"medit" overran the argument list, choking on the NULL pointer
following the last argument.
Note that "medit" still only does byte-sized accesses, which limits
its usefulness on most systems.
Author: Werner Almesberger <werner@almesberger.net>
Signed-off-by: Sebastien Bourdeauducq <sebastien@milkymist.org>
PR 1984/doc
* user/conf.t: Change CONFIGURE_MINIMUM_STACK_SIZE to
CONFIGURE_MINIMUM_TASK_STACK_SIZE.
PR 1983/networking
* libnetworking/libc/gethostbyht.c (gethostent_r):
Abort if (!hostf).
PR 1961/cpukit
* score/src/coremsgsubmit.c: Close window caused by using message
pending count rather than directly obtaining unused buffer.
PR 1934/bsps
* libchip/serial/ns16550.c: Change to unsigned variable.
PR 1957/cpukit
* score/include/rtems/score/coremutex.h,
score/inline/rtems/score/threadmp.inl: Add parentheses to protect
macro arguments.
PR 1952/cpukit
* libmisc/untar/untar.c: Add return code for failure when unable to
write file.
PR 1890/cpukit
* psxmsgq01/init.c: POSIX says msg_prio is allowed to be NULL.
PR 1890/cpukit
* posix/src/mqueuerecvsupp.c: POSIX says msg_prio is allowed to be
NULL.
PR 1855/cpukit
* Makefile.am, configure.ac, psx16/Makefile.am: Correct signal
processing during pthread_join. We are supposed to unblock the thread
waiting on a pthread_join(), dispatch the signal handler, account for
it potentially overwriting errno, and then have the thread return to
blocking within pthread_join().
* psxeintr_join/.cvsignore, psxeintr_join/Makefile.am,
psxeintr_join/init.c, psxeintr_join/psxeintr_join.doc,
psxeintr_join/psxeintr_join.scn: New files.
PR 1855/cpukit
* posix/src/psignal.c, posix/src/psignalunblockthread.c,
posix/src/pthread.c, posix/src/pthreadjoin.c: Correct signal
PR 1867/cpukit
* Makefile.am, configure.ac, psx12/task.c, psxrwlock01/test.c: Correct
implementation of pthread_exit() and pthread_join() to support the
case where a thread is joinable but calls pthread_exit() before a
thread has attempted to join.
* psx16/.cvsignore, psx16/Makefile.am, psx16/init.c, psx16/psx16.doc,
psx16/psx16.scn: New files.
PR 1867/cpukit
* posix/src/pthreadexit.c, posix/src/pthreadjoin.c: Correct
PR 1864/doc
* user/conf.t: Add missing documentation for
CONFIGURE_MAXIMUM_POSIX_BARRIERS , CONFIGURE_MAXIMUM_POSIX_SPINLOCKS,
CONFIGURE_MAXIMUM_POSIX_RWLOCKS.
PR 1851/doc
* user/conf.t: Fix typo in CONFIGURE_MESSAGE_BUFFER_MEMORY example.
PR 1839/filesystem
* libcsupport/include/rtems/libio_.h, libcsupport/src/fchdir.c,
libcsupport/src/fdatasync.c, libcsupport/src/fpathconf.c,
libcsupport/src/fsync.c, libcsupport/src/read.c,
libcsupport/src/readv.c, libcsupport/src/write.c,
libcsupport/src/writev.c: Some calls did not return proper status for
permission errors or incorrectly permissions at all.
* Makefile.am, preinstall.am: Include stubs so all tests compile.
* include/tm27.h: New file.
* clock/ckinit.c: Correct back port.
PR 1845/bsps
* custom/rtl22xx_t.cfg: Remove unused line with what is now invalid
syntax.
PR 1778/bsps
* vme/VMEConfig.h: Used the VME shared IRQ handlers.
* include/bsp.h: Removed BSP_PIC_DO_EOI.
* network/if_100MHz/GT64260eth.c:
Recycle the Rx mbuf if there is any Rx error.
PR 1766/bsps
* clock/ckinit.c: Add missing read of Timer_Counter_1.
PR 1837/bsps
* shared/motorola/motorola.c, shared/motorola/motorola.h: Add MVME2400
board with 750 CPU to list of supported Motorola boards.
PR 1838/filesystem
* libcsupport/src/fchmod.c: fchmod() does not need a writeable file
descriptor.
PR 1381/networking
* netinet/ip_output.c: If a null or unreachable gateway is
specified either statically in networkconfig.h or from dhcp/bootp,
sendto() fails on multicast send with errno "118 Host is unreachable".
The failure occurs in networking file ip_output.c since it currently
requires all multicasts to have a valid route to the outside world.
PR 1381/networking
* libnetworking/netinet/ip_output.c: If a null or unreachable gateway
is specified either statically in networkconfig.h or from dhcp/bootp,
sendto() fails on multicast send with errno 118 Host
PR 1833/bsps
* ne2000/ne2000.c: Addition of multicast support disabled broadcast
reception. Patch also includes support to work on big endian CPUs.
PR 1812/filesystem
* libfs/src/imfs/imfs_stat.c: stat() implementation for IMFS did not
set st_blksize field. Set it based upon user configuration.
PR 1783/bsps
* include/bsp.h: Remove dead prototypes of Clock_delay() and delay().
Neither had bodies.
* ne2000/ne2000.c: Add multicast support. Patch submitted to mailing
list 2005-12-21.
PR 1722/networking
* ftpd/ftpd.c: FTPD fails to parse correctly FTP commands relating to
filenames with spaces in them.
