | Sebastian Huber | |
2017-10-20 | rtems-kernel-page: Reclaim pages earlier | Sebastian Huber | |
2017-10-20 | rtems-kernel-page: Add used pages counter | Sebastian Huber | |
2017-10-10 | user-space: Define O_DIRECTORY | Sebastian Huber | |
2017-09-27 | ffec: Port to RTEMS | Sebastian Huber | |
2017-09-22 | Generalize bsp_fdt_map_intr() | Sebastian Huber | |
Update #3090. |
