Unlike the older build this keeps files within each BSP now that we have a
one-directory-per-bsp model.
This supports external BSPs trivially by keeping all files separate from
the base build.
This allows to use header includes in "config.h" to reduce the build
configuration checks.
Update #3818.
Update #3818.
Provide an init.c for each Ada test instead of the #include <config.h>
magic which works only due to hand crafted include paths.
Update #3818.
Close #3823.
Rename source files to use a %.c -> %.o and %.cc -> %.o pattern. Use
*.cc for C++ source files instead of *.cpp to be in line with other C++
source files.
Update #3818.
Use rtems_tarfs_load() instead of Untar_FromMemory() to reduce the
memory demands of the tests.
The functions expect a valid string as input according to POSIX. On
systems with a NULL pointer protection the test cases ended up in
exceptions.
Use uniform pattern for all TAR file names. Use the dl* tests as a
template.
Update #3818.
Add the static files to the repository. This simplifies the build.
Update #3818.
This simplifies the build process. Do not generate the archive content
through the build system. Let the version control system deal with
symbolic links.
Update #3818.
Close #3823.
Update #3823.
Output only the basename of source files to be independent of the build
system source paths.
In the future it may be better to use the GCC -fmacro-prefix-map option.
This option is available in GCC 8 and later. It is not yet available in
clang.
Update #3818.
Update #3818.
Update #3818.
This partially reverts commit 7ec08391fee73d7a25855089f4996f3c4f448007.
Since the RTEMS_DEFINE_GLOBAL_SYMBOL_IN_SECTION() cannot control the
alignment of the symbol it cannot be used to define the begin of a
linker set. File scope basic __asm__ statements cannot have operands,
so there is no way to specify the desired alignment.
Both need POSIX support
Fix prototype.
Fix node size. Linfiles are dynamically turned into memfiles.
Update #3823.
Update #3818.
Update #3818.
This BSP family uses only one linker command file. Use the standard
name.
Update #3818.
name.
Update #3818.
Integrate parts of this commit:
This commit brings in a new refactored TCP stack
called Rack. Rack includes the following features: - A different SACK
processing scheme (the old sack structures are not used). - RACK (Recent
acknowledgment) where counting dup-acks is no longer done instead time
is used to knwo when to retransmit. (see the I-D) - TLP (Tail Loss
Probe) where we will probe for tail-losses to attempt to try not to take
a retransmit time-out. (see the I-D) - Burst mitigation using TCPHTPS -
PRR (partial rate reduction) see the RFC.
Once built into your kernel, you can select this stack by either
socket option with the name of the stack is "rack" or by setting
the global sysctl so the default is rack.
Note that any connection that does not support SACK will be kicked
back to the "default" base FreeBSD stack (currently known as "default").
To build this into your kernel you will need to enable in your
kernel:
makeoptions WITH_EXTRA_TCP_STACKS=1
options TCPHPTS
Sponsored by: Netflix Inc.
Differential Revision: https://reviews.freebsd.org/D15525
Update #3818.
Use the test state configuration instead.
Update #3818.
Update #3818.
name.
Update #3818.
name.
Update #3818.
Update #3785.
Update #3785.
Always provide this function. Return 0 by default. Fix formatting.
Simplify function.
Update #3785.
It is fine to build the drivers always.
Update #3818.
Support for targets compiled with -fno-pic and -mno-relax
Fix all warnings.
Update #3818.
Update #3818.
Move system.h to shared init.c.
Update #3818.
Update #3818.
Update #3818.
This avoids an extra include path.
Update #3818.
Update #3818.
