- Refactor the libio interface
- Move syscalls into an rtemsbsd location
- Provide a root directory mount point
Update #4475
- Object files cannot config init and resided in libbsd.a
Update #4475
Update #4475
Update #4475
Update #4475
- Provides the thread's proc pointer and with that access to creds
Update #4475
Update #4475
- See `man lockmgr`
- Implement the lock_object and move the RTEMS mutex to that object
- Add debug support to track the locks with gdb
Update #4475
Update #4475
Update #4475
Update #4475
Update #4475
Update #4475
Update #4475
- The script's use of sort proved to not be portable
- No need to check the commits as symbols are only added
- Regenerated kernel header to reset the sort order
Update #4475
The default implementation was completely broken. Use the GCC specific
__alignof__ if compiling for C99 or C++03. If not C++11, C11, or
GCC, then it is an error.
Made ZynqMP build with the SDHCI driver.
Now that the issue with false PHY detection on unterminated MII busses
has been resolved, present all hardware interfaces for use on ZynqMP.
When the MII bus is unterminated on unused interfaces, it results in PHY
read timeouts which manifest as spurious PHYs during the attach call.
Detect these timeouts during the probe so the device can be ignored.
This alters the selection of the 4 Cadence GEM interfaces on the Zynq
Ultrascale+ MPSoC BSP to be provided by config.inc instead of being
provided by options in the RTEMS BSP itself since those options appear
to be dead code when not used in conjunction with LibBSD.
Added a new test for the TTCP command. Modified default-network-init.h
to conditionally build the shell with TTCP. Modified libbsd.py to build
the new TTCP test.
Updated ttcp.c to build clean for RTEMS 6 and the machines it
originally built for. Also fixed ttcp.c to close network
sockets after completion. Defined a shell command for TTCP in
rtems-bsd-shell-ttcp.c. Added TTCP to the list of RTEMS network
commands in netcmds-config.h. Added declaration of the TTCP shell
command to rtems-bsd-commands.h. Modified libbsd.py to make waf
build TTCP and its shell command.
Updated the TTCP code to match the ttcp.c in RTEMS network-demos
repository (https://git.rtems.org/network-demos/).
Added the original Test TCP (TTCP) program in unmodified form.
Also added the original README for TTCP. Both the README and the
TTCP program were sourced from the first commit in the RTEMS
network demos repository.
Use the new options from the ZynqMP BSPs to allow selection of the
available CGEM ethernet interfaces.
For checking the dependencies, the tests are removed. But if the tests
are not enabled at all, that triggers a python exception.
During some newlib version, the _types_fd_set has been replaced with
just fd_set.
Since the epoch call callbacks may lock/unlock a mutex the callbacks must be
called from within thread context with thread dispatching enabled. Use thread
pinning to ensure that the calling thread stays on the right processor. Use
the interrupt server to ensure the thread context for the epoch drain.
Use the PER_CPU_DATA_NEED_INITIALIZATION() macro if necessary to request an
initialization of the per-CPU data.
Changed nfs_utime() to nfs_utimens(), changed the arguments to use
a timespec array instead of individual variables for access and
modified time.
Updates #4400
setkey uses pfkey_open to open a socket. But setkey doesn't close the
socket.
The libipsec functions are used only by user space applications (setkey
and racoon). Adding the wrapper for socket makes sure that the opened
socket is registered and closes if the application exits.
Fixes #4405
Possible data sources for SD driver:
- mmc_sd_switch():
- length: 64 byte;
- buffer on stack
- mmc_test_bus_width():
- length: 4 or 8 byte
- buffer in program memory or on stack
- mmc_app_send_scr():
- length: 8 byte
- buffer from device ivar structure
- mmc_app_sd_status():
- length: 64 byte
- mmc_send_ext_csd():
- length: MMC_EXTCSD_SIZE = 512
- rtems_bsd_mmcsd_disk_read_write():
- length: depends on read
- buffer from rtems_blkdev buffer -> already aligned
- mmcsd_ioctl_cmd():
- length: depends on call
- buffer malloced, not aligned -> patched in RTEMS
So the problematic buffers are only the ones up to 512 bytes. Copy these data
into a buffer to avoid that problem.
Some drivers can't easily work with buffers that are not cache aligned
and have an arbitrary length. Therefore use an aligned malloc instead.
Update #4372
Update #4372
Update #4372
This is basically the same as the patch for ping.
Update #4360
Dynamically allocate a big enough file descriptor set for select(). A
better solution would be to use kqueue() instead of select().
Update #4360
ZynqMP hardware comes with many different Ethernet PHYs depending on
which board is used. Add the UKPHY driver to handle basic PHY
interaction for any unrecognized PHYs.
According to commentary on GCC bug
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99143, the alignment
behavior of linker sections on which RTEMS has relied was never
guaranteed to be consistent across platforms and any alignment
requirements for linker sections needs to be enforced explicitly.
This adds those explicit alignment requirements.
libck assumes all AArch64 pointers are 8 bytes. This adds the required
defines to handle 4 byte pointers on ILP32.
Add a System Level Control Register driver for the Xilinx Zynq
Ultrascale+ MPSoC with basic clock control functionality for use with
the Cadence GEM. This also removes the Zynq-7000 clock control weakref
from compilation depending on the BSP in use.
Similar to the UARTs, ZynqMP hardware platforms use the highest
memory-mapped CGEM peripheral as the primary instance of that
peripheral. This change allows operation on hardware as well as QEMU.
This is a port of the latest patch in FreeBSD that adds support for
64bit CGEMs as used in ZynqMP. This does not include the work necessary
for support on RISC-V systems.
Alignment on 64bit hardware is strict in comparison to running in an
emulator. This resolves an alignment exception when allocating memory on
real hardware.
Closes #4264
