2016-08-05 | if_ffec_mcf548x: Init when interface is set to UP.4.11.34.11.24.11.14.11.04.11 | Christian Mauderer | |
Call the driver initialization function if the interface is set to UP. | |||
2016-08-04 | netstat: Don't init vars if they are not defined. | Christian Mauderer | |
The variables are not available, if there is no INET6 defined. | |||
2016-08-04 | freebsd: Use constant ipv6 addresses from vars.c. | Christian Mauderer | |
2016-08-03 | testsuite/pf02: Add interactive pf test. | Christian Mauderer | |
2016-08-03 | libbsd.txt: Add section describing PF. | Christian Mauderer | |
2016-08-03 | libbsd.txt: Add guide for user space tools. | Christian Mauderer | |
2016-08-03 | testsuite/pf01: Test pfctl and pf. | Christian Mauderer | |
2016-08-03 | pfctl: Add rtems_bsd_command_pfctl. | Christian Mauderer | |
2016-08-03 | pfctl: build files. | Christian Mauderer | |
2016-08-03 | pfctl: Add yacc generated file. | Christian Mauderer | |
2016-08-03 | pfctl: Adapt for RTEMS. | Christian Mauderer | |
2016-08-03 | pfctl: Use static where possible. | Christian Mauderer | |
2016-08-03 | pfctl: Add const and move static variables. | Christian Mauderer | |
Note: This should be upstreamed into BSD. Make everything constant that can be constant and move static variables out of their functions. | |||
2016-08-03 | pfctl: Match prototype. | Christian Mauderer | |
Note: This should be upstreamed into BSD. | |||
2016-08-03 | pfctl: Import sources from FreeBSD. | Christian Mauderer | |
2016-08-03 | freebsd: Don't use new wrappers for old ports. | Christian Mauderer | |
Some of the commands have been adapted manually. So the wrapper currently don't necessarily work as expected. For example ifconfig calls malloc outside of the program call. | |||
2016-08-03 | rtemsbsd: Add wrapper for open, fopen, malloc, ... | Christian Mauderer | |
Add the following rtems_bsd_program_... wrapper: * rtems_bsd_program_open * rtems_bsd_program_socket * rtems_bsd_program_close * rtems_bsd_program_fopen * rtems_bsd_program_fclose * rtems_bsd_program_malloc * rtems_bsd_program_calloc * rtems_bsd_program_realloc * rtems_bsd_program_free * rtems_bsd_program_strdup * rtems_bsd_program_vasprintf * rtems_bsd_program_asprintf | |||
2016-08-03 | rtemsbsd: Add call to program with a data restore | Christian Mauderer | |
This adds the rtems_bsd_program_call_main_width_data_restore function. | |||
2016-08-03 | testsuite/syscalls01: Split out program01 part. | Christian Mauderer | |
This allows to use normal functions for sockets and similar while allowing to test the upcoming rtems_bsd_program_opan/close/... for the program part. | |||
2016-08-03 | testsuite/pf01: Add test that links PF. | Christian Mauderer | |
2016-08-03 | rtems-bsd-symbols.h: add pf symbols. | Christian Mauderer | |
2016-08-03 | linkersets.h: Add necessary macros from rtems 4.12. | Christian Mauderer | |
2016-08-03 | rtemsbsd: Add linkersets.h from current rtems 4.12. | Christian Mauderer | |
2016-08-03 | testsuite/cdev01: Add test for cdev functions. | Christian Mauderer | |
2016-08-03 | kern_conf.c: Adapt for RTEMS. | Christian Mauderer | |
2016-08-03 | kern_conf.c: Import from FreeBSD. | Christian Mauderer | |
2016-08-03 | rtemsbsd/devfs: Add. | Christian Mauderer | |
2016-08-03 | Dummy securelevel_ge() and securelevel_gt() | Sebastian Huber | |
2016-08-03 | subr_prf.c: Port to RTEMS. | Sebastian Huber | |
Note: Only the XXsYYprintf functions have been back ported from 4.12. | |||
2016-08-03 | subr_prf.c: Import from FreeBSD | Sebastian Huber | |
2016-05-06 | ZONE(9): Fix mp_maxid definition | Sebastian Huber | |
2016-05-06 | The maxid is not the number of cpus. | Chris Johns | |
2016-02-02 | Fix heap corruption in UNIX domain socket connect | Sebastian Huber | |
Close #2558. | |||
2015-11-16 | SOCKETPAIR(2): Port to RTEMS | Sebastian Huber | |
2015-11-16 | Update rtems_waf module | Sebastian Huber | |
2015-11-10 | Rename kernel space log() to _bsd_log() | Sebastian Huber | |
This avoids a conflict with the standard math library log() function. | |||
2015-11-10 | Delete broken Makefile, use waf instead | Sebastian Huber | |
2015-10-19 | NSDISPATCH(3): Add proper nsparser.h | Sebastian Huber | |
Update nsparser.h to fit with the files introduced via e35a65e99512000ab0107c4fc64f89aa84f7de38. | |||
2015-09-11 | media01: Add network and SMP support | Sebastian Huber | |
2015-09-11 | ZONE(9): Fix slab flag handling | Sebastian Huber | |
Disable unused slab flags. | |||
2015-09-11 | ZONE(9): Disable unused field | Sebastian Huber | |
2015-09-11 | ZONE(9): Define SMP if RTEMS_SMP is defined | Sebastian Huber | |
2015-09-11 | if_dwc: Fix a possible interrupt starvation | Sebastian Huber | |
2015-09-11 | if_dwc: Invalidate read buffer again | Sebastian Huber | |
This may prevent problems in case a cache line prefetch added some lines to the cache during a DMA transfer. | |||
2015-07-23 | Update due to header guard changes | Sebastian Huber | |
2015-07-16 | Fix buiding for the i386. | Chris Johns | |
2015-07-15 | libbsd.txt: Clarify rules to modify FreeBSD code | Sebastian Huber | |
2015-06-26 | tcpdump: Return the PCAP loop return value. Increase the stack size. | Chris Johns | |
2015-06-26 | tcpdump: Allow enter/return to exit tcpdump. | Chris Johns | |
Implement the PCAP loop in a separate thread and block the shell thread in the stdin getchar. When a user presses enter/return call the PCAP break loop function to have it return. | |||
2015-06-26 | modified: waf_generator.py Fix incorrect encoding of NET_CFG_GATEWAY_IP and ↵ | Gene Smith | |
change _IP_IP ending to _IP. Remove _IP_IP ending from NET_TAP_INTERFACE. modified: wscript Re-generated from "./freebsd-to-rtems -m" based on waf_generator.py |
