summaryrefslogtreecommitdiff
path: root/ConvertUTF.c (unfollow)
AgeCommit message (Collapse)Author
2014-08-01Add initial support for the RTEM Trace Linker.Chris Johns
The RTEMS Trace Linker or rtems-rld creates an RTEMS executable with trace support built in without any changes the existing code. This commit is an initial starting point with function signatures being read from INI files.
