summaryrefslogtreecommitdiff
path: root/rtems-tld.cpp (unfollow)
AgeCommit message (Collapse)Author
2014-09-06Refactor the CC flags. Fix the various linkers. The trace linker is compiling.Chris Johns
2014-09-05Remove march/mcpu and add RTEMS BSP and cflags support.Chris Johns
2014-09-01rld: Split the file into a path module for path specific functions.Chris Johns
This allows resued for other parts of the system not dependent on objcet files or archives.
2014-08-07rtms-tld: Refactor the code to match a better configuration format.Chris Johns
2014-08-05rtems-tld: Add wrapper support and start the generator coding.Chris Johns
2014-08-04rtems-tld: Add generator loading support.Chris Johns
2014-08-04rtems-tld: Add recursive parsing of headers and defines.Chris Johns
2014-08-04rtems-tld: Add trace configuration support.Chris Johns
Extend the configuration support to provide the needed configuration required to generate the C stub support.
2014-08-01Add initial support for the RTEM Trace Linker.Chris Johns
The RTEMS Trace Linker or rtems-rld creates an RTEMS executable with trace support built in without any changes the existing code. This commit is an initial starting point with function signatures being read from INI files.
