* sapi/include/confdefs.h: Fixed workspace size estimate of tasks.
* posix/src/mqueuenametoid.c,
posix/src/semaphorenametoid.c: Removed files.
* posix/src/psxnametoid.c: New file.
* posix/Makefile.am: Reflect changes above.
* posix/include/rtems/posix/config.h: Fixed integer types.
* posix/include/rtems/posix/posixapi.h: Declare _POSIX_Name_to_id().
* posix/include/rtems/posix/mqueue.h,
posix/inline/rtems/posix/mqueue.inl: Changed parameter of
_POSIX_Message_queue_Create_support().
_POSIX_Message_queue_Name_to_id() is now inline.
* posix/include/rtems/posix/semaphore.h,
posix/inline/rtems/posix/semaphore.inl: Changed parameter of
_POSIX_Semaphore_Create_support(). _POSIX_Semaphore_Name_to_id() is
now inline.
* posix/src/mqueuecreatesupp.c, posix/src/semaphorecreatesupp.c: Use
_Workspace_String_duplicate().
* posix/src/mqueuesendsupp.c, posix/src/mqueueopen.c,
posix/src/mqueueunlink.c, posix/src/seminit.c, posix/src/semopen.c,
posix/src/semunlink.c: Update due to API changes.
* sapi/include/confdefs.h: Fixed workspace size estimate of POSIX keys
and message queues.
* score/include/rtems/score/wkspace.h, score/src/wkstringduplicate.c:
Changed parameter of _Workspace_String_duplicate() to avoid strnlen().
* configure.ac: Check for getrusage.h decl.
* libcsupport/src/getrusage.c:
Apply HAVE_DECL_GETRUSAGE (Missing prototypes).
* score/src/wkstringduplicate.c: New file.
* score/Makefile.am: Reflect change above.
* score/include/rtems/score/wkspace.h: Declare
* posix/src/fork.c: Include <unistd.h> for "fork" prototype.
Don't include <sys/types.h> (unnecessary).
PR 1985/cpukit
* telnetd/Makefile.am: Remove icmds.c.
PR 1986/libcpu
* rtems/include/rtems/rtems/cache.h:
Add rtems_cache_aligned_malloc decl.
* posix/src/sigtimedwait.c: Make _POSIX_signals_Get_lowest static.
PR 1985/cpukit
* telnetd/icmds.c: Removed.
All functionality is in shell. Obsolete and unreferenced.
* cpu.c: Make _defaultExcHandler static.
* cpu.c: Correct typo.
* libblock/src/flashdisk.c:
Make rtems_fdisk_crc16_gen_factors static.
* libblock/src/nvdisk.c:
Make rtems_nvdisk_crc16_gen_factors static.
* rtems/src/rtemsobjectsetname.c:
Include <rtems/rtems/object.h> (Missing prototype).
* rtems/src/rtemsobjectgetclassicname.c:
PR 1968/filesystem
* libfs/src/rfs/rtems-rfs-file.c: Fix to the seek bug where a seek
to 0 after reading the end of the file did not point to the
correct block.
* libfs/src/rfs/rtems-rfs-rtems.h,
libfs/src/rfs/rtems-rfs-trace.c: Fix the trace flags. Used to fix
the bug.
* rtems/src/rtemsobjectgetname.c:
* sapi/src/getversionstring.c: Include <rtems.h> (Missing prototype).
* libcsupport/src/termios.c: Make rtems_termios_refill_transmitter
static.
PR 1981/cpukit
* posix/Makefile.am: Reflect changes below.
* posix/src/pthreadsetcputime.c, posix/src/pthreadgetcputime.c:
Remove (Obsolete).
* ftpd/ftpd.c: Make split_command static.
* libnetworking/rtems/rtems_dhcp.c:
Make format_ip, dhcp_init static.
* libnetworking/nfs/bootp_subr.c:
Make bootp_strdup_realloc static.
* rtems/src/rtemsobjectapiminimumclass.c:
Adjust rtems_object_api_minimum_class to prototype.
* libcsupport/src/sup_fs_is_separator.c:
Include <rtems/libio_.h> (Missing protypes).
