2018-01-09 | FIXME Update Makefile.am with header.amno-preinstall | Sebastian Huber | |
2018-01-05 | FIXME Install linkcmds | Sebastian Huber | |
2018-01-05 | FIXME Move bsp_specs to BSP linkcmds directory | Sebastian Huber | |
2018-01-05 | Remove preinstall from the build system. | Chris Johns | |
Update #3254. | |||
2018-01-02 | bsps: Use CPPASCOMPILE for startfile | Sebastian Huber | |
Update #3254. | |||
2018-01-02 | bsps: Add EXTRA_DIST to all BSP Makefile.am | Sebastian Huber | |
This makes it possible to easily use EXTRA_DIST += foobar in fragments. Update #3254. | |||
2018-01-02 | bsps: Include bsp.am in all BSP Makefile.am | Sebastian Huber | |
Update #3254. | |||
2017-11-27 | bsps: Provide <tm27.h> in each BSP | Sebastian Huber | |
Since the <tm27.h> is highly BSP-dependent and used only by the tm27 test program we must provide this header file for each BSP. Without the preinstall build target each header file must have a unique source header file. Update #3254. | |||
2017-11-24 | Remove coverhd.h | Sebastian Huber | |
This header file contained timing overhead values which are hard to maintain. Update #3254. | |||
2017-11-17 | getentropy: Add cpu counter based implementation. | Christian Mauderer | |
Update #3239. | |||
2016-02-03 | Use linker set for libio initialization | Sebastian Huber | |
Update #2408. | |||
2016-01-19 | bsps/arm: Use common ARMv7-M bsp_reset() | Sebastian Huber | |
2015-12-10 | bsps: Delete superfluous bsp_pretasking_hook() | Sebastian Huber | |
Use the bsp_predriver_hook() instead. Update #2408. | |||
2014-09-18 | bsps: Fix build error | Sebastian Huber | |
Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802. | |||
2014-02-14 | score: Add CPU counter support | Sebastian Huber | |
Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter. | |||
2013-05-03 | bsps/arm: Move implementation to inline functions | Sebastian Huber | |
2013-04-26 | bsp/lm3s69xx: New BSP variants | Eugeniy Meshcheryakov | |
Add support for LM3S3749. | |||
2012-03-24 | bsps: Shared ARMv7-M interrupt support | Sebastian Huber | |
2012-03-24 | bsps: Add shared default IRQ handler | Sebastian Huber | |
2012-03-24 | bsp/lm3s69xx: Format | Sebastian Huber | |
2012-03-24 | bsp/lm3s69xx: Use shared timer stub driver | Sebastian Huber | |
2012-03-24 | bsp/lm3s69xx: Use shared start.S | Sebastian Huber | |
2012-03-24 | bsps: Shared ARMv7-M clock driver | Sebastian Huber | |
2011-11-07 | 2011-11-07 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | |
PR 1951/bsps * Makefile.am, console/console-config.c: Update due to API changes. | |||
2011-09-24 | 2011-09-24 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | |
* 0001-Fixed-interrupt-handling-for-ARMv7M.patch, 0002-Fixed-system-handler-priority-register-access.patch, 0003-Disable-priority_mask-unused-for-NVIC.patch, 0004-Typo.patch, 0005-Evil-hack-for-BASEPRI-BASEPRI_MAX.patch, 0006-Evil-hack-to-increase-the-RAM-size.patch, bsp_specs, ChangeLog, clock/clock-config.c, configure.ac, console/console-config.c, console/uart.c, .cvsignore, include/bsp.h, include/.cvsignore, include/irq.h, include/lm3s69xx.h, include/uart.h, irq/irq.c, make/custom/lm3s6965.cfg, make/custom/lm3s69xx.inc, Makefile.am, README, start/start.S, startup/bspreset.c, startup/bspstart.c, startup/bspstarthook.c, startup/linkcmds.lm3s6965, timer/timer.c: New files. |
