* arm/beagleboardorig
* arm/beagleboardxm
* arm/beaglebonewhite
* arm/beagleboneblack
All tests build as well.
All tests build. The other zynq BSPs have not been added yet.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Close #2477.
The expensive heap walks are superfluous due to the heap protection
enabled via RTEMS_DEBUG.
Update #2477.
This function is used by Newlib since 2013-07-09 (Git commit
9b51cd8c6b9cdd067d9648a7ab952884019c56a5).
This structure is available in Newlib since 2013-11-29 (Git commit
a534dfd26e765047621acd0eda656ded886e7108).
The problem exists for both RTEMS untar implementations and their
variants: Untar_FromMemory(), Untar_FromFile() and rtems_tarfs_load().
If filesystem object already exists at extracted directory path
then if it is directory, creation is ignored. Attempt
to delete/unlink object and make directory is tried for other cases.
This simple approach problem reported in ticket fixes #2413.
Behavior follows GNU tar and BSD tar practice for directories
but much more work is required to achieve full semantics
of the full featured tar implementation still.
Required by new network stack.
We must not load registers (e.g. PSR) from the heir context area before
the heir stopped execution.
With this patch the write to PSR is divided into two steps. We first update
the current window pointer and then we restore the status registers and
enable traps. This allows us to move the first write to PSR to be before
the write to WIM, as there is now no risk that we get an interrupt where
the CWP and WIM would be inconsistent. We only need to make sure that we
do not use any of the non-global registers or instructions that affects
CWP for three instructions after the write.
In the earlier code the non-global %o1 register was used right after the
write to PSR, which required the use of three nop:s.
We must ensure that the Thread_Control::Wait information update is
visible to the target thread before we update its wait flags, otherwise
we may return out of date events or a wrong status.
Use this event for the interrupt server to avoid conflicts with
application events used by interrupt handlers.
Close #2459.
Close #2454.
Include stackimpl.h otherwise PTHREAD_MINIMUM_STACK_SIZE cannot be
evaluated.
closes #2431.
Close #2433.
This allows BSPs to use this library.
Import from:
git://git.kernel.org/pub/scm/utils/dtc/dtc.git
Commit:
604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e
Date:
2015-09-29T09:09:08Z
This reverts the relevant part of commit
da06fe948c0878057e5f563ebd3dfe40c0f1b0d2. The acquire/release order is
superfluous for the next ticket increment. The mutual exclusion is
guaranteed by the acquire load from and release store to the next
serving atomic variable.
This reduces the code size.
According to the C11 and C++11 memory models only a read-modify-write
operation guarantees that we read the last value written in modification
order. Avoid the sequential consistent thread fence and instead use the
inter-processor interrupt to set the thread dispatch necessary
indicator.
Do not obfuscate the standard API.