* rtems/src/workspace.c:
Include <rtems/rtems/support.h> (Missing prototypes).
PR 1983/networking
* libnetworking/libc/gethostbyht.c (gethostent_r):
Abort if (!hostf).
* libnetworking/libc/ns_parse.c (ns_parserr):
Comment out if ( section < 0 ) (type is unsigned).
* libnetworking/libc/gethostbydns.c: Comment out __dns_getanswer
(Unused).
* rtems/src/ratemonperiod.c: Make _Rate_monotonic_Update_statistics
static.
* libcsupport/src/pipe.c: Include <unistd.h>.
Include <rtems/pipe.h>.
* libmisc/stackchk/check.c: Make Stack_check_Initialize,
Stack_check_Dump_threads_usage static.
* libfs/src/pipe/pipe.c: Include <rtems/pipe.h> (Missing prototype).
* score/src/heapiterate.c, score/src/pheapiterate.c: New files.
* score/Makefile.am: Reflect changes above.
* score/include/rtems/score/heap.h: Declare _Heap_Iterate() and define
Heap_Block_visitor.
* score/include/rtems/score/protectedheap.h: Declare
_Protected_heap_Iterate().
* score/src/heapgetinfo.c: Use _Heap_Iterate().
* rtems/powerpc/registers.h: More register defines.
* libcsupport/src/flockfile.c, libcsupport/src/ftrylockfile.c,
libcsupport/src/funlockfile.c:
Add __attribute__((unused)) to unused function parameters.
* libcsupport/src/envlock.c: Build conditionally.
* configure.ac: Check for envlock.h.
Check for decls of __env_lock, __env_unlock.
* libcsupport/src/envlock.c: Rename define ENVLOCK_DEDIDCATED_MUTEX
into ENVLOCK_DEDICATED_MUTEX (Typo).
* libmisc/serdbg/serdbg.h: Add serdbg_init_dbg.
* libmisc/serdbg/serdbgcnf.h:
Remove conditional serdbg_init_dbg prototype.
* libmisc/mouse/serial_mouse.c: Make serial_mouse_l_rint static.
* libcsupport/src/malloc_sbrk_helpers.c: Make
malloc_sbrk_initialize, malloc_sbrk_extend_and_allocate static.
* libmisc/monitor/mon-network.c: Include <rtems/monitor.h>.
* libmisc/monitor/mon-object.c:
Make rtems_monitor_object_canonical_next_remote,
rtems_monitor_object_dump_1, rtems_monitor_object_dump_all static.
* libmisc/monitor/mon-prmisc.c:
Make rtems_monitor_dump_assoc_bitfield static.
* libmisc/monitor/mon-symbols.c:
Make rtems_monitor_symbol_dump_all static.
* score/src/schedulercbsattachthread.c,
score/src/schedulercbsdestroyserver.c,
score/src/schedulercbsdetachthread.c,
score/src/schedulercbsgetapprovedbudget.c,
score/src/schedulercbsgetexecutiontime.c,
score/src/schedulercbsgetparameters.c,
score/src/schedulercbsgetremainingbudget.c,
score/src/schedulercbssetparameters.c:
Remove checks for server_id < 0 (server_id is unsigned).
* posix/src/pspinlocktranslatereturncode.c:
Include <rtems/posix/spinlock.h> (Missing prototypes).
* libfs/src/imfs/imfs_debug.c: Make IMFS_print_jnode,
IMFS_dump_directory static.
* libfs/src/imfs/memfile.c: Make memfile_free_blocks_in_table static.
* libcsupport/include/rtems/libio.h:
Make LIBIO_FLAGS_* defined unsigned (Avoid implicit sign
conversions).
* libmisc/capture/capture.c:
Make RTEMS_CAPTURE_* defines unsigned (Avoid implicit
sign-conversions).
Make rtems_capture_trigger static (Missing prototypes).
* libmisc/capture/capture.h:
Make RTEMS_CAPTURE_WATCH, RTEMS_CAPTURE_TRACED unsigned (Avoid
implicit sign conversions).
