summaryrefslogtreecommitdiff
path: root/make (unfollow)
AgeCommit message (Collapse)Author
2011-12-082011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
PR 1589/build * leaf.cfg, Templates/Makefile.leaf: Remove obsolete optional manager capability.
2011-06-172011-06-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* host.cfg.in: Remove (Unused).
2011-04-012011-04-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* custom/default.cfg: Update to account for movement of .cfg files.
2011-03-042011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* Makefile.am: Remove (merged into ../Makefile.am).
* compilers/gcc-target-default.cfg: Remove (Unused). * Makefile.am: Reflect change above.
* compilers/gcc-no_bsp.cfg: Remove (Unused). * Makefile.am: Reflect change above.
2010-07-272010-07-27 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
PR 1532/testing * host.cfg.in: Add initial tests for untar capabilities.
2009-10-162009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* custom/bare.cfg: Remove (Abandoned). * Makefile.am: Remove custom/bare.cfg.
2009-10-16Remove custom/bare.cfg.Ralf Corsepius
2009-10-16Remove (Abandoned).Ralf Corsepius
2009-10-152009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* Makefile.am: Remove custom/no_bsp.cfg.
2009-10-15Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius
* custom/no_bsp.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* Makefile.am: Reflect custom/*.cfg having moved.
* custom/av5282.cfg, custom/csb360.cfg, custom/gen68302.cfg, custom/gen68340.cfg, custom/gen68360_040.cfg, custom/gen68360.cfg, custom/pgh360.cfg, custom/genmcf548x.cfg, custom/m5484FireEngine.cfg, custom/idp.cfg, custom/mcf5206elite.cfg, custom/mcf52235.cfg, custom/mcf5235.cfg, custom/mcf5329.cfg, custom/mrm332.cfg, custom/mvme136.cfg, custom/mvme147.cfg, custom/mvme147s.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg, custom/ods68302.cfg, custom/sim68000.cfg, custom/simcpu32.cfg, custom/uC5282.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/csb336.cfg, custom/csb337.cfg, custom/csb637.cfg, custom/edb7312.cfg, custom/gba.cfg, custom/arm1136jfs.cfg, custom/arm1136js.cfg, custom/arm7tdmi.cfg, custom/arm920.cfg, custom/armcortexa9.cfg, custom/gp32.cfg, custom/gumstix.cfg, custom/lpc24xx.cfg, custom/lpc24xx_ea.cfg, custom/lpc24xx_ncs_ram.cfg, custom/lpc24xx_ncs_rom_ext.cfg, custom/lpc24xx_ncs_rom_int.cfg, custom/nds.cfg, custom/rtl22xx.cfg, custom/rtl22xx_t.cfg, custom/smdk2410.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/csb350.cfg, custom/genmongoosev.cfg, custom/hurricane.cfg, custom/jmr3904.cfg, custom/rbtx4925.cfg custom/rbtx4938.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/m32csim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/m32rsim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/lm32_evr.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/icecube.cfg, custom/pm520_cr825.cfg, pm520_ze30.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/hsc_cm01.cfg, custom/mpc8313erdb.cfg, custom/mpc8349eamds.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/bf537Stamp.cfg, custom/eZKit533.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/brs5l.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/h8sim.cfg, custom/h8sxsim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/c3xsim.cfg, custom/c4xsim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/pghplus.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/ep1a.cfg, custom/gen5200.cfg, custom/gen83xx.cfg, custom/haleakala.cfg, custom/mbx821_001.cfg, custom/mbx821_002.cfg, custom/mbx821_002b.cfg, custom/mbx860_001b.cfg, custom/mbx860_002.cfg, custom/mbx860_005b.cfg, custom/mbx860_1b.cfg, custom/mbx8xx.cfg, custom/mcp750.cfg, custom/mpc5566evb.cfg, custom/mpc55xx.cfg, custom/mpc8260ads.cfg, custom/mtx603e.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg, custom/psim.cfg, custom/qemuppc.cfg, custom/score603e.cfg, custom/ss555.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg, custom/virtex.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/nios2_iss.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/leon3.cfg, custom/leon2.cfg, custom/sis.cfg, custom/erc32.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/avrtest.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/i386ex.cfg, custom/pc486.cfg, custom/ts_386ex.cfg, custom/pc386.cfg, custom/pc586.cfg, custom/pc386dx.cfg, custom/pc686.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/gensh1.cfg, custom/gensh2.cfg, custom/gensh4.cfg, custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh2e.cfg, custom/simsh4.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-142009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* custom/Cygwin-posix.cfg, custom/FreeBSD-posix.cfg, custom/Linux-posix.cfg, custom/Solaris-posix.cfg, custom/posix.cfg: Remove.
2009-10-14Remove.Ralf Corsepius
2009-10-05add missing filesThomas Doerfler
2009-10-05renamed config filesThomas Doerfler
2009-10-012009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* Makefile.am: Add new BSP variants for ARM simulator in GDB. * custom/arm1136jfs.cfg, custom/arm1136js.cfg, custom/arm7tdmi.cfg, custom/arm920.cfg, custom/armcortexa9.cfg: New files.
2009-09-242009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* Makefile.am: Add qemuppc.cfg. * custom/qemuppc.cfg: New file.
2009-09-142009-09-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* custom/gen83xx.cfg: Remove -funit-at-a-time.
2009-08-272009-08-27 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* custom/leon2.cfg, custom/leon3.cfg: Fix typo.
